Résolution QHD 2,5K + Vision nocturne couleur
Chaque détail est visible clairement en couleurs éclatantes, de jour comme de nuit.
Sécurité intérieure/extérieure
Placez-le n'importe où grâce à sa résistance aux intempéries IP65.
Projecteur à activation par mouvement
Déclenchement automatique du voyant LED et de l'annonce vocale pour une sécurité renforcée.
Détection de personnes et plus encore
Avec Cam Plus, vous bénéficiez d'un stockage vidéo illimité et d'une détection IA avancée.
Wyze Cam v4 is our best camera yet, with super-clear, 2.5K QHD resolution and enhanced Color Night Vision. Our new audio technology now removes harsh and static sounds better than ever before. You can use Wyze Cam v4 indoors and outdoors, and use its built-in spotlight and Motion Warning feature to deter intruders. With Wi-Fi 6 capabilities, you can get better connectivity, and with Smart Focus on the Live stream, you can catch important details in motion while still viewing the bigger picture.
Wyze Cam v4 is a wired camera. It is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Yes, Wyze Cam v4 is IP65-rated and can be used both indoors and outdoors.
2.5K QHD (2560x1440).
No, Wyze Cam v4 only supports 2.4 GHz networks.
Wyze Cam v4 is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Yes, Wyze Cam v4 is compatible with Wyze Web View.
Wi-Fi 6 offers better range, handling of congestion, and higher connection speed. For example, the max capacity of Wi-Fi 5 is ~80 feet vs WiFi 6 at ~150 ft, and the number of streams for Wi-Fi 5 is 8 streams vs Wi-Fi 6 at 12 streams. If you are interested in a Wi-Fi 6 router, check out our Wyze Mesh Router and Wyze Mesh Router Pro.
Yes, Wi-Fi 6 is backwards compatible.
No, Wyze Cam v4 is powered via a USB cable.
Day: 20 frames per second (fps)
Night: 15 fps
Yes. While it's not waterproof, it is weather resistant and safe to use outside. Indoor and Outdoor IP65 rated.
Wyze Cam v4 works with the following accessories: Wyze Lamp Socket, Wyze Cam Window Mount, Wyze Cam Outdoor Adapter v1 and v2, and microSD cards up to 512 GB.
Smart Focus is a new feature that adds a smaller view of the Live stream, while the camera focuses on what matters - motion. When motion is detected, you will have two views of the Live stream at the same time.
No. Wyze Cam v4 is not compatible with our home monitoring service, but it's on the wish list!
À performances égales, la Wyze Cam la plus nette jamais conçue.
Capturez des images et des vidéos plus détaillées grâce à la clarté de la haute définition 2,5K Quad.
Plus de sécurité grâce à la vision nocturne couleur.
Un matériel amélioré perce l'obscurité et révèle des détails stupéfiants en conditions de faible luminosité, invisibles à l'œil nu. C'est comme donner à votre appareil photo une vision de super-héros !
Placez-le n'importe où.
La Wyze Cam v4 fonctionne par tous les temps grâce à son indice de résistance aux intempéries IP65.
Communication bidirectionnelle améliorée
Conversation plus claire.
Le codage audio avancé (AAC), un amplificateur plus puissant et un microphone amélioré s'associent pour offrir la meilleure qualité audio jamais vue sur une caméra Wyze.
Projecteur et sirène intégrés
Plus de sécurité la nuit.
Dissuadez les intrus ou éclairez votre chemin grâce à un projecteur à détecteur de mouvement. Activez la sirène puissante pour dissuader les intrus de s'enfuir.
Enregistrez chaque seconde
Enregistrement 24h/24 et 7j/7 avec carte microSD.*
Ne manquez rien grâce à l'enregistrement local continu sur carte microSD jusqu'à 256 Go. Aucun abonnement requis.
Cartes MicroSD
Ajoutez une carte microSD Wyze pour enregistrer des jours de données locales.
Accessoires compatibles avec la Cam v4
Le meilleur ne cesse de s'améliorer.
Connectez-vous via Bluetooth®
Facile à installer.
Plus besoin de scanner de code QR. Profitez d'une installation simplifiée grâce à Bluetooth®, qui offre également la possibilité de l'utiliser avec d'autres appareils domotiques.
Support magnétique sans vis
Facile à installer.
Rangez les outils électriques. Le montage est facile grâce à une base magnétique et une plaque de fixation métallique.
Compatible avec les assistants intelligents
Compatibilité avec Alexa, Google Assistant et IFTTT.
Un confort et une personnalisation à portée de main grâce à des intégrations comme Amazon Alexa, Google Assistant, IFTTT et Wyze Rules.
ZOOM AUTOMATIQUE AVEC IA
Suivi avec Smart Focus.
Concentrez-vous sur l'essentiel, tout en gardant une vision d'ensemble.
Découvrez pourquoi la v4 est la meilleure Wyze Cam à ce jour.
Encore plus de fonctionnalités à apprécier.
Bénéficiez d'une connexion plus stable et plus fiable, même à grande distance. Routeur Wi-Fi 6 requis.
Détectez les mouvements et les sons grâce à la Wyze Cam v4. Elle envoie une alerte à votre téléphone et commence à enregistrer dès qu'un mouvement ou un son est détecté.
Surveillez des zones spécifiques pour détecter les mouvements et ne recevez de notifications que lorsque c'est important.
Recevez une alerte dès que votre Wyze Cam v4 détecte le déclenchement d'un détecteur de fumée ou de monoxyde de carbone. La Wyze Cam enregistre une vidéo pendant ce temps.
Choisissez la meilleure caméra à brancher pour vous
La détection intelligente est incluse dans nos abonnements. Chaque caméra Wyze est équipée de la détection de mouvement, mais nos abonnements vous offrent des fonctionnalités supplémentaires comme la détection de personnes, d'animaux, de colis et de véhicules. Vous bénéficiez également de la détection sonore basée sur l'IA.
* La Wyze Cam v4 est câblée, ce qui permet une alimentation et un enregistrement continus .
** Nécessite l'adaptateur secteur extérieur Wyze (vendu séparément) pour une utilisation en extérieur.
** Nécessite une carte microSD (vendue séparément).
