Will It Fit? — Wyze Bulb Cam Fixture Checker
Fit Check Tool
Will the Bulb Cam fit your fixture?
Two quick questions. We'll tell you instantly — before you buy. No returns, no guessing.
1 Your fixture type
Where will it go?
2 Your measurements
Measure the cavity
4.4" 3.1"
Pick a fixture and enter your measurements
We'll instantly tell you whether the Bulb Cam will fit, fit snugly, or need a different setup.
4.4"
Total Length
3.1"
Max Width
E26
Standard Base
120V
AC Power
Sconces that play nice with Bulb Cam
These common outdoor and indoor sconce styles fit the Bulb Cam with room to spare. If your fixture matches one of these, you're good to go.
Rule of thumb: less than 7.87" (20 cm) deep from socket to edge
Fits
Traditional Coach Lantern
Outdoor · Open-bottom
Typical Depth
5–7"
Common Use
Porch, garage
Fits
Box / Mission Lantern
Outdoor · Glass-paneled
Typical Depth
5.5–7"
Common Use
Entryway
Fits
Half-Dome Wall Pack
Outdoor · Garage / Side door
Typical Depth
5–6"
Common Use
Garage, alley
Fits
Barn / Gooseneck
Outdoor · Bottom-facing
Typical Depth
4–6"
Common Use
Driveway, barn
Tight Fit
Cylinder Up/Down
Modern · Narrow opening
Typical Depth
4–5"
Watch
Check width
Fits
Flush Porch Light
Indoor/Outdoor · Domed
Typical Depth
5–6"
Common Use
Porch ceiling
Confirmed fits from popular brands: Hampton Bay Progress Lighting Kichler Hinkley Sea Gull Lighting Westinghouse
Measurements based on Wyze Bulb Cam v1 (4.4" L × 3.1" W). Sconce examples reflect typical dimensions — always measure your specific fixture. We recommend at least 0.25" clearance for ventilation.
FREE shipping on orders $0+
