1 of 5
Wyze Floodlight Security Bundle
Get total yard coverage with two powerful Wyze Floodlights
Floodlight Pro (Color)
Floodlight v2 (Color)
$209.96 $239.96
Low stock: 52 left
With this much lumen power, you'll dominate the dark, and spot the bad guys, with ease.
    2K HD Resolution & Color Night Vision
    Capture more details.
  • A black image with a wide angle lens.
    Wide Field Of View
    Eliminate blind spots. 160° FOV with Floodlight v2 and 180° FOV with Floodlight Pro.
  • A sun icon with a black background.
    Super-Bright LEDs
    Dimmable & adjustable. Get complete control with the Wyze app.
  • A black screen with a message about syncing a microSD card.
    24/7 Recording with MicroSD Card
    MicroSD card sold separately. Add AI alerts and cloud backup with Cam Plus.
Wyze Cam Floodlight Pro
  • Color: White or Black
  • Finish: Matte
  • Mount: Wall/Ceiling
  • Hardwired 110 - 120V AC
  • 2.5K QHD (2560*1440) with Color Night Vision
  • 180° Diagonal, 170° Horizontal, 95° Vertical
  • Frame Rate: Daytime: 20 FPS, Nighttime: 15 FPS
  • Up to 256 GB microSD card (Format: exFAT, FAT32)
  • -4°F - 140°F (-20°C - 60°C)
  • IP65 Water Resistance
Learn more
Wyze Cam Floodlight v2
  • Finish: Matte
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • 2 dimmable LED light panels
  • 2800 total lumens of brightness
  • 5000K color temperature
  • Dimmable: Yes
  • 2K (2304 x 1296)
  • Night Vision
  • Color Night Vision
  • Safe for outdoor use
Learn more
Connectivity & Compatibility
  • IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
  • Warranty: 1 Year
  • x1 - Wyze Cam Floodlight Pro
  • x1 - Bracket Screws
  • x1 - Mounting Bracket
  • x1 - Ground Wire Screw
  • x1 - Floodlight Screw
  • x1 - Rubber Stopper
  • x1 - Wire Nuts
  • x1 - Hook
  • x1 - Screwdriver
  • x1 - Quick Start Guide
  • x1 - Wyze Cam Floodlight v2
  • x1 - Mounting Accessory Kit
  • x2 -Bracket Screws (#6, #8, and #10)
  • x1 - Ground Screw
  • x2 - Wire Nuts
  • x1 - Hook x
A bright light on a house.
Wyze Floodlight Pro
Professional yard security to brighten any space.
A pro floodlight category-leading 180° field-of-view means you can protect your property with fewer blind spots.
It offers 2K HD resolution for clear color night vision. With three adjustable light panels, its 3000-lumen LEDs deter intruders and reveal details even in the dark.
Connect with dual-band (2.4 and 5.0 GHz) Wi-Fi compatibility.
A black security camera with two floodlights attached, mounted to a wall.
Wyze Floodlight v2
The dark doesn't stand a chance.
Delivering 2K HD video and vibrant color night vision, this outdoor security camera ensures your home always under watch.
The expansive 160° wide-angle view and advanced motion detection eliminate blind spots.
Enjoy a well-lit exterior with powerful 2800-Lumen LEDs, and let the 105dB siren add an extra layer of security.
  • A black and white image of a clock with a small arrow pointing upwards.
    24/7 local recording
    Record 24/7 locally with a microSD card up to 256 GB (sold separately). Add AI alerts and cloud backup with Cam Plus.
  • Motion sensoring for learning.
    Bye bye, blind spots!
    Eliminate blind spots and trigger lights faster than ever with wider FOVs, PIR, and AI technology.
  • A black screen with a white sun icon.
    Dusk-to-dawn automation
    Wyze floodlights know when the sun goes down and when it comes back up. No need to turn it on and off manually.
  • Weather resistant icon.
    IP65 weatherproof
    Rated to withstand any weather. Around the clock coverage all year long.
    Ambient Light Mode
    Enable constant ambient lighting that automatically switches to increased brightness when motion is detected.
    Motion-Activated Voice Deterrence
    A voice prompt that plays when a person is detected. Feature included with Wyze Floodlight Pro for all users.
1 of 6
A person is standing in front of a car.
One powerful Wyze app
Control both smart floodlight cameras from the palm of your hand and get total peace of mind.
  • 24/7 Live Streaming
  • Access local recordings*
  • Setup detection zones
  • Available for Android & iOS
*Local recording requires the addition of MicroSD card
Enjoy crystal-clear 2K resolution.
Immaculate 2K image quality means you can capture events in more detail than ever, especially at night. Because we all know the devil is in the details. Or maybe it was just Brad, the hypersensitive HOA president.
A man standing in front of a white car.
A man standing next to a white car.
A man carrying a box in front of a house at night.
Add a Wyze Security Plan
Get better AI detections with Cam Plus
Instead of vague motion detections, you can now get phone alerts for Person and Package Detection with Cam Plus. Also enjoy unlimited 14-day cloud video storage and additional functionality.
A tablet displaying a live video feed from a security camera mounted outside.
A smart speaker on a table.
Add fingerprint
Add fingerprint
Wyze Cam Floodlight v2 PDP Artboard 12.
Wyze Cam Floodlight v2 PDP 12
Super simple setup.
Both Wyze Floodlight Cameras are great devices to securing the outside of your home.
Use your Amazon Echo, Alexa, and Google Home devices to view live feeds of floodlight cam. Even get smart alerts when a person is detected, with Cam Plus.
Access Point Wi-Fi setup lets you pair Wyze Cam Floodlight v2 with
the Wyze app without climbing a ladder to scan a QR code.
