Certaines offres et certains contenus varient selon la région. Vous parcourez actuellement le site Canada.
1 de 4
Capteur et sonde de fuite Wyze Sense
Soyez informé(e) des fuites.
Style
$68.99CAD
Stock faible : 76 restant
Recevez-le dès
Utilisez un code postal de 6 caractères, par exemple L6Y 0P5.
FREE shipping on orders $99+
Garantie prolongée de 18 mois
Soyez averti(e) en cas de fuites. À utiliser avec Wyze Sense v2 ou Wyze Home Monitoring.
Voir les détails complets
No, these sensors are not standalone product and must be paired with a Wyze Sense Hub to function. Need a Wyze Sense Hub? Check out the Wyze Home Monitoring Core Starter Kit.
No, but the leak and climate sensors will not work without the Wyze Sense Hub (available with a subscription to Wyze Home Monitoring). If you have a hub but no active subscription, you will still be able to use your leak and climate sensors.
Yes, all Wyze Leak Sensors can work without the Wyze Leak Sensor Probe. Wyze Leak Sensor Probe will not be able to operate without a Wyze Leak Sensor.
32-104 F (0 to 40 C)
≤ 85% at 86°F (30°C)
The range is up to 500 feet in ideal conditions. Please keep in mind that walls and other interference between the sensors and hub may decrease this range.
No, these sensors are incompatible with Wyze Sense v1. They must be paired with a Wyze Sense Hub, found in the Wyze Home Monitoring Core Starter Kit.
Yes, the Wyze app is able to differentiate between the leak sensor and leak sensor probe. You can turn off this feature if you prefer.
Yes, but the accuracy of the sensors will be decreased and it is not recommended.
No, these sensors are for indoor-use only.
You'll be able to set notifications for temperatures between 32-104º F (0-40º C) and humidity from 0% to 85%.
