Skip to content
1 of 7
Wyze Cam Pan v3
Wyze Cam Pan v3
360° 1080p Cam with Night Vision
IP65 Weather Resistant
Pan and Tilt
Ai Motion Capture
Privacy Mode
Color
Pack
$39.98
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Wyze Cam Pan v3 is a redesigned indoor/outdoor, 360° pan and 180° tilt security camera, and is fully IP65 weather resistant.
*For safe outdoor use, Pan v3 requires a Wyze Outdoor Power Adapter (sold separately).
  • Indoor/Outdoor IP65 Weatherproof
  • Remotely Spins 360°/Tilts 180°
  • Automatic Motion-Tracking
  • Privacy Mode
Wyze Cam Pan v3 Specs
Color & Materials
  • Color: White
  • Finish: Matte
  • Body: Polycarbonate
  • Lens: Glass + plastic
  • CPU: 1.5 GHz
  • Image Sensor: 1/2.9'' CMOS
  • LED indicator: Front. Red + Blue
  • Night Vision: 4 IR LEDs (850 nm)
Dimensions & Weight
  • 124mm (H) x 60mm (W) x 63mm (D)
  • 11.29 oz (320 g)
Video
  • Video Encoding: H.264
  • Video FPS: Daytime - 20 fps; Nighttime - 15 fps
View Range
  • 360° horizontal, 180° vertical
Field-of-view
  • 120° FOV
Additional Details
  • Digital Zoom: 8x
  • Mount: Screw 1/4" - 20
  • Circular Base: Diameter 1.69" (43mm)
  • Ports: 1 micro USB
  • Memory: 128 Mb
  • Rotation Speed: Up to 110° per second
  • Audio: Built-in speaker and microphone; 2-way audio; Noise & Echo cancellation
  • Alerts: Push notifications
  • Night Vision and Color Night Vision
Power
  • Power Cable Length: 6" (1.8 m)
  • Power Adapter Input: 110-240V (AC/DC)
  • Power Adapter Output: 5V/2000mA
Connectivity & Compatibility
  • 802.11 b/g/n, 2.4GHz (5GHz Wi-Fi not supported)
  • Upload speed 1.0 Mbps for SD, 1.5 Mbps for HD
Storage
  • Supports up to 256 GB microSD in ExFAT format
Weather & Temperature
  • Operating temp: -20°C - 50°C (-4°F - 122°F)
  • IP65 Water Resistance
Certifications
  • FCC, IC, UL, TSCA, IP65
Language
  • English
Warranty
  • 1-Year
Important note
  • Wyze Cam Pan v3 comes with one of two versions of the Mounting Kit, as shown here. The Mounting Kit pictured on the product packaging is currently of the original design but the package could contain the new design. Both mounts allow you to install the Pan v3 upside down.
  • Wyze Cam Pan v3
  • 6' micro USB Cable
  • Power Adapter
  • Mounting Kit (Please note: There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality. Learn more here.)
  • Quick Start Guide
Wyze Cam Pan v3 has an entirely new, innovative design that doubles the total tilt range to 180º and produces 52% less dBA noise when rotating. It is also our first IP65-rated weather-resistant pan camera, ready to be used outdoors with the included mounting kit that lets you mount it literally anywhere - even upside-down. Lastly, it has Privacy Mode which points the camera lens down towards the camera body and obstructs any view.
No, Wyze Cam Pan v3 is powered via a 1.8 m USB cable.
1920 x 1080p Full HD.
Yes, it will return to its previous position.
Yes, Wyze Cam Pan v3 is IP65-rated and can be used both indoors and outdoors. Just be sure to cover the SD card slot to avoid water damage. Wyze Outdoor Power Adapter v2 is required for outdoor use.
Day: 20 frames per second (fps); Night: 15 fps.
No, Wyze Cam Pan v3 only supports 2.4 GHz networks.
Yes, Wyze Cam Pan v3 supports Wyze Web View. (Requires subscription to Cam Plus or Cam Protect) (https://view.wyze.com/)
No, it does not. Cam Plus Lite is only available on cameras released before April 2022.
Wyze Cam Pan v3 is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night. To use it, turn off Night Vision in low light conditions.
There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality. Please check our support site if you need more details.
Take Wyze Cam Pan v3 outside.
Not just an indoor cat anymore. With IP65 water resistance* you can automatically patrol your property in any weather.
Wyze Cam Pan v3 in the snow outside
Automatic motion-tracking.
Those cans never knew what hit them, but Pan v3 did. That's because it detects motion, follows, and records it automatically. Its upgraded tracking motor is quieter than a gossiping church mouse, so it won't wake napping babies or startle pets.
...wait till' the end 😂
See the whole room with 360° pan and 180° tilt.
Now with double the tilt coverage, Pan v3 can look straight up and down. Just like my middle school gym teacher, but way less judgy. It was an awkward time for me, okay?
Privacy Mode.
You just sat down to binge watch that show. You also decided that pants were optional today.
Pan v3 with a speech bubble that says "Bruno, wake up, it's dinner time!" and is pointed towards a nearby dog.
Two-Way Audio.
Watched a black and white movie recently? We haven't either, because every detail matters. That's why we've made Color Night Vision standard across all of our security cameras with Starlight Sensor.
  • Classic night vision from Pan v3
    $150 Competitor Cam
  • Color night vision with Pan v3
    Wyze Cam Pan v3
Wyze Cam Power Adapter v2 laid out against a white background.
Add a Wyze Outdoor Power Adapter + L-shaped MicroUSB
Ready for rain, snow, or shine. Pair your camera with an adapter made for the outdoors. The Wyze Outdoor Power Adapter + L-shaped MicroUSB is designed to work with Wyze Cam Pan v3.
Learn more
  • Smartphone with Wyze App open. Text overlay that says "24/7 recording with local SD card storage."
  • Smartphone with Wyze app open. Text overlay that says "Get smarter security with Cam Plus."
Render of Pan v3 with 4 active waypoints mapped.
Smartphone with Wyze notification on the lock screen.
Detection settings screen in the Wyze app with a marked detection zone.
Alarm settings screen with options to toggle notifications for Smoke Alarm Sound and CO Alarm Sound.
Packed with app features.
Patrol your room with Pan Scan™. Set the camera’s patrol route with up to 4 custom waypoints.
Wyze Cam Pan v3 sends your phone instant alerts when either motion or sound is detected. With Cam Plus, you can get advanced notifications, like if Wyze Cam hears a crying baby or a barking pet.
*Requires Wyze Outdoor Power Adapter + L-shaped MicroUSB (sold separately) for outdoor use.
