Skip to content
1 of 4
Wyze Cam v4 Outdoor Bundle
The clearest Wyze Cam ever made.
What's in this bundle
Wyze Cam v4 (Color)
SALE
$69.99 $72.96SAVE 4%
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Get unmatched security with Wyze Cam v4. Crystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, and motion-activated spotlight keep your home safe day or night. Plus, 24/7 local recording, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant for ultimate convenience.
  • 2.5K QHD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • weather icon
    Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
  • spotlight icon
    Motion-Activated Spotlight
    Automatically trigger the LED light and voice prompt for extra security.
  • Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v4 Specs
  • Colors: White and Grey and Black
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue.
  • Dimensions: 2in x 2in x 2 3/8in
  • Weight: 0.49 lb (222 g)
  • Mounting: Stand, wall mount, ceiling mount, or magnetic wall mount (adhesive)
  • Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
  • Cable: 6-Foot Flat micro USB to USB-A
  • Resolution: 2.5K QHD (2560x1440)
  • Digital Zoom: 8x
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision/Color Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Learn more
Wyze Outdoor Power Adapter
  • Color: White
  • Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
  • Weight: 235 g
  • Total cable length: 12.5 ft (3.8 m)
  • AC cable length: 3.9 ft (1.2 m)
  • DC cable length 8.5 ft (2.6 m)
Compatibility:
  • Outdoor Power Adapter works with Wyze Cam v3/Cam v4 and Cam OG series.
  • Outdoor Power Adapter + L-shaped Adapter works with Wyze Cam Pan v3/Cam v3 Pro.
  • Outdoor Power Adapter + L-shaped USB-C Adapter works with Battery Cam Pro.
Weather Resistance: IP67
Certification: FCC, UL
Warranty: 1-Year
Wyze MicroSD Card (128GB)
  • Class 10 and UHS-3 (U3)
  • Media Storage (128GB): ~11,520 minutes (192 hours) of HD video(5), ~40,320 minutes (672 hours) of SD video(6), and ~16,800 16MP photos(7)
  • Read Speed: 31MB/s8
  • Write Speed: 12MB/s9
  • 1x Wyze Cam v4
  • 1x Wyze Outdoor Power Adapter
  • 1x MicroSD Card 128gb
The best just got
Wyze Cam v4 with WDR
No WDR
Even more features to love.
Wyze Outdoor Power Adapter WYZECV3OA - Wyze Labs, Inc.
Your Cam is Compatible With The Outdoors!
You're ready for rain, snow, or shine. because your camera comes with an adapter made for the outdoors. The Wyze Outdoor Power Adapter + L-shaped MicroUSB is designed to work with Wyze Cam Pan v4.
Record continuously.
See what happened from start to finish with local recording. Built-in microSD card slot allows for continuous event capture and 24/7 monitoring.
Learn More
