Skip to content
1 of 12
Wyze Bulb Cam
Wyze Bulb Cam
2K Camera Built into a Smart Bulb
2K Color Night Vision
Group Lights Together
Manually extend, rotate and tilt
160 Degree View
Eliminate Blind Spots
$49.98
Wide 160° View Sees More Space
Hand adjusting camera head of the Wyze Bulb Cam
Adjusts to Fit Most Light Fixtures
Manually extend, pan, and tilt the camera to find just the right angle.
Dimmable 800 Lumen LED Bulb
Traditional lightbulbs look boring. We built this bulb to look modern and classy (just like you). Customize the brightness on these long-lasting LED bulbs to achieve the perfect lighting.
Works with Wyze Accessory Bulb
Meet the sidekick that's full of bright ideas. It's 800 lumens, dimmable, and works exclusively with Wyze Bulb Cam.
Wyze Accessory Bulb in outdoor light fixture
Enhanced Group Light Control
Auto-connect up to 5 Accessory Bulbs for full coverage smart lighting. Customize brightness and set schedules. Motion-activated lights? Yeah, they can do that too!
24/7 Local Recording with MicroSD Card*
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
  • Family using Wyze outdoor cam with two-way talk for dinner.
    Two-Way Audio
    Speak to people and pets from anywhere right from your smartphone.
  • Wyze app on phone: Garage Cam live view, person/vehicle detection alerts.
    Detection Features
  • Hand adjusting bulb camera with text overlay about Cam Unlimited Pro and a phone notification.
    AI Notifications and Descriptive Alerts
  • Motion sensor light illuminating driveway with a person approaching a car in a garage at night.
    Lighting Effects + Siren
    Flashing lights and a built-in siren will scare people away faster than a multi-level marketing invite.
Installation as easy as...
Brilliant setups
Versatile Wyze Camera Socket shown in three lighting setups.
Wyze Bulb Cam shown in outdoor fixture that is split between the morning, evening, and night.
Clear View Fit Check
Use the diagram below to confirm the clearance in your specific fixture. For optimal performance, the camera lens must extend beyond the bottom edge of your light fixture or sconce.
Viewing through glass or fixture housing can cause motion detection issues, unwanted reflections, and poor image quality.
Wyze Bulb Cam PVB-CBC-CBCAB - Wyze Labs, Inc.
Bulb Cam uses a standard E26 socket
  • Accessory Bulb
    Auto-connect and synchronize the lighting of up to 5 Wyze Accessory Bulbs (sold separately) for full coverage smart lighting.
  • SD Card
