1 of 10
Apartment Basics Kit
Best Value
The Most for Your Money
$89.99 $110.96
Use a 5-digit ZIP code.
1080p HD logo
1536x1536 HD+
Video Resolution
IP65 rating
IP65 Weather Resistant
Battery-powered or Hardwired
Two Way Audio device.
2 Way Audio
Perfect for renters, the Apartment Basics Kit gives you easy home security without drilling, wiring, or permanent installation. Both devices are fully battery-powered, making setup simple and landlord-friendly.
Wyze Battery Video Doorbell lets you see and talk to visitors with a wide head-to-toe view, smart motion alerts, and long-lasting battery life—no hardwiring required.
Wyze Cam Pan v3 adds smooth 360° coverage indoors, tracking movement across your space without mounting holes or complicated setup.
Together, they create a flexible, no-damage security solution ideal for apartments, condos, and temporary living spaces.
  • A white Wyze Cam Pan v3 is shown in a black background.
    Wyze Pan Cam v3
    Wyze Cam Pan v3 delivers smooth 360° pan and 180° tilt with weather-resistant design, smart motion tracking, and clear HD video—giving you whole-room or outdoor coverage with easy, flexible placement.
  • Wyze Battery Video Doorbell - Black / No Chime - Head-to-Toe Viewing 1536 x 1536 HD+ Resolution Wire-Free or Wired Up to.
    Wyze Battery Video Doorbell gives you a wide head-to-toe view of visitors with sharp video, two-way audio, and smart motion alerts—all in a wire-free, renter-friendly design that installs anywhere.
  • A black air purifier with a blue light on top.
    Wyze Air Purifier
    Wyze Air Purifier uses a powerful HEPA-grade filter to capture allergens, dust, pollen, smoke, and pet dander. With smart monitoring and quiet operation, it keeps your home’s air clean and comfortable.
  • A black microSD card with the Wyze logo on it.
    Wyze MicroSD Card (128GB)
    The Wyze 128GB MicroSD Card provides fast, reliable storage for continuous recording, time-lapse videos, and smooth playback—perfect for 24/7 monitoring with any compatible Wyze camera.
Instant visibility at your door with Battery Video Doorbell.
See every visitor and every delivery the moment they arrive. No wiring, no drilling. Battery-powered security for simple installation without submitting a maintenance request.
A person holding a smart device that is attached to a door.
A man wearing a grey hoodie and a yellow backpack is standing in front of a door.
Peace of mind without a peephole.
See more of what matters. With a 150° horizontal and 150° vertical field of view, Wyze Doorbell captures everything.
Keep an eye on packages, food delivery drop-offs, or your neighbor across the hall, all without blind spots. Even if someone stands close to the camera, you’ll still see the full picture — from head to toe.
A black device with a blue light on it.
No existing chime needed.
Apartment didn't come with a doorbell? No wiring needed when you pair with a Wyze Universal Wi-Fi Chime (sold separately) to hear alerts anywhere in your apartment, even through your Wyze Cams.
Shop Chime
Pan v3 sees the whole room with 360° pan/ 180° tilt.
Cover the whole space with one device. Pan/ tilt to see the living room, kitchen, and entryway. Get alerts for movement or noise.
A chair with a pillow on it is on a balcony.
A cat is laying on a bed in a small wooden box.
Keep an eye on motion.
Pan v3 detects motion and automatically follows it. Easily pan around to monitor pets or check in on maintenance while you’re away.
FREE shipping on orders $0+
