Wired Front Porch Protection
Now you can see if it's your best friend, the mail guy, or your in-laws at the door.
Wyze Cam v4 (Color)
$99.98 $104.96
Use a 5-digit ZIP code.
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Keep an eye on who's coming and going without breaking the bank. Get the Wyze Video Doorbell v2 and a Wyze Cam v4 to see everything on your front porch.
    Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • A black and white image of a weather icon.
    Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
  • A black background with a white icon of a page.
    Product Warranty
    Every Wyze device has a 1-year warranty.
  • A purple circle with a white cross in it.
    Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v4 Specs
  • Colors: White, Grey, and Black
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue.
  • Dimensions: 2in x 2in x 2 3/8in
  • Weight: 0.49 lb (222 g)
  • Mounting: Stand, wall mount, ceiling mount, or magnetic wall mount (adhesive)
  • Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
  • Cable: 6-Foot Flat micro USB to USB-A
  • Resolution: 2.5K QHD (2560x1440)
  • Digital Zoom: 8x
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision/Color Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Learn more
  • Video Resolution: 2K (2048 x 1536)
  • Video Format: H.264
  • Sensor Size: 1/2.8"
  • Aperture: F2.0
  • Focal Length: 2.1mm
  • Frame Rate: Day: 20FPS, Night: 15FPS
  • Field-of-View: Horizontal: 135°, Vertical: 103°,
  • Diagonal: 166.8°
  • Power: 16V-24V AC,≥10VA
  • Microphone: ECM (Electric Condenser)
  • Zoom: Digital Zoom
  • MicroSD card: Up to 256G in FAT32 format
  • Cloud: When paired with a Wyze SecurityPlan
  • IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
  • IP65 weather resistant
  • Operating temp: -4°F - 122°F (-20°C - 50°C)
  • Storage temp: -40°F - 176°F (-40°C - 80°C)
Learn more
Connectivity & Compatibility
  • Bluetooth® 5.2
  • Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
Storage
  • Local (microSD card required)
  • MicroSD card up to 512 GB
  • Cloud (with subscription plan)
Weather
Warranty
  • 1-Year
Cam v4:
  • 1x Wyze Cam v4
  • 1x Quick Start Guide
  • 1x Wall Mount Plate
  • 1x Wall Mount Plate Tape
  • 1x Screw Kit
  • 1x Indoor USB Power Adapter
  • 1x 6-Foot Flat micro USB to USB-A cable
Wyze Video Doorbell v2:
  • 1x Wyze Video Doorbell v2
  • 1x Wyze Doorbell Chime Controller
  • 1x Wall Plate
  • 1x Wedge (30°)
  • 1x Installation Kit
  • 3x Wire Caps
  • 2x Extension Wires
  • 1x Screw Kit
  • 2x Long Screws
  • 2x Short Screws
  • 2x Wall Anchors
A person is pressing a button on a doorbell.
WYZE VIDEO DOORBELL V2
Around the clock front door monitoring.
2K Video Resolution with Head-To-Toe Viewing—Capture all porch arrivals and departures in greater detail.
  • Local recording with MicroSD card (sold separately)
  • Works with existing Doorbell Chime
  • Two-way audio
  • 3-6 seconds of pre-roll recording for motion events
  • Motion-Activated Voice Deterrence alerts visitors that they are being recorded
A white Wyze Cam is mounted on a black pole.
WYZE CAM V4
Packed with power and features.
We’ve upgraded everything that matters most to make this a powerful and affordable plug-in cam.
  • Crystal-clear 2.5K QHD resolution
  • See in full color with 1080p Color Night Vision
  • Speak and hear with clarity through your cam
  • Set this up inside or outside
A man wearing a hoodie is standing on a porch holding a box.
Night as clear as day.
A white camera with a black stand.
Security rain or shine.
Wyze Cam v4 and Video Doorbell v2 operate in any weather due to their IP65 weather-resistant rating.
A white doorbell with a picture of a person on it.
A green circle with a Wyze Cam v4 inside.
Even more features to love.
