1 of 7
Ultimate smart home front porch security.
Style
$173.97
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Compatible With
Compatible With
Meet the ultimate smart home front porch security bundle. With Wyze Video Doorbell and Chime, view your front porch in 1080p HD and say hello with two-way audio. With Wyze Lock, unlock and lock the door remotely and view your lock history in the Wyze app.
  • A black background with a video camera icon.
    View your porch in 1080p HD
  • A smartphone with a lock icon on it.
    Lock/unlock the front door remotely
  • Motion sensoring for learning.
    View motion events and lock history
  • Voice assistant icon.
    Works with Alexa and Google Assistant
Wyze Video Doorbell
  • Power: 16V-24V AC, ≥10VA (May use existing doorbell-chime circuit, or standalone transformer and wires.)
  • Weight: 1.7oz / 49gSize: 1.5'' x 3.25'' x 0.625''
  • Image Sensor: 2K (2048 x 1536)
  • Camera: F2.0 aperture, 2.7mm focal length, 1/2.8" CMOS
  • Image Quality: 1080p and 480p w/ 8x Digital Zoom
  • Frames per Second: 20 Daytime, 15 Nighttime
  • Audio: Built in Speaker & Microphone (with 2-way Audio & Noise/Echo Cancellation)
  • White LED (Fill Light): 6 x 5000K (daylight color temperature)
  • IR Night Light: 4 x 940nm Infrared LED
  • Connectivity: Direct to WiFi 802.11 b/g/n, 2.4GHz (5GHz WiFi not supported)
  • Sub1G: 906.8MHz, used for local connection between doorbell and chime.
  • IP65 Weather-resistant
  • Storage Temperature: -40 to 176°F (-40 to 80°C)
  • Operating Temperature: -4 to 122°F (-20 to 50°C)
  • Field of View: 120° Vertical x 88° Horizontal
  • Operating Systems: iOS 9.0 and Android 5.0 or later
  • Data Security: End-to-end encryption, HTTPS secure transfer protocol, AES 128-bit encryption
Wyze Chime
  • Chime Power: Standard US Power Outlet: 100V-240V, 0.1A, 50/60Hz
  • Weight: 2.0 oz / 56g
  • Size: 2'' x 2'' x 1.4''
  • Chimes: 5 modern, 4 classic doorbell, 3 animal sounds, 6 automation sounds, 1 intruder alarm
Lock
  • Color: Silver
  • Dimensions: 4.9" Length x 2.5" Width x 1.3" Depth (2" including knob)
  • Weight: 0.67 lb
  • Power Source: 4x AA Batteries (included)
  • Battery Life: 5-6 months (depending on usage)
  • Communication Method: Bluetooth, Zigbee
  • Range: To Keypad: 9', To Gateway: 50', BLE to phone: 16'
  • Compatibility: Android 5.0+, iOS 9.0+
  • Weather Resistance: Indoor only
  • Operating Temperature: 14°F - 131°F / -10°C - 55°C
  • Storage Temperature: -22°F - 158°F / -30°C - 70°C
Keypad (sold separately)
  • Color: Silver
  • Dimensions: 3.7" Length x 1.3" Width x 1.0" Depth
  • Weight: 0.1 lb
  • Power Source: 2x AA Batteries (included)
  • Battery Life: 4-6 months (depending on temperature)
  • Range: To Lock: 9'
  • Weather Resistance: IPX5
  • Operating Temperature: -4°F - 140°F / -20°C - 60°C
Gateway
  • Color: White
  • Dimensions: 2.1" Length x 2.1" Width x 1.2" Depth (1.9" including pins)
  • Weight: 0.12 lb
  • Power Source: 110-240V, ~60Hz
  • Battery Life: NA
  • Communication Method: Bluetooth, Zigbee, Wifi
  • Range: To Lock: 50', To Router: 50
Wyze Lock
  • Wyze Lock x1
  • Wyze Lock Gateway x1
  • AA Batteries x4
  • Adhesive Strip x1
  • Mounting Plate x1
  • Adapter x3
  • Quick Start Guide x1
Wyze Video Doorbell + Chime
  • Wyze Video Doorbell x1
  • Wyze Chime x1
  • Wall Plate x1
  • Wedge (Horizontal, 30°) x1
  • Wire Caps x4
  • Bracket Screws x2
  • Screws & Expansion Tubes x2
  • Extension Wires x2
  • Fuse x1
A cell phone with a picture of a doorbell on it.
Did you know?
You can lock/unlock the door right from the Wyze Video Doorbell (or Video Doorbell Pro) viewer. Watch the video to see how simple it is.
