1 of 6
Bird Feeder Wireless Camera Bundle
Birdwatching on easy mode. Comes with everything you need to get started right away.
Wyze Battery Cam Pro (Color)
Wyze Bird Feeder (Color)
$118.98 $164.94
Low stock: 2 left
Use a 5-digit ZIP code.
NEW Bird Detection
Great news for Wyze Battery Cam Pro owners. Bird Detection is now available with Wyze Security Plans. Test it with a Cam Plus trial.
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Bundle comes with Wyze Bird Feeder, Wyze Battery Cam Pro, and Wyze Solar Panel. It's birdwatching on easy mode. View and record live video of every feathered visitor with Wyze Bird Feeder. The feeder's vibrant blue body and orange top is designed to attract a variety of birds. Use your favorite top-selling Wyze Camera to explore the world around you like never before. A must-have for the birder in all of us!
  • An icon for the IP65 page.
    Weather-Resistant Polycarbonate
    Constructed for resilience against outdoor elements.
  • A black background with a white logo for a wireless device.
    Wire-Free Bundle. No Hub.
    Place it anywhere with hassle free Battery Cam Pro setup.
    Includes Macro Lens Adapter
    Macro magic. Switch the focus from distant sights to close-up bird watching.
  • A black screen with a white icon.
    Watch Live in the Wyze app
    Stream live video on your phone without any fees.
Wyze Bird Feeder
  • Color: Blue and Orange
  • Material: Polycarbonate
  • Dimensions: 7.48 in x 10.12 in x 8.58 in (190mm*257mm*218mm)
  • Net Weight: 2.5 lb (1.13 kg)
  • Gross Weight: 3.42 lb (1.55 kg)
  • Bird Seed Capacity: 1 Liter
  • Weather Resistance: IP65 Weatherproof
  • Operating Temperature: -4°F to 122°F (-20°C to 50°C), Humidity < 90%
  • Warranty: 1 year
NEW! Bird Detection.
  • Color: White or Black
  • Camera Lens: Optical glass
  • Camera Weight (lbs): 0.94
  • Dimensions: 2.5" x 1.8" x 3.5"
  • CPU Speed: 500 MHz
  • Memory: 128 MB RAM
  • Mounting Methods: 1/4” - 20 standard
  • Wall mount: Included (short mount)
  • Wall Mount Dimensions: 2" x 2" x 2.2"
    Wall Mount Weight: 1.5oz (44g)
  • Video Resolution: 2560 x 1440 (2.5K)
  • Connector: USB-C
  • Certifications: FCC, IC
  • Wi-Fi: 2.4 GHz and 5 GHz, 802.11a/n/g/b
  • Weather Resistance: Indoor & Outdoor (IP65)
  • Warranty: 1 year
Learn more
Wyze Solar Panel
  • Color: White frame and mount
  • Black solar cells
  • Dimensions: 173 mm x 120 mm x 17 mm
  • Solar power rating: 2.5W, 5VDC
  • Micro USB cable length: 13 ft (4m)
Wyze Bird Feeder
  • Wyze Bird Feeder x 1
  • Food Tray x 1
  • Food Tray Stand x 1
  • Solar Panel Cover x 1
  • Camera Bracket x 1
  • Lens Bracket x 1
  • L-Shaped Bracket x 1
  • Suction Cup Bracket x 1
  • Pillar Connecting Piece x 1
  • Cable Tie x 1
  • Suction Cup x 2
  • Safety Cord x 1
  • Mounting Cord x 1
  • Screw Accessory Pack x 1
  • Screwdriver x 1
  • Quick Start Guide x 1
Wyze Bird Feeder is compatible with Wyze Battery Cam Pro (this is the camera included in this bundle), Wyze Cam Outdoor v1/v2, and Wyze Cam v3/v3 Pro/v4. If using a Wyze Cam that is not battery-powered, you'll need a Wyze Outdoor Power Adapter to plug it into power.
Wyze Bird Feeder was designed specifically for select Wyze Cams - from the housing to the lens bracket.
Yes, it works with Wyze Solar Panel! Which is also included in this bundle. You can use a Wyze Solar Panel with a Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2 to minimize taking down the camera to recharge it. Truly hassle-free.
While you can view and manage the camera installed in the bird feeder from the Wyze app, Wyze Bird Feeder itself is not a connected or an IoT device. We say it's the smartest way to bird watch.
After much research and consultation, we’ve concluded that any attempt to prevent squirrels from visiting would be futile. Instead, we focused on making sure that the materials used will be able to withstand significant damage, which should prevent the squirrels from destroying the feeder itself. Right now, our priorities lie in making sure that no harm could come to our feathered friends.
It has a sloped food tray that slowly dispenses the bird feed. Yay gravity!
Wyze Bird Feeder
Birding on easy mode.
A screenshot of a computer screen with a video playing.
A person holding a cell phone with a picture of a bird on it.
A blue and red bird feeder with a camera inside.
Weather-resistant for all seasons.
Birds of every feather will flock your way, no matter the weather. Come rain or shine, the durable polycarbonate design of Wyze Bird Feeder serves as a safe haven for wild birds to hang out and grab a bite.
A bird feeder with a blue base and an orange top.
Easy install with many mounting options.
Choose between 5 easy installation options—wall, tree, pole, cord, and suction cup. Place it anywhere you (or they) need it.
  • A small bird is sitting on a bird feeder, looking at a camera.
    Compatible with Battery Cam Pro for remote birdwatching.
    Wyze Bird Feeder supports Battery Cam Pro for a wireless set-up on trees, walls, poles, and more.
  • A white circle with a black border.
    Macro Lens Adapter included.
    It's like a monocle, but for your Wyze Cam. This special lens slips over compatible cameras correcting the focus to ensure you get clear up-close views of bird friends.
  • A solar panel on a white pole.
    Designed with Wyze Solar Panel in mind.
    There’s a designated space for a Wyze Solar Panel to minimize recharging with Battery Cam Pro.
  • A man holding a camera with a picture of a camera on it.
    Live stream video and get notifications with the Wyze app.
    View, record, and get notified about every visitor with the Wyze app.
1 of 4
    Wyze Cam v3
    From $32.98
    Shop now
  • Wyze Cam v4
    From $35.98
    Shop now
  • A black and white camera with a white base.
    Wyze Cam Outdoor v1
    See our latest wireless cam, Wyze Battery Cam Pro.
  • A black camera with a white base.
    Wyze Cam Outdoor v2
1 of 4
  • A red bird perched on a blue perch.
  • A bird perched on a blue object.
  • A small brown bird sitting on a blue tray.
  • A blue jay perched on a blue bird feeder.
1 of 4
Send videos and images of bird friends to wow@wyze.com! We'd love to share them.
⚠️ WARNING: THE ELUSIVE "FUR BIRD" ⚠️
Disclaimer: While our bird feeder is top-notch, it unfortunately doesn’t include a squirrel defense system. These tiny furry ninjas who’ve mastered the art of stealth and parkour will likely visit. So, sit back, relax, and enjoy the inevitable squirrel circus. You’ve been warned, friend.
A cartoon of a squirrel with a sign that says "will launch self as ninja.
