Rociador Wyze Plus
Rociador Wyze Plus
Devoluciones sin complicaciones durante 30 días.
Subscribe today
Desbloquee un conjunto de funciones inteligentes basadas en el clima para mantener su jardín verde de manera más eficiente.
Ver todos los detalles
  • Inteligencia meteorológica
    Riega cuando tus plantas tengan sed, no cuando llueve.
  • Información avanzada
    Puede ver los niveles de humedad históricos, actuales y futuros.
  • Saltos meteorológicos inteligentes
    Evite riegos programados innecesarios. Datos meteorológicos hiperlocalizados.
  • Información de humedad de la zona
    Vea los niveles de humedad históricos, actuales y futuros para cada zona de riego.
1x Licencia digital única para Sprinkler Plus
Sprinkler Plus is an optional service that adds a ton of smarts to your Wyze Sprinkler! With Sprinkler Plus your Wyze Sprinkler gains advanced weather data that can be used to create Smart Schedules, enable Weather Skips, and provide detailed Zone Moisture information. It is available as an annual subscription.
No, a Sprinkler Plus subscription cannot be gifted. Only the account owner can subscribe to Sprinkler Plus.
It uses hyper-local weather data and zone parameters. With Sprinkler Plus, you can create Smart Schedules which automatically water your plants when needed.
To do this, we measure water in (from rain and running your irrigation system) and water out (evapotranspiration), along with previous and forecasted weather to calculate the water balance in each zone. When the balance is forecasted to reach the allowed depletion (dry out), we schedule a watering.
No, Sprinkler Plus is completely optional. Sprinkler Plus is an optional service for Wyze Sprinkler that gives you advanced weather data. This data can be used to:
  • Create Smart Schedules
  • Enable Weather Skips
  • Turn on Cycle/Soak
  • See detailed Zone Moisture data
Your Wyze Sprinkler Controller purchase includes 1 year of Sprinkler Plus. Make the most of it!
No, Sprinkler Plus is only available in the US.
Wyze Sprinkler Controller and Sprinkler Plus are only available in the US at this time.
Un plan elaborado para el controlador de aspersores Wyze
Necesitará el controlador de rociadores para aprovechar al máximo este plan.
  • Controlador de riego inteligente a un precio asequible
    -Tendencias digitales
  • El controlador de riego Wyze tiene una excelente relación calidad-precio.
    -Cortador de alambre
  • Controlador de riego inteligente asequible n.° 1
    -ZDNet
1 de 3
Desbloquea el riego basado en el clima con Sprinkler Plus.
Riega cuando tus plantas lo necesiten, no cuando llueva, con Sprinkler Plus. (incluye una suscripción gratuita de 1 año con la compra del controlador de riego Wyze)
Upcoming rain, no watering needed for the next three days.
Advanced insights into your yard screen.
Información avanzada sobre su jardín.
Con Sprinkler Plus, puedes ver los niveles históricos, actuales y futuros de humedad para cada zona de riego. Incluso puedes consultar el pronóstico del tiempo y las próximas actividades de riego directamente desde la aplicación.
A weather app on a phone displaying a 5-day forecast.
Saltos meteorológicos inteligentes.
Sprinkler Plus puede omitir riegos programados innecesarios basándose en datos meteorológicos hiperlocalizados para ahorrar agua y proteger tus plantas.
Instalación tú mismo en 20 minutos.
Wyze Sprinkler reemplaza su controlador actual en menos de 20 minutos y crea automáticamente un horario después de la configuración.
Envío GRATIS en pedidos de $0+
