1 de 4
Sensor de movimiento Wyze Sense
Detecta movimiento.
Tamaño
Complementos
$24.98
En existencias
Recíbelo tan pronto como
Devoluciones sin complicaciones durante 30 días.
Detecta movimiento. Requiere Wyze Sense v2 o Wyze Home Monitoring.
Ver todos los detalles
No, this functionality is not available at this time. To use Wyze Sense v2 accessories, please purchase and connect them to a Wyze Sense Hub via the Wyze Home Monitoring Core Starter Kit.
No. Wyze Sense Entry and Motion Sensors and Keypads are for indoor use only.
Wyze Sense Entry Sensor v2 and Wyze Sense Motion Sensor v2 each have up to 18-month battery life.
No, glass will interfere with the functionality of the PIR sensor.
No, the adhesive is designed to be permanent.
No, all sensors and keypad will require a Wyze Sense Hub to pair with.
The Wyze Sense Hub can connect to sensors up to 500 feet away in an unobstructed room. Please note that walls and interference in your home may cause the range to vary.
Wyze Sense Motion Sensor v2 can detect movement within a 120 degree field of vision within 25 feet.
Up to 100 sensors & keypads.
Envío GRATIS en pedidos de $0+
