1080p HD Color Night Vision
Seguridad interior/exterior IP65
Foco empotrado con sirena integrada
Grabación 24/7 en tarjeta microSD Wyze
No se requiere suscripción.
Nota: Puede haber ligeras diferencias de apariencia según el modelo de cámara que reciba. La funcionalidad del producto es idéntica.
El último número de modelo 2025 en la caja es WYZECGSD. El número de modelo anterior era WYZECGS.
There are two key differences: The telephoto camera has a 3x telephoto lens, while the standard OG camera has an integrated spotlight. Both are great cameras with all of the features you know and love. Use Wyze Cam OG to monitor your home with a wide angle lens. Use Wyze Cam OG Telephoto to clearly monitor points-of-interest that are further away.
Yes, both cameras can be used as standalone cams. But we like using them both together - you get the OG’s integrated spotlight, Wyze Cam OG Telephoto’s closer details, and the ability to view the livestream of both cameras at the same time.
No, Wyze Cam OG is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Yes, Wyze Cam OG is IP65-rated and can be used both indoors and outdoors.
You can stack 2 total cameras together, in any combo! That could be a Wyze Cam OG and a Wyze Cam OG Telephoto, or two Wyze Cam OG cams, or two Wyze Cam OG Telephoto cams.
1920 x 1080p Full HD.
Day: 20 frames per second (fps); Night: 15 fps.
No, Wyze Cam OG only supports 2.4 GHz networks.
Wyze Cam OG is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Yes, Wyze Cam OG is compatible with Wyze Web View.
Yes, the telephoto cam can be used as a standalone camera, without a Wyze Cam OG. But we like using them both together - you get the OG’s integrated spotlight, Telephoto’s 3x closer details, and the ability to view the livestream of both cameras at the same time.
Yes, Wyze Cam OG Telephoto is IP65-rated and can be used both indoors and outdoors, rain or shine.
Day: 20 frames per second (fps); Night: 10 fps.
No, Wyze Cam OG Telephoto only supports 2.4 GHz networks.
Yes, Wyze Cam OG Telephoto is compatible with Wyze Web View.
Only Wyze Cam OG and Wyze Cam OG Telephoto have Picture-in-Picture functionality.
Yes. You can use Picture in Picture to view two Wyze Cam OGs or two Wyze Cam OG Telephoto 3x cameras at the same time. It is not limited to only Wyze Cam OG + Wyze Cam OG Telephoto viewing.
No, neither camera is compatible with Cam Plus Lite. Cam Plus Lite only supports cameras released during or before April 2022.
No, only Wyze Cam OG has a spotlight.
No. The Wyze Cam OG Stack Kit is a useful way to mount any two Wyze Cam OG or Wyze Cam OG Telephoto cameras on top of each other and use a single outlet to power them both. The Picture-in-Picture feature is a software feature and does not require the physical stack kit to work.
The Wyze Stack Kit includes a USB Cable Splitter, a Power Brick, and Stack Mount that allows you to power and stack-ably mount two Wyze Cam OGs or Wyze Cam OG Telephoto Cameras on top of each other.
Yes. Both cameras take all Wyze microSD cards up to and including 256GB microSD cards.
Independientemente asombroso.
Ya sea boca abajo o boca arriba, cada cámara funciona por sí sola para cubrir todos los ángulos de cualquier espacio.
Protege cada espacio, interior y exterior.
Foco incorporado y mini-sirena.
Luces. Cámara. ¡DESCONTROLADO! Disuade a posibles malhechores con un foco de 40 lúmenes y una sirena de 90 decibeles que activa el usuario.
Notificaciones de movimiento 3 veces más rápidas.
Audio bidireccional mejorado.
What was that? Better audio you ask? Yeah we hear you loud and clear. An upgraded microphone and revamped speaker provide enhanced clarity.
Cargue videos HD en vivo más rápido que nunca.
Genial desde el primer momento. Aún mejor con Cam Plus.
Admite todas las tarjetas microSD Wyze, hasta 256 GB inclusive.
Una experiencia de aplicación completamente nueva.
A diferencia de un ladrillo Lego perdido a la 1 am, hemos colocado todas las herramientas útiles exactamente donde las querrías, desde los controles del foco y la sirena hasta la nueva revisión simplificada de eventos.
Disfrute de una nueva sección de Eventos recientes fácil de explorar para navegar rápidamente por las imágenes.
Dile a Wyze Cam OG exactamente dónde quieres que observe. Recibe notificaciones solo cuando detecte algo dentro de tu zona personalizada.
¡Elige la Wyze Cam OG que mejor se adapte a ti!
Cámara Wyze OG
- 120° Field of View
- Built-In Spotlight with Color Night Vision
- IP65 Weatherproof
- Two-Way Audio
- Works with Wyze Cam OG Stack Kit
Aprende más- 3x Telephoto Camera (27° Field of View)
- Color Night Vision
- IP65 Weatherproof
- Two-Way Audio
