1 de 7
Aspiradora inalámbrica Wyze (reacondicionada) (primera generación)
La potencia adecuada para cada superficie.
$49.99 $99.99
Agotado
Este producto no es elegible para devoluciones.
Garantía extendida de 12 meses
Obtenga una garantía extendida de 12 meses al comprar productos reacondicionados en wyze.com. También obtenga paquetes especiales, promociones únicas y recompensas con cada pedido
Ver todos los detalles
  • A black and white icon of a vacuum cleaner.
    Potencia de succión de 150 AW / 24.000 Pa
    Ligero, 2,8 libras
  • A black and white icon of a battery with a lightning bolt in the middle.
    Batería de iones de litio intercambiable de 50 minutos
  • A black and white icon of a computer mouse.
    Pantalla LED
1. Remove the vacuum from the packaging.
2. Fully charge the vacuum using the included charger. The LED screen will show 100% when fully charged. Unplug the vacuum from power.
3. To turn on the vacuum and operate in Medium Mode (default), press the Power button and begin cleaning. For change the suction, tap the Mode Shift button on the LED screen to switch to Turbo Mode or Eco Mode.
4. To turn off the vacuum, press the Power button again.
The cordless vacuum performs best when used indoors, on dry surfaces, bare floors, and carpets with short and firm textures. It is not recommended to use Wyze Cordless Vacuum on thick or plush carpets. You can switch to handheld use by attaching the accessories after removing the floor brush and aluminum tube.
Use attachments to clean areas like your sofa, bed, ceiling, and stairs.
Note: The cordless vacuum only comes with a Crevice Tool and the 2-in-1 Brush tool. You can purchase additional attachments at Wyze.com.
The capacity of the dust cup is 0.7 L.
The volume is about <80 dBA in Turbo Mode, the strongest mode.
Use the 2-in-1 Brush tool when a softer touch is required.
Use the mini-motorized brush for a deeper clean to remove dust particles and mites in bedding, carpeted stairs, and more.
Use the extension hose when you need more flexibility when cleaning.
Use the crevice tool to pick up crumbs and dirt in corners, nook, and hard-to-reach areas.
Yes, Wyze Cordless Vacuum works great to remove pet hair from all dry surfaces.
No, only use Wyze Cordless Vacuum on dry surfaces to pick up dry debris. Do not use it on wet surfaces or to pick up liquids.
Liquids, including water and oil.
Chemicals, inflammable and explosive hazardous materials.
Sharp objects such as broken glass, construction waste, screws, etc.
Burning objects such as cigarette butts, matches, and ash.
Pet waste.
Yes, and you can buy it here: wyze.com
Remove the dust cup from the Main Unit, pull out the HEPA filter, and rinse the filter and dust cup with fresh water. Let all parts air dry completely. Do not expose the filters to direct sunlight or high temperatures.
More detailed maintenance instructions are available in the Quick Start Guide.
Use the included Wall Mount to store your Wyze Cordless Vacuum. It can be used to hold the main unit, crevice tool, and 2-in-1 dust brush. Yes, it does need to be installed near a power outlet for charging.
No, it cannot stand up on its own. Please use the included wall mount for storage.
Cuando se trata de potencia de succión, los motores son lo más importante
Los motores económicos ofrecen resultados más económicos. Nos hemos esforzado al máximo con un potente motor digital que alcanza un nivel de succión industrial. Nuestro eficiente diseño sin escobillas reduce significativamente la fricción para mantener la máxima potencia, una alta durabilidad y una mayor duración de la batería.
A close up of a cordless vacuum with a blue light.
No sólo un motor. DOS motores.
Agregamos otro motor con 9,500 RPM de potencia en el cabezal del cepillo porque nos tomamos tan en serio la limpieza como usted lo hace recoger cada hebra de la majestuosa melena de Fido.
A black vacuum cleaner with blue lights on a wooden table.
Esta aspiradora de mano es tan ligera como 2,8 libras de plumas.
Toda esa tecnología de limpieza avanzada en un paquete tan ligero. De hecho, pesa menos que un cachorro de corgi peludo. ¡Awww!
Close up image of cordless vacuum battery screen.
Diferentes superficies requieren distintos niveles de succión. Seleccione entre 3 velocidades de limpieza diferentes. Controle la velocidad y el uso con una pantalla LED de gran nitidez.
Eco 7.000 Pa
Med 15.000 Pa
Turbo 24.000 Pa
A close up of a cordless vacuum battery.
Baterías intercambiables de larga duración
Termina lo que empezaste. Disfruta de hasta 50 minutos de energía sin interrupciones hasta que termines el trabajo. Agrega una batería adicional para un total de 100 minutos de trabajo.*
*Hay paquetes de baterías adicionales disponibles a través de mercados de terceros o en wyze.com .
Estés preparado o no, el polvo no puede ocultarse.
Las pelusas han estado viviendo en la sombra durante demasiado tiempo. Vea más con 6 luces LED de luz diurna en el cabezal del cepillo para iluminar el polvo y los residuos debajo de los muebles.
A vacuum cleaner with green lights on. A cordless vacuum with green LED lights on the bottom.
Con LED
Sin LED
Hay una herramienta para eso
¿Migas en el sofá? Tenemos una herramienta para rincones. ¿Polvo en el marco de la puerta? Tenemos un cepillo. Nuestra gama de accesorios te ayuda a limpiar cualquier tipo de suciedad.
Two women cleaning a living room with a Wyze cordless vacuum.
A cordless vacuum with a 3-stage filtration system.
Sistema de filtración de 3 etapas
Primero, el ciclón de vacío separa los residuos de diferentes tamaños. A continuación, una malla metálica filtra partículas grandes como suciedad y cabello. Finalmente, un filtro HEPA de alta eficiencia elimina el 95 % de las partículas de <0,3 µm de diámetro.
A person is using a vacuum to clean a counter.
A black and green vacuum cleaner with a long handle.
A person is holding a green and blue filter in a kitchen sink.
A close up of a vacuum cleaner with a filter brush.
Más para amar
Utilice un dedo para liberar y vaciar el depósito de polvo.
El depósito de polvo y los filtros son fáciles de quitar, enjuagar y reutilizar.
Gire el cepillo de filtro incorporado para sacar el polvo del filtro al depósito de polvo y mantener la máxima eficiencia.
