Skip to content
1 of 6
Wyze Plug Outdoor
Wyze Plug Outdoor
Weatherproof Smart Outlet with WiFi Controls
Wyze Plug Outdoor (Quantity)
$29.98
Power up the outdoors, rain or shine, with an outdoor smart plug – because even your garden lights deserve a tech-savvy friend. From festive holiday inflatables to backyard soirées, take full control with the ease of an app. Monitor usage, set schedules – and just like that, your outdoor space just got a whole lot easier to manage, all thanks to you.
outdoor plug in app
Monitor USAGE
Consume less energy and more cold brew
Energy Monitoring. Set energy consumption alerts and see historical energy usage in the Wyze app.
Overhead view of a large home with circle overlays surrounding the house.
Large WiFI Range
Long-range WiFi lets you plug in nearly anywhere
Up to 300’ WiFi Range. Confidently control outlets around your home with Wyze Plug Outdoor’s extended WiFi range (300 ft. in open space).
IP64 Weather Resistant. Made for the outdoors.
Safely plug into areas that are exposed to rain, dust, dirt, and snow.
A wet outdoor plug that is plugged in
Close up of outdoor plug with both outlets being used.
2 Outlets, 2 Separate Controls
Independent control of both outlets at any given time
Two Outlets in One. Turn off your outdoor lights but leave your inflatable snowman standing strong.
Hand holding a smartphone with the Wyze app open
VOICE COMMANDS WITH ALEXA
Turn your lights off without putting your boots on.
App & Voice Control. Light up your block in seconds by asking your voice assistant or pulling up the Wyze app on your phone.
  • icon bulbs
    Outdoor Lighting
  • icon snowflake
    Roof De-icers
  • sink icon
    Pond Pump
1 of 3
Safely power melters, and more this winter
15 AMP Output with Overload Protection. Wyze Plug Outdoor offers one of the highest output ratings available for a smart plug, allowing for more ways to use it.
outdoor plug
outdoor plug
ß
