Résistance aux intempéries IP65
Support facile à 360°
Fonctionne à l'énergie solaire
Câble d'alimentation de 13 pieds
The solar panel converts sunlight into electrical energy to charge Wyze Cam Outdoor or Wyze Battery Cam Pro.
The maximum power output is 2.5 watts.
Mount the solar panel where you get the most sunlight during the day. Make sure it’s not in a shaded area and avoid placing it directly under a tree. Tree sap, falling leaves, and large shadows can greatly reduce the solar panel’s efficiency.
For the most sunlight, position your Wyze Solar Panel so that it’s facing south and is tilted upward at a 30º angle.
No, we do not recommend using Wyze Solar Panel with other Wyze cameras. This is only compatible with Wyze Cam Outdoor and Wyze Battery Cam Pro.
Wyze Solar Panel is an accessory for Wyze Cam Outdoor and Wyze Battery Cam Pro to extend its battery life. We do not recommend using it to charge other devices.
Depending on the intensity of the sunlight, the solar panel is unlikely to perform well in cloudy or rainy weather.
Yes, Wyze Solar Panel is IP65 weather resistant and dustproof but is not waterproof.
No, Wyze Solar Panel is an accessory for Wyze Cam Outdoor and Wyze Battery Cam Pro to extend its battery life and is not related to the Base Station. Your Base Station needs a constant power source to keep your Wyze wireless cameras online.
Puissance continue
Prolongez la durée pendant laquelle votre caméra Wyze peut enregistrer sans avoir à la ramener à l'intérieur pour la recharger.
Support Freestyle 360°
Trouvez l'angle parfait pour une exposition solaire maximale. Résistance aux intempéries IP65 - Résistant aux intempéries et à la poussière.
Câble d'alimentation longue portée
Un câble d'alimentation étanche de 4 mètres offre une flexibilité de montage optimale.
