1 of 7
Wyze Video Doorbell Pro
Battery-powered HD smart doorbell with 30 second install.
Check out the newer model:
  • 1536 x 1536 HD+ Resolution
  • Up to 6-month battery life on a single charge.
  • Flexible installation: Go wire-free or use existing wiring.
  • Local storage via microSD card (supports up to 256GB).
  • Includes Motion-Activated Voice Deterrence and Two-Way Audio.
  • IP65 weather resistance for year-round protection.
Get Battery Doorbell
Option
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
$236CAD
Low stock: 60 left
FREE shipping on orders $99+
Wider view. Higher resolution. Extraordinary price. Wired or Wireless with battery power. Install in 30 seconds.
  • Charging battery full.
    Wire-Free
    Don't deal with the hassle of wires or power tools. Go battery-powered.
  • A black background with a white star icon.
    30-Second Install
    No screws required. Includes 3M adhesive and mounting plate.
  • A black and white image of a camera lens shutter.
    Ultra Wide View
    Don't pick between seeing a person's face or packages on the ground. See it all.
  • A black background with a white microphone icon.
    Two-Way Audio
    Communicate with visitors through the built-in speaker.
Wyze Video Doorbell Pro Specs
Color & Materials
  • Doorbell color: White, with black accents
  • Chime color: White
  • Body: Polycarbonate
  • Lens: Glass + Plastic
Dimensions & Weight
  • Doorbell: 141 mm x 46.5 mm x 28 mm (5.5 in x 1.8 in x 1.1 in)
  • Chime Pro: 69.85 mm x 41.27 mm x 69.85 mm (2.7 in x 1.6 in x 2.7)
  • Doorbell weight: 210 g
  • Chime Pro weight: 100 g
Night Vision
  • IR Lights: 6 x 850mm
  • Day/Night Vision
  • Color Night Vision
Video & Image
  • Resolution: 1440x1440p Full HD
  • Field of view: Horizontal 150°, Vertical 150°
Audio
  • Mic: ECM
  • Speaker: 80 dB, waterproof
  • Simultaneous 2-way talk
Battery
  • Battery life: 3-6 months of battery life with normal use
  • Battery spec: 2x3250 mAh/7.4V rechargeable batteries (non-removable)
  • Can be used as a wireless camera (100% battery-powered/wire-free) or installed by wired connection.
Connectivity & Compatibility
  • 2.4 GHz and 5 GHz WiFi
Weather & Temperature
  • IP65 Weather resistant
  • Operating temp: -4℉ - 120℉ (-20°C - 49°C)
Certifications
  • FCC, IC, UL and IP 65 Certified
Warranty
  • 1-Year
  • Wyze Video Doorbell Pro ×1
  • Wyze Chime Pro ×1
  • Back Plate For Screws ×1
  • Back Plate For 3M Tape ×1
  • 3M Tape x1
  • T8 Screwdriver ×1
  • Wire Nuts ×3
  • Bracket Screws ×3
  • Extension Wires ×2
  • Expansion Tubes ×3
  • USB Charging Cable ×1
  • Quick Start Guide ×1
It takes ~30 seconds to use the included 3M adhesive to mount the doorbell. Mounting the doorbell on a wooden door frame with the included screws should take under 5 minutes.
No technician is required for installation, even if you choose to use the included hard-wired option for your existing doorbell wiring.
Anywhere near your front door is a great choice since no wires are needed when you go fully wire-free. Make sure the height you choose is comfortable for visitors to press the button on your new doorbell.
The FOV is 150º horizontal and 150º vertical. You can see almost anything in front of your door, head to toe, including packages on the ground.
Yes, our wire-free doorbell is powered by internal, non-removable, lithium-ion batteries. The battery life is 3-6 months with normal use, and you can recharge the doorbell using the included USB cable.
Yes, and you can receive notifications whenever motion is detected (using the body-heat infrared sensor). With a subscription to Cam Plus, you’ll be able to configure alerts to detect people, pets, packages, and more.
Yes. With an annual or monthly subscription to Cam Plus, Wyze Doorbell Pro will have the latest AI features, including Person Detection, Package Detection, Vehicle Detection and Pet Detection. Also, Cam Plus enables the doorbell to record full-length event videos.
Yes, compatible wiring will allow the doorbell to charge while it’s mounted. Having constant external power will allow your doorbell to record an additional 3-6 seconds of pre-roll video before an event, allowing you to see more context for a video clip.
Yes, one Wyze Chime Pro is included.
Yes, Wyze Video Doorbell Pro is IP65-rated as weather resistant for outdoor installation. This means that it is "dust-tight" and protected against water sprays from any angle.
Yes, you can adjust the volume in the Wyze app, in your doorbell settings.
Yes! We've integrated with the most popular smart home systems. Use your Amazon Echo smart speakers as doorbell chimes and be able to hear chime from throughout your house. We the Wyze Video Doorbell Pro you can also send live video feeds of people at the door to your Echo Show and Google Home devices.
Cam Plus allows you to see a live feed of anyone at the door, whether they're knocking or just standing around outside. This makes it easy for you to track who's coming and going without ever having to leave your comfort zone or worry while being away from home.
Battery-powered front porch protection.
Designed from the ground up to deliver a luxurious user experience, Wyze Video Doorbell Pro can be easily installed wired or wire-free. Easily mount with screws or the screw-free adhesive plate and quickly view it all from anywhere in crystal-clear HD resolution.
A person holding a white Wyze camera.
  • A white background with a logo on the edge.
    “Punches well above its price point.”
A doorway with a welcome mat and a house with a flag.
Welcome mat? You can see that too.
Wyze Video Doorbell Pro features a head-to-toe, ultra-wide viewing angle, so not only can you see the package at your doorstep, but even the house down the street.
A man is standing on a set of stairs and looking at his phone.
Faster notifications with a Wi-Fi Extender chime.
Most battery-powered video doorbells have sluggish notifications.
Ours includes a dual-band Wi-Fi Extender chime which stays connected to both your doorbell and Wi-Fi for lightning-fast notifications while also conserving your doorbell's battery life.
A Wyze device with a blue screen displaying a message.
Smart detection alerts with Cam Plus.
Get smarter notifications with Cam Plus like Person, Package, Vehicle, and Pet Detection. Unlock unlimited video recording and exclusive discounts on Wyze products.
Integrated with Alexa and Google.
Use your Amazon Echo smart speakers as extra doorbell chimes throughout your home. Command live video feeds to appear on your Echo Show and Google Home devices, even get an alert from Alexa if a person is detected at your door, with Cam Plus.
A white vase with flowers in it.
A small camera with a blue light on it.
Motion-activated security light.
When motion is detected, a security light around the doorbell's button will gradually glow blue to alert anyone at your front door that they are on camera and being recorded.
A man and a woman are standing in front of a door with a smart lock.
Quickly tell the deliver driver where you want your package placed by simply pressing the "talk" button in the Wyze app.
You can also use preset quick responses to have the doorbell say things like:"Be there shortly" or "Leave the package at the door."
A person standing in a room with a white wall and a small speaker on the wall.
Hear your doorbell ring, chirp, or bark.
Choose between 20 unique tunes and 8 sound levels to find the perfect chime for you, even scare off potential intruders with a dog bark.
✓ Chime Included
Unlock wyze lock bolt from anywhere with wyze doorbell pro video
Unlock from anywhere.
Pair with the Wyze Lock Bolt.
Knock, knock 🤝 Open sesame. A new integration let's you securely unlock Wyze Lock Bolt from anywhere when paired with Wyze Video Doorbell Pro.
Shop now
Compare Doorbells
Compare Doorbells
Wyze Video Doorbell Pro: A battery-powered HD smart doorbell with 30 second install.
from $74.99 $119.98
A black camera with a blue circle on the front.
Wyze Video Doorbell v2
from $59.99 $84.98
Resolution
1563 x 1563 (HD+)
Front: 2048 x 1536 (2K) / Bottom: 1920 x 1080
1440 x 1440
2048 x 1536 (2K)
Field-of-View
H: 150°, V: 150°
Front H: 132°, V: 100° / Bottom H: 121°, V: 60°
H: 150°, V: 150°
H: 135°, V: 103°
Chime
Existing + Auxiliary
Existing
Auxiliary
Existing
Power Option
Battery + Wired
Battery + Wired
Battery + Wired
Wired Only
3P Integration
Amazon Alexa, Google Home
Storage
Local & Cloud
Local & Cloud
Cloud Only
Local & Cloud
View
View
View
View
