Skip to content
1 of 4
Wyze Sense Motion Sensor
Detects motion.
⚠️ Requires Wyze Sense Hub.
This device will NOT function as an individual or standalone product or with Wyze Sense v1.
Instant Discount
To get 28% off Wyze Sense Sensors, add a Wyze Home Monitoring Annual plan to your cart. Check out the builder.
Place the Wyze Sense Motion Sensor around your home to be notified when motion is detected up to 25 ft within its 120° FOV detection zone. With adjustable sensitivity settings and alternative “large pet installation” instructions, Wyze Motion Sensor is designed to detect people, not pets. The adhesive back makes it easy to install on walls with the option to use screws for added security.
Size
$29.99CAD
Detects motion. Requires Wyze Sense v2 or Wyze Home Monitoring.
No, this functionality is not available at this time. To use Wyze Sense v2 accessories, please purchase and connect them to a Wyze Sense Hub via the Wyze Home Monitoring Core Starter Kit.
No. Wyze Sense Entry and Motion Sensors and Keypads are for indoor use only.
Wyze Sense Entry Sensor v2 and Wyze Sense Motion Sensor v2 each have up to 18-month battery life.
No, glass will interfere with the functionality of the PIR sensor.
No, the adhesive is designed to be permanent.
No, all sensors and keypad will require a Wyze Sense Hub to pair with.
The Wyze Sense Hub can connect to sensors up to 500 feet away in an unobstructed room. Please note that walls and interference in your home may cause the range to vary.
Wyze Sense Motion Sensor v2 can detect movement within a 120 degree field of vision within 25 feet.
Up to 100 sensors & keypads.
