1 de 4
Détecteur de mouvement Wyze Sense
Détecte les mouvements.
Taille
Extensions
$24.98
En stock
Recevez-le dès
Garantie prolongée de 18 mois
Détecte les mouvements. Nécessite Wyze Sense v2 ou Wyze Home Monitoring.
Voir les détails complets
No, this functionality is not available at this time. To use Wyze Sense v2 accessories, please purchase and connect them to a Wyze Sense Hub via the Wyze Home Monitoring Core Starter Kit.
No. Wyze Sense Entry and Motion Sensors and Keypads are for indoor use only.
Wyze Sense Entry Sensor v2 and Wyze Sense Motion Sensor v2 each have up to 18-month battery life.
No, glass will interfere with the functionality of the PIR sensor.
No, the adhesive is designed to be permanent.
No, all sensors and keypad will require a Wyze Sense Hub to pair with.
The Wyze Sense Hub can connect to sensors up to 500 feet away in an unobstructed room. Please note that walls and interference in your home may cause the range to vary.
Wyze Sense Motion Sensor v2 can detect movement within a 120 degree field of vision within 25 feet.
Up to 100 sensors & keypads.
