Skip to content
1 of 13
Outdoor Security Plus - Wireless
Want continuous local recording?
SALE
$219.95 $304SAVE 27%
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Get powerful, wire-free protection for your entire yard with the Outdoor Security Plus – Wireless kit. This bundle includes two Wyze Solar Cam Pan units and a Wyze Cam Floodlight v2, giving you wide-angle monitoring, bright motion-activated lighting, and uninterrupted solar-powered coverage.
Wyze Solar Cam Pan (x2) delivers smooth 360° pan and 180° tilt movement with solar charging for year-round, battery-free operation. Perfect for monitoring large outdoor spaces, tracking motion, and keeping watch from any angle—without running a single cable.
Wyze Cam Floodlight v2 lights up dark areas with powerful LED illumination while capturing clear, detailed video. Advanced motion detection and wide-area coverage help deter intruders and keep your property fully visible at night.
Together, these devices create a flexible, wireless outdoor security system that provides full visibility, strong deterrence, and reliable power anywhere you need it.
  • Wyze Solar Cam Pan is a wireless camera with 2K HD resolution and AI-powered person tracking.
    Maintenance-free battery power with solar. 360° protection.
  • A white camera with a blue light on it.
    Lights up dark areas with powerful LED illumination and wide-angle monitoring.
Wyze Cam + The Sun. Love at first light.
Let the sun do the work. ☀️ An integrated high-efficiency ETFE solar panel delivers continuous power to the battery with one hour of sunlight per day.
360° pan/tilt coverage with AI-powered person tracking.
Edge AI detects and locks on to people, following them wherever they go. Secure an entire space with pan and tilt coverage. Control remotely via the Wyze app to see exactly what you want.
Flexible solar panel mounting.
Connect the solar panel on top of the camera for a tidy install. Or place it separately where the sunlight’s strongest for maximum charging power. The choice is yours.
Cloudy days? No sweat.
Does the sun like to hideout for a while where you live? No worries. The built-in 6400mAh lithium-ion battery provides up to 6-months of standalone power.
2K HD Resolution with WDR
Crystal-clear video recording with a wide field-of-view captures every detail, day or night. Wide Dynamic Range (WDR) evens out the brightest highlights and the darkest shadows so nothing gets lost.
Motion-activated spotlight & siren.
Deter intruders or light your way home with a motion-activated spotlight. Activate the loud 105dB siren for extra security.
Enjoy crystal-clear 2K resolution.
Immaculate 2K image quality means you can capture events in more detail than ever, especially at night. Because we all know the devil is in the details. Or maybe it was just Brad, the hypersensitive HOA president.
A person is standing in front of a car.
A side-by-side comparison of a traditional view and a wide-angle view of a Wyze Cam Floodlight v2.
See more, worry less.
A 160° wide-angle view gives you double the visibility compared to the previous generation. Moms everywhere are wondering if this can be applied to genetics.
A man standing in front of a garage door with a white car.
The dark doesn't stand a chance.
Turn night into day with two 2800 lumen, adjustable and motion-activated LED lights that illuminate your path and keep intruders at bay.
Man holding a golf bag and talking to someone through a Wyze Cam Floodlight v2.
Two-way talk + loud siren.
Respond to visitors and familiars by tapping on the mic icon in the Wyze app. Still not getting the message? Sound the 105dB siren for extra deterrence.
A green circle with the text "270 PIR Motion Detection Zone" in white.
Bye bye, blind spots!
Eliminate blind spots and trigger lights faster than ever with a 270° PIR motion detection area.
