1 of 5
Wyze Watch 44mm
Wyze Watch 44mm
What you'll find:
  • Reach your health goals with Smart Scales.
  • Put the outside world on mute with Noise-Cancelling Headphones.
  • Keep your surroundings clean without it being a total chore.
  • And we can't forget about the Merch.
Shop Lifestyle products
Item is no longer available.
The go-anywhere smart watch.
  • A blue arrow pointing downwards on a pink and purple square.
    Compact Size (1.44 Inches)
  • A purple and pink symbol that represents carbon dioxide.
    Blood Oximeter
  • A square with a black background and a pink border.
    Lightweight Aluminum Alloy Frame
  • A purple and pink circle with a white star in the center.
    9-day Battery Life
Wyze Watch 44mm Device Details
Color
  • Black
Materials
  • Screen: 2.5D glass
  • Body: Aluminum alloy
  • Bottom body: ABS + Pet
  • Strap: Silicone (Black)
Dimensions
  • Watch body: 44 mm (L) x 36 mm (W) x 11.7 mm (D)
  • Strap: Silicone: 160-240 mm x 22 mm
Weight
  • 42 g
Display
  • Size: 1.75 TFT LCD
  • Screen Resolution: 320 x 385 pixels
  • Color: 16-bit color
  • Touchscreen: Yes
Battery
  • Battery capacity: 300 mAh
  • Charging time: 2.5 hours
  • Battery life: 9 days
  • Standby: 60 days
  • Charger: Magnetic charging, 0.7 m cable
Performance
  • MCU: 96 MHz
  • RAM: 512 KB
  • External Flash: 16 MB
Sensors
  • PPG Heart Rate Sensor: Yes
  • Blood Oxygen Sensor: Yes
  • Acceleration Sensor: Yes
  • Vibration Motor: Yes
Connectivity
  • Bluetooth 5.0
Weather Resistance
  • IP68 Waterproof
Warranty
  • 1-Year
  • Wyze Watch 44mm x1
  • USB Charging Cable (0.7m) x1
  • Black Silicone Strap x1
  • Quick Start Guide x1
Wyze Watch can run up to 9 active days on a charge!
No, Wyze Watch uses a magnetic charger.
Both sizes of Wyze Watch use 22mm quick release watch straps.
The included strap is made of silicone.
Heart rate, step count, blood oxygen, sleep tracking info, calories burned, blood oxygen level, and accelerometer info. There is also voluntarily provided information such as weight, height, etc. that we will ask for during setup for accurate fitness information.
It takes about 2.5 hours for a full charge.
Press and hold the button on the side, then tap reset on the screen.
Your Wyze Watch will automatically measure your heart rate periodically, but you can also initiate a manual heart rate reading from your watch.
The back of the watch has an LED cluster which emits two wavelengths of light. Combining the information that they each collect, the watch screen shows your blood oxygen saturation level.
Wyze Watch supports running Shortcuts that you have set up in your Wyze app. Please see the section “What are Shortcuts?” on our Support site for more information.
A green watch with a dark green band.
A window to better wellness.
In just a few taps, you can check for drops in your blood oxygen saturation - one of the early signs of serious health risks. Also track steps, heart rate, and other fitness information right from your wrist.
A black watch with a green screen displaying a message.
Stay connected to what matters.
Wyze Watch 44mm displays your phone's notifications to save you from digging in your pocket or purse to check a message.
Man wearing a backpack and a watch.
Travel without another charger in your bag.
With up to 9 days of battery life, you have one less thing to worry about when you’re heading out on your latest adventure.
A black watch with the word Gmail on the screen.
See even more than before.
With a high-density square display, you’ll be able to read and see more than you ever could with a fitness band.
1.44-Inch Screen Size
Show off your personal style.
Be bold and make a statement or help your watch blend in. The choice is yours with over 35 customizable watch faces and six 22mm quick-release straps to choose from.
35+ Customizable Watch Faces 6 Quick-Release Straps
A watch with a green band.
A person washing their hands with a blue watch on their wrist.
By your side no matter the conditions.
Dust, rain, or sweat? No problem. IP68 weather and water resistance means there’s no need to worry about the elements - whether you’re out and about or just doing the dishes.
A black and white watch with the time 12:24.
A shortcut to your Wyze Shortcuts.
Control your Wyze devices using the Shortcuts you know and love from the top of your Wyze app. Lights, cams, robot vacuums, and more are at your fingertips.
