Skip to content
1 of 6
The Airbnb Side-Hustle Starter Pack
Everything you need to start an Airbnb side-hustle.
Style
SALE
$189.99 $201.96SAVE 5%
Wyze Lock Bolt
Wyze Video Doorbell Pro
Wyze Plug (Indoor) (2-pack)
Wyze Night Light (3-pack)
Start a side-hustle with Wyze.
With inflation on the rise and budgets getting tighter, we here at Wyze want to help you kickstart your next money-making venture. This starter pack includes the basics in home security and automation to get you started.
Beautiful glow of setting sun against a cabin surrounded by trees and a view of distant mountains.
Entryway with a side table and luggage next to a white wood door with the Wyze Lock Bolt installed
Wyze Lock Bolt
Practically made for short-term rentals, Wyze Lock Bolt let's you do things no other smart lock can.
For example, did you know you can create automatically-expiring access codes so renters can't access the Airbnb after a certain time?
  • In app front door lock history
    View history of locks and unlocks in the Wyze app.
    See who stopped by in the Wyze app. You can even view how it was unlocked, the exact time, and if there were any failed passcode attempts.
  • In app access duration
    Create auto-expiring codes and access schedules
    Use auto-expiring codes so you never have to worry about temporary guests entering without permission. Set the day/time the code expires and never think about it again.
1 of 2
Person installing a Wyze Video Doorbell Pro onto a wall mount plate
Wyze Doorbell Pro
Place Wyze Video Doorbell Pro wherever you need it with no wiring required and a 6-month battery life.
It's perfect for spaces with a private entrance that you might need to keep an eye on.
  • Motion detection notification
    Motion Notifications
    Most battery-powered video doorbells have sluggish notifications. Ours includes a dual-band Wi-Fi Extender chime which stays connected to both your doorbell and Wi-Fi for lightning-fast notifications.
  • Two way audio on video doorbell pro telling guests to come inside
    Two-Way Audio
    Quickly respond to guests by simply pressing the "talk" button in the Wyze app. You can also use preset quick responses to say things like: "Leave the package at the door."
  • View of front door from video doorbell
    Ultra-Wide Viewing Angle
    Wyze Video Doorbell Pro features a head-to-toe, ultra-wide viewing angle, so not only can you see the package at your doorstep, but even the house down the street.
1 of 3
Wyze Plug in a wall outlet with a small house fan attached
Wyze Plug
Guests gone but left all the lamps, coffee maker, and fans on? No worries, just use Wyze Plug to shut everything off from your phone until you get back.
  • Wyze plug in app settings
    Quick controls in the Wyze app.
    View daily and weekly run times and group multiple plugs together, controlling them all with one tap.
  • Air purifier plugged into a wyze plug
    Works with Alexa and Google Assistant
    Command your devices using just your voice with Amazon Alexa and Google Assistant.
1 of 2
Wyze Night Lights lining the side of stairs
Wyze Night Light
Wyze Night Lights are unique in their ability to be linked together to light a path. This is especially useful guests staying in spaces with dark hallways and stairs or helpful for lighting a path to the restroom at night.
  • Wyze Night Light turning on with motion in the bathroom
    Motion Detection
    Built-in motion and light sensors activate a soft glow (only at night).
  • Wyze Night Light on wall next to a couch
    Magnetic Installation (no outlet required)
    Since Wyze Night Light is battery powered, you can place it wherever you need to with the magnetic mounting plate.
1 of 2
