1 of 6
Cam v4 + Lamp Socket v2 Bundle
Make your exterior lighting smart while powering a Cam v4.
Device Compatibility: Lamp Socket v2 works with Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, and Cam Pan v3.
Wyze Cam v4 (Color)
Make your exterior lighting even smarter with this power duo. With our latest lamp socket, you can now power Cam v4 without the need for an outlet.
Flexible power for your Wyze Cams, now including Pan v3.
Skip the wiring and electrocution (unless you're into that sort of thing). Harness the electricity from your outdoor light fixture to continuously power your Wyze Cam v3/v3 Pro/v4, Wyze Cam OG, and Wyze Cam Pan v3. No long, ugly wires. No hassle.
Upgrade to smart lighting in seconds.
Wyze Lamp Socket v2 and compatible Wyze Cams work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains! Control your lights from anywhere in the Wyze app.
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever your compatible Wyze Cam detects motion. Now your old light fixture is a cutting-edge model of sleek security sophistication!
Smart home security camera and light bulb in fixture on a wall
Easily link multiple sockets for greater coverage and control.
Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting. Then schedule and control your smart setup from anywhere using the Wyze app.
Dusk to Dawn automation.
As easy as screwing in a lightbulb.
Some installations are as easy as screwing in a lightbulb. Other installations are literally the exact same as screwing in a lightbulb. Wyze Lamp Socket v2 falls in the latter category.
This video is for our Lamp Socket v1, but the installation process is still just as easy.
Note: Due to thermal limitations, incandescent bulbs cannot by used with this lamp socket. We recommend using a CFL or LED bulb under 20W, like Wyze Bulb White.
