1 of 4
Wyze Air Filter Subscription
Type
$37.99
Replacement filters for Wyze Air Purifier.
Allergen Filter
  • Dimensions: 8.1" x 8.1" x 11.3" / 205 mm x 205 mm x 286 mm
  • Weight: 1.5 lb / 0.6 kg
  • Pre-filter + True HEPA 13 + Activated Carbon
  • TVOC Removal Efficiency: 92.7%
  • Particulate Matter CADR: 362 m3/h / 214 CFM
  • 99% efficiency for representative viruses and bacteria
  • Service Life: 6–12 months (The Wyze app will let you know when it is time to change.)
Formaldehyde Filter
  • Weight: 1.7 lb / 0.77 kg
  • Pre-filter + True HEPA 12 + MnO2 + Activated Carbon
  • TVOC Removal Efficiency: 98.9%
  • Particulate Matter CADR: 317 m3/h / 186 CFM
  • Formaldehyde (HCHO) CADR: 178 m3/h
  • Service Life: 5–12 months (The Wyze app will let you know when it is time to change.)
Wildfire Filter
  • Weight: 1.9 lb / 0.87 kg
  • Pre-filter + True HEPA 12 + Activated Carbon
  • TVOC Removal Efficiency: 97.1%
  • Hydrogen Sulfide (H2S) Removal Efficiency: 98.9%
  • Particulate Matter CADR: 342 m3/h / 186 CFM
  • Service Life: 4–12 months (The Wyze app will let you know when it is time to change.)
Allergen Filter
  • Allergen Filter x1
Formaldehyde Filter
  • Formaldehyde Filter x1
Wildfire Filter
  • Wildfire Filter x1
Allergen filter pollutants
Allergen Filter
The Allergen Filter is an all-purpose filter for everyone:
Pre-Filter + HEPA 13 + Granulated Carbon
A filter for pollutants, including formaldehyde, dust, germs, and mold.
Formaldehyde Filter
This premium filter not only captures pollutants, it destroys heavy odors and dangerous chemicals:
Pre-Filter + True HEPA 12 + Granulated Carbon with Activated Manganese
A blue container with a filter for pollutants.
Wildfire Filter
This specialty filter captures basic pollutants with maximized fire pollution absorption:
Pre-Filter + True HEPA 12 + Chemically Modified Granulated Carbon
What is formaldehyde?
It's not just for science classes!
Formaldehyde is found in tobacco smoke, new furniture, and construction materials from carpet to lumber. Over time, it is considered carcinogenic.
Formaldehyde is only one of several VOCs (gases that can damage your health), but particularly difficult to capture. A filter that can catch and destroy formaldehyde is considered a premium-grade filter.
Twist. Remove. Replace.
Filter replacement in just 3 easy steps.
Out with the old, in with the new, and you're back up and running with clean, purified air.
FREE shipping on orders $0+
