Skip to content
1 of 15
Wyze Solar Cam Pan
Wyze Solar Cam Pan
Zero Wires. Zero Maintenance.
Quantity
$99.98CAD
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Compatible With
Compatible With
  • Integrated High-Efficiency Solar Panel
  • 360° Pan & 70° Tilt Coverage
  • AI-Powered Person Tracking
  • 2K HD Resolution with WDR
  • Quick, Easy Mounting
  • IP65 Weather Resistance
  • Maintenance-Free Solar Power
    An integrated solar panel delivers continuous power to the battery with just one hour of sunlight per day.
  • 360° Pan/Tilt Coverage + 2K HD
    See every detail with no blind spots. Secure an entire space with pan and tilt coverage.
    Detects and locks on to people, following them wherever they go.
  • Quick, Easy Mounting + Setup
    Mount anywhere and snap into place in minutes. Enjoy hassle-free setup with Bluetooth®.​
Specs
  • Model: WYZESCPWH
  • Body Material: Polycarbonate
  • Lens Material: Glass & Plastic
  • Certifications: FCC/IC, IP65, RoHS, REACH, CA65
Audio
  • Microphone: Built-in, digital
  • Siren: 105dB
  • 2-Way Audio
Storage & Alerts
  • Alerts: Push notifications
  • Cloud Storage: Stored in the AWS cloud (Wyze Service subscription required)
  • Local Storage (microSD card required): Supports 8-32 GB microSD cards in FAT32 format. Supports up to 512 GB microSD cards in exFAT format.
Weather & Temperature
  • Weather Resistance: IP65
  • Operating Temperature: -4°F - 122°F (-20°C - 50°C)
  • Storage Temperature: -4°F - 140°F (-20°C - 60°C)
  • Resolution: 2K (3MP)
  • Digital Zoom: 8x
  • Field of View: Diagonal: 130°, Horizontal: 108°, Vertical: 57°
  • Frame Rate: Daytime: 20 FPS, Nighttime: 15 FPS
  • Night Vision: Color Night Vision, IR LEDs: 2x 850nm
  • Spotlight: 2x White LED (100 lm)
  • Pan/Tilt Range: Horizontal: 360°, Vertical: 70°
Connectivity & Compatibility
  • OS Requirements: Android 9.0+ or iOS 15.0+
  • Wi-Fi: 802.11 b/g/n/ax 2.4 GHz, Wi-Fi 4/5/6
  • Bluetooth® Setup
Power
  • Power Adapter: 5V/2A (not included)
  • Input: 110-240V
  • Cable: Type-C to USB-A (2 ft. / 0.6 m)
  • Integrated Solar Panel (1.8W)
  • Battery: 6400mAh, non-removable Lithium-ion battery
  • Charging Time: 0-100% in 4-6 hours using the cable/adapter
  • Battery Life: Up to 6 months (if not connected to power)
  • Wyze Solar Cam Pan x 1
  • Solar Panel x 1
  • Camera Mounting Bracket x 1
  • Solar Panel Mounting Bracket x 1
  • Charging Cable (2ft) x 1
  • Camera Mounting Kit x 1
  • Solar Panel Mounting Kit x 1
  • Camera Mounting Drilling Guide sticker x1
  • QSG x1
Wyze Cam + The Sun. Love at first light.
Let the sun do the work. ☀️ An integrated high-efficiency ETFE solar panel delivers continuous power to the battery with one hour of sunlight per day.
360° pan/tilt coverage with AI-powered person tracking.
Edge AI detects and locks on to people, following them wherever they go. Secure an entire space with pan and tilt coverage. Control remotely via the Wyze app to see exactly what you want.
Flexible solar panel mounting.
Connect the solar panel on top of the camera for a tidy install. Or place it separately where the sunlight’s strongest for maximum charging power. The choice is yours.
Cloudy days? No sweat.
Does the sun like to hideout for a while where you live? No worries. The built-in 6400mAh lithium-ion battery provides up to 6-months of standalone power.
Crystal-clear video recording with a wide field-of-view captures every detail, day or night. Wide Dynamic Range (WDR) evens out the brightest highlights and the darkest shadows so nothing gets lost.
Motion-activated spotlight & siren.
Deter intruders or light your way home with a motion-activated spotlight. Activate the loud 105dB siren for extra security.
IP65 weather resistance.
Drip. Splash. Plop. No matter the weather, this camera cannot be stopped. Built tough to handle the elements outdoors. Designed with style to blend into your home indoors.
  • Two-Way Audio
    Hear sound and speak through the camera from anywhere with the Wyze app.
  • Detection Features
  • AI Notifications and Descriptive Alerts
  • Wi-Fi 6 Support
    Maintain a strong and reliable connection with Wi-Fi 6 support (Wi-Fi 6 router required), resulting in smoother livestreaming.
More to Love
See our unique design in action.
How to Setup Wyze Solar Cam Pan
While following the Wyze Solar Cam Pan Setup Guide, you'll be prompted to install your camera. Follow along with this video and article to install your Wyze Solar Cam Pan.
What's in the box?
Note: A 5V/2A power adapter is required to charge Wyze Solar Cam Pan using an outlet.
  1. Follow along in the Wyze Solar Cam Pan Setup Guide. Once successfully paired, tap Next.
  2. Ensure you have the required tools. Tap Next.You will need a ladder and a Philips-head screwdriver.
  3. Review the series of installation tips, tapping Next on each.Avoid pointing the camera at trees and busy roads.Position your camera for better motion detection.Mount the camera 7-10 feet up, angled 30° down.
  4. Check your Wi-Fi Strength. Tap Next.
  5. If you have a strong connection, tap Next.
  6. Choose how you'd like to install your Wyze Solar Cam Pan and solar panel.Tap Install Together to attach the solar panel to the camera before mounting.Tap Install Separately to mount the solar panel and camera separately.
  7. Once installation is complete, follow the in-app instructions to complete setup.
  8. You're all set! Tap Done.
Before you begin setup:
  2. Connect your device to a 2.4 GHz Wi-Fi network, and enable BluetoothⓇ.
  3. Unpack your Wyze Solar Cam Pan box, removing all plastic and packing materials.Be sure to remove the plastic film from the lens.
  4. Plug the camera into power using the provided Type-C cable, and a 5V/2A adapter (not included).You must fully charge Wyze Solar Cam Pan before setup and installation.The camera’s status light will turn solid red while charging, and solid blue when charging is complete.
To set up your Wyze Solar Cam Pan:
  3. Tap Cameras > Pan and Tilt Camera > Wyze Solar Cam Pan.
  4. Ensure that your camera is fully charged. Tap Begin Setup.The camera's status light will be solid red when charging, and solid blue when fully charged.
  5. Single-press SETUP on top of the camera. The camera will say "ready to connect." In the app, check the box next to It said, Ready to connect".
  6. Tap Next.
  7. If BluetoothⓇ hasn't been enabled, you will be prompted to allow BluetoothⓇ and location access. Tap Next.If BluetoothⓇ and location access has already been enabled, it will skip to the next step.
  8. The app will automatically begin searching for and pairing with your Wyze Solar Cam Pan.If you have multiple Wyze Solar Cam Pans, select the correct camera by tapping the MAC address that matches the address on the top of the camera.
  9. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.Tap the icon in the password field to display the password to ensure it was entered correctly.
  10. Your device will continue pairing. Once paired, tap Next.
  11. Once connected, the app will show an installation guide with placement tips.
    Check out: Wyze Solar Cam Pan Installation GuideIf you want to use the installation guide now, tap Next.If not, tap Skip.
  12. Now it's time to set up your Home Waypoint, your cam's default view. Tap Continue.The Home Waypoint is required for this initial setup.Once your camera connects to the live stream, the camera will automatically calibrate for accurate positioning.
  13. Use the arrows in the app to pan/tilt your camera until you reach your desired Home position. Tap Set and then tap Next.Camera mounted upside down? Tap Rotate 180° to flip the live stream.
  14. Name your camera using the text field, or by choosing a suggestion. Tap Next.
  15. You may be prompted to try a Wyze security plan, if you're not already a subscriber. Tap Continue.
  16. Set up some automations on the Things to Try page, or tap Skip then Done.
  17. Enjoy your new Wyze device!
You’ll find the status light on the front of Wyze Solar Cam Pan, to the right of the lens. The charging indicator light is on the back of the camera.
⚡️ All Wyze devices have a handy status light that helps determine what state the device is in.
Wyze Solar Cam Pan Status Light Guide
Wyze Solar Cam Pan Status Lights:
  • Flashing red – The device is ready to set up.
  • Flashing red and blue – The device is connecting to the network.
  • Solid red – The device has detected motion or is live streaming.
  • Solid blue – Setup was successful; the device is powered and fully connected.
Wyze Solar Cam Pan Charging Indicator Lights:
  • Solid red – The device is charging.
  • Solid blue – The device is fully charged.
