Skip to content
1 of 7
(Refurbished) Wyze Lamp Socket
Outdoor Power for Cam v3/v4
Style
SALE
$19.98 $34.96SAVE 44%
12-month extended warranty
Get a 12-month extended warranty when you buy refurbished products on wyze.com. Also get special bundles, unique promos, + rewards with each order
Wyze Refurbished logo
This is a Wyze refurbished product. What does that mean? It's a like new Wyze product, fully tested and guaranteed to work — now at an even better price. Final sale, but a wyze decision.
Make your exterior lighting smart. Power Wyze Cam v3 and v4 without a plug.
The original model of the Wyze Lamp Socket.
  • Conveniently Powers Wyze Cam v3/v4
    No creative extension cord weaving required.
  • Motion-Activated Lights
    Converts standard bulbs into motion-activated security lights.
  • Linkability
    Wirelessly link up to 5 lamp sockets together.
  • Dusk to Dawn Scheduling
    Automatically turn your lights on at sunset and off at sunrise.
Wyze Lamp Socket Device Details
  • Color: White
  • Materials: Polycarbonate, Plastic
  • Dimensions: 56.5mm x 56.5mm x 65mm
  • Weight: 80 g
  • Socket Connector Type: E26
Power
  • Lamp Socket Input/Output120V, 60Hz
  • Max Lamp Power30W
  • USB Cable75 cm / 30 inches
  • USB Ports1 Type-AUSB Output5W/ 5V1A, USB 1.1
Compatibility
  • Phone: Android 7.0+, iOS 12.0+
  • Camera: Wyze Cam v3/v4
Connectivity
  • 802.11 b/g/n, 2.4GHz, Bluetooth
Operating temperature
  • -4°F ~ 120°F (-20°C, ~ 50°C)
Weather Resistance
  • Not weatherproof or waterproof. Suitable for damp locations.
Certifications
  • ETL, CETL, UL
Wyze Cam v3 Device Details
  • Color: White, with black accents
  • Lens: Glass + Plastic
  • Camera Dimensions: 52 mm (L) x 51 mm (W) x 58.5 mm (D)
  • Camera Weight: 98.8g
Phone Compatibility
  • Android 7.0+ and iOS 12.0+
Display
  • Resolution: FHD 1920x1080p
  • Viewing angle: 130º diagonal
Night Vision
  • IR Lights 4x940 nm, 4x850 nm
  • Day/Night Vision
Audio
  • Mic: ECM
  • Speaker: 80 db, waterproof
  • Simultaneous 2-way Talk
  • Siren
Powering methods
  • Power Adapter: Indoor 5v/1A
  • Wyze Lamp Socket (sold separately)
  • Outdoor Power Adapter (sold separately)
  • Cable: 6 Feet Flat USB Cable
Sensor
  • CMOS Starlight Sensor
LED Indicator
  • Front. Red + Blue.
Connectivity
  • 2.4GHz WiFi
Storage
  • Local Storage (microSD card required)
  • Cloud
Operating Temperature
  • -5°F - 113°F (-20°C - 45°C)
Weather Resistance
  • IP65 Weather resistant, Indoor/Outdoor
Certifications
  • FCC, IC, UL and IP65 Certified
Languages
  • English
Warranty
  • 1-Year
Lamp Socket (only)
  • Wyze Lamp Socket x1
  • USB Cable x1
  • USB Cable Clips x6
  • Wall Anchors x6
  • Screws x6
  • Quick Start Guide x1
Lamp Socket + Wyze Cam v3 Bundle
  • Wyze Cam v3 x1
  • USB Cable x1
  • Cable Clips x6
  • Wall Anchors x6
  • Camera Screws x2
  • Camera Wall Anchors x2
  • Camera Wall Plate x1
  • Camera Mounting Tape x1
Users can leave the power switch on all the time, but the light doesn’t need to stay on all the time, to save power. The light will be turned on when a motion or person is detected.
Turn them all on (up to 5) within 30 seconds and they will find themselves, link, and form a group. Once they form a group, you can control each lamp socket in the group at the same time.
Only 1 (one) Wyze Cam v3 or Cam v4 per lamp socket.
Yes absolutely. All sockets are connected wirelessly and can be turned on/off simultaneously. We currently support up to 5 lamp sockets linked in one group.
No, each Wyze Lamp Socket comes with a dedicated cable to connect to a v3/v4. Do not use any other Wyze Cam v3/v4 cable.
No, it is not weatherproof or IP-rated. It is UL rated for Damp Locations, and must be protected from direct rain and water.
We use the advanced motion detection from Wyze Cam v3 or v4 to detect motion and turn on your light.
Flexible power for your Wyze Cam v3/v4
Skip the wiring and electrocution (unless you're into that sort of thing). Harness the electricity from your outdoor light fixture to continously power your Wyze Cam v3/v4. No more creative cord compositions. No long, ugly wires. No hassle.
Wyze Lamp Socket powering an Edison bulb outside with a Wyze Cam v3 attached to the outlet built into the socket.
A Wyze Lamp Socket with an Edison bulb attached
Upgrade to smart lighting in seconds.
Wyze Lamp Socket and Wyze Cam v3 work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains! A perfect, symbiotic relationship, just like Hippo and Oxpecker! Sing it with us! Symbiotic! Symbiotic!
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever Wyze Cam v3/v4 senses motion or sound. Now your old light fixture is a cutting-edge model of sleek security sophistication!
Easily link multiple sockets for greater coverage and control.
Auto-connect up to 5 lamp sockets for Olympics-worthy synchronization of your outdoor lighting. Then schedule and control your newly smart setup from anywhere using the Wyze app.
Dusk to Dawn Automation.
Get Inspired
See how Wyze users are using their Wyze Lamp Socket!
As easy as screwing in a light bulb.
Some installations are as easy as screwing in a lightbulb. Other installations are literally the exact same as screwing in a lightbulb. Wyze Lamp Socket falls in the latter category.
