Skip to content
1 of 8
Wyze Watch 47c
Wyze Watch 47c
The do-anything aluminum smartwatch.
Color
Additional Strap
$33.99
  • battery icon
    9-Day Battery Life
    Instant Notifications
  • sprinkler controller icon
    Advanced Health Tracking
  • Weather-resistant page.
    IP68 Waterproof
Wyze Watch 47mm C Device Details
Color
  • Available in Rainbow, Space Blue, Classic Blue, and Classic Black.
Materials
  • Screen: 2.5D glass
  • Body: Aluminum alloy
  • Bottom body: ABS + Pet
  • Strap: Silicone (Classic Black, Classic Blue). Nylon (Rainbow, Space Blue)
Dimensions
  • Watch body: 46.8 mm (L) x 38.9 mm (W) x 11.9 mm (D)
Weight
  • 46.6 g
Strap
  • Silicone: 160-240 mm x 22 mm
  • Nylon: 145-230 mm x 22 mm
Display
  • Size: 1.75 TFT LCD
  • Screen Resolution: 320 x 385 pixels
  • Color: 16-bit color
  • Touchscreen: Yes
Battery
  • Battery capacity: 300 mAh
  • Charging time: 2.5 hours
  • Battery life: 9 days
  • Standby: 60 days
  • Charger: Magnetic charging, 0.7 m cable
Performance
  • MCU: 96 MHz
  • RAM: 512 KB
  • External Flash: 16 MB
Sensors
  • PPG Heart Rate Sensor: Yes
  • Blood Oxygen Sensor: Yes
  • Acceleration Sensor: Yes
  • Vibration Motor: Yes
Connectivity
  • Bluetooth 5.0
Weather Resistance
  • IP68 Waterproof
Warranty
  • 1-Year
  • Wyze Watch 47 C x1
  • Magnetic USB Charging Cable (0.7m) x1
  • Strap x1 (Available in Rainbow, Space Blue, Classic Blue, and Classic Black)
  • Quick Start Guide x1
- Wyze Watch 47mm C comes in 4 total colors: Rainbow, Space Blue, Classic Blue, and Classic Black.
- It has new packaging specially designed for the holidays.
- It comes with 12 new and exclusive watch faces.
No, the firmware is the same as the original Wyze Watch 47mm. There are no new functions.
No, individual straps for this version are not available. Because of limited quantities, the straps are sold exclusively with Wyze Watch 47mm C.
- Classic Black: Black frame with a black silicone strap.
- Classic Clue: Light blue frame with black silicone strap.
- Space blue: Dark blue frame with blue nylon strap.
- Rainbow: Purple frame with rainbow nylon strap.
No, the new watch faces are exclusive to Wyze Watch 47mm C.
No, it uses an included magnetic charger and does not work with wireless chargers.
You can accept and deny incoming calls using your Wyze Watch, which works great if you’re wearing Wyze Headphones or Wyze Buds. However, Wyze Watch does not have a built-in microphone or speaker.
No, it does not support contactless payments or NFC.
No, it does not support cellular data or GPS. It works via Bluetooth-only.
Silicone for Classic Black and Classic Blue, Nylon for Space Blue and Rainbow.
It stands for both Color and Classic. Maybe we should call it C².
Luxurious Aluminum Design.
Wyze Watch 47c is crafted from brushed aluminum and hardened glass with a large, 1.75" display for easy viewing from every angle.
Two Black Wyze Watch 47c. One watch shows watch band and smart digital interface with an app screen open. Second watch shows band and back of the watch face.
Watch 47c separated by screen, computer chip, watch frame, and watch band.
9-Day Battery Life.
Power through a full week without worrying about battery life. You can also track your sleep at night instead of taking your watch off to charge.
Side view of watch showing Facebook, Whatsapp, Instagram, Messenger, Gmail, Twitter, WYZE, and Youtube icons above watch face
Instant Notifications.
Get notified right from your wrist. Discreetly view texts, decline phone calls, and stay apprised of meaningful notifications from your favorite apps.
Phone screen showing Watch 47c in Wyze app
Customizable Watch Faces.
Choose from dozens of unique watch faces in the Wyze app, even upload photos from your smartphone and create your own.
Advanced Health Tracking.
Track where you started so you know where you're headed with Wyze Watch 47c.
  • Watch screen showing Oxygen Saturation
    Blood Oxygen / Heart Rate
    A drop in blood oxygen saturation is one of the earliest signs of serious health risks. Wyze Watch 47c measures your heart rate and blood oxygen levels so you can check in on your health at any time.
  • Watch screen showing Sleep Monitoring
    Sleep Monitoring
    Create healthy sleep habits by tracking how much rest you get at night. Make more informed decisions regarding your sleep and set alarms for waking up or going to bed.
  • Watch screen showing Menstrual Cycle Tracking
    Cycle Tracking
    Easily track your cycle right from your Wyze Watch 47c. Period predictions are calculated based on your cycle length and your most recent period date.
1 of 3
A smart watch screen with a menu of options including Shortcut, Turn Lights On, All Cams Off, and others.
Control your Wyze Ecosystem.
Lock the door with Wyze Lock. Turn on the lights with Wyze Switch. Brew a pot of coffee with Wyze Switch. Do it all from your wrist.
Wyze Watch 47c in water
IP68 Waterproof.
Built to withstand dust, dirt, and sand. Resistant to submersion up to a maximum depth of 2 meters underwater for up to 30 minutes.
