1 of 14
Wyze Indoor Cam Pan
Wyze Indoor Cam Pan
Affordable 2K pan and tilt security
Quantity
$39.98 $59.98CAD
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Meet your budget-friendly, robotic security guard that spins, stalks, and secures your space in stunning 2K HD resolution. With a full 360° pan and 103° tilt, it leaves absolutely zero blind spots for mischief, using advanced AI to track the puppy turning your rug into confetti while completely ignoring the swaying curtains. Add in fast Bluetooth pairing for frustration-free setup on 2.4 GHz Wi-Fi. Plus clear two-way audio with a built-in siren to send snoops packing, and 24/7 continuous microSD recording, and you’ve got a powerhouse smart camera that works overtime so you don't have to.
  • A black background with a white logo.
    2K HD + Enhanced Night Vision
    See everything in crystal-clear HD quality.
  • Black background with white text.
    360° Pan/103° Tilt Range
    Leave no blind spots unmonitored.
  • A black background with a single white dot in the center.
    Quiet AI Motion Tracking
    It follows the movement without waking the room.
  • A black background with a two way audio system.
    Two-Way Audio + Loud Siren
    Speak clearly and warn intruders.
Color & Materials
  • Color: White
  • Finish: Matte
  • Body: Polycarbonate + ABS
  • Lens: Glass + plastic
  • Image Sensor: 3M, 1/2.8”, FSI
  • LED indicator: Front. Red + Blue
  • Night Vision: 4 IR LEDs (940 nm)
Dimensions & Weight
  • 60 mm x 62 mm x 120 mm (2.36 in × 2.44 in × 4.72 in) (L × W × H)
  • 235 g (0.52 lbs)
Video
  • Video Encoding: H.264
  • Video FPS: Daytime - 20 fps; Nighttime - 15 fps
  • Video Resolution: 2304 x 1296 (2K)
View Range
  • 360° horizontal, 103° vertical
Field-of-view
  • DFOV 100.6°, HFOV 81°, VFOV 43°
Additional Details
  • Digital Zoom: 8x
  • Audio: Built-in speaker and microphone; 2-way audio; Noise & Echo cancellation
Power
  • Power Cable Length: 6 ft (1.8 m)
  • Power Adapter Input: 100-240V(AC), Output: 5V DC, 1.5A
Connectivity & Compatibility
  • 2.4 GHz Wi-Fi & BLE, WiFi 6
  • Phone Compatibility: Android 10.0+, iOS 16.0+
Storage
  • Supports up to 512 GB microSD in ExFAT format
Weather & Temperature
  • Operating temp: -14° F - 113° F (-10° C - 45° C)
  • Weather resistance: Indoor only
Certifications
  • CP65, ROHS, TSC, UL62368-1, FCC, IC
Language
  • English
Warranty
  • 1-Year
  • Wyze Indoor Cam Pan x 1
  • USB Cable x 1
  • Power Adapter x 1
  • Mounting Kit x 1
  • Wall Bracket x 1
  • Mounting Sticker x 1
  • Quick Start Guide x 1
Wyze Indoor Cam Pan is your affordable, indoor-only monitoring solution.
No, Wyze Indoor Cam is not wire-free.
2K (2304 x 1296).
Yes, the camera lens will return to its previous position.
Day: 20 FPS; Night: 15 FPS.
No, Wyze Indoor Cam Pan is designed for indoor-use only. It is not IP-rated.
No, Wyze Indoor Cam Pan supports 2.4 GHz networks only.
Wyze Indoor Cam Pan is compatible with Wyze Web View, and it doesn't require a subscription. However, for more than 1 camera in the view, you need a subscription.
Wyze Indoor Cam Pan is not compatible with Wyze Lamp Socket or Wyze Lamp Socket v2. This camera is designed for indoor use only and should not be installed outdoors or exposed to the elements.
Wyze Indoor Cam Pan can show more natural color detail in low-light environments when there is enough ambient light. To try this, turn off Night Vision in the Wyze app.
You can turn the camera off in the Wyze app. You can also create a schedule to have the camera turn off automatically at a set time.
  • A white Wyze indoor camera is placed on a bookshelf.
    Playroom patrol
    Keep half an eye on the kids in the next room while you get dinner going.
  • A Wyze indoor camera is sitting on a table.
    Entryway watch
    Point it at the front hall to see deliveries land and the door open.
  • A white dog is laying on a white bed.
    Pet check
    Find out what they actually do all day. Spoiler: it's the couch.
So quiet it's almost invisible.
Whisper Quiet
The motor is softer than a hushed voice across the room. Check the nursery without starting the whole bedtime process over.
Smooth, Startle-Free Tracking
It glides to keep your kid or your dog in frame. No jerking, no grinding, nothing that makes a light sleeper open one eye.
Made for Naptime and Bedtime
Calm and quiet enough to check in any time of night, so you get peace of mind, and they get their rest.
Most cameras watch one corner and call it security.
This one turns. Left, right, up, down, following a crawling baby or a sprinting puppy instead of watching them leave the frame.
A white camera is mounted on a shelf in a child's room.
Check the nap without cracking the door.
✔️ Pan across the whole crib. Tilt down for a sleeping face, sweep the room when they're up and exploring.
✔️ Hum a lullaby from the kitchen. Two-way audio lets you soothe them before you even reach the stairs.
✔️ See clearly in the dark. Night vision keeps the lights off and the little one asleep.
Wyze Indoor Cam Pan Shopify 07 f8facc96 bb74 431d be4b 8357ff9f65ff
Watch the zoomies from your desk.
✔️ Follow them room to room. They don't stay in one spot, and neither does the camera. Pan to wherever the noise is coming from.
✔️ Say "off the couch" from the office. Two-way audio lets you talk them down before the cushion's a goner.
✔️ The lights-off hours are covered too. Night vision shows you the whole overnight story without disturbing them.
Crisp 2K HD View
Sharp, detailed video for everyday peace of mind — clear enough to read the room, efficient enough to not eat up your Wi-Fi bandwidth.
Wyze indoor cam pan shopify 06.
360° Pan/103° Tilt AI Motion Tracking
A camera pointed at one wall is useless when the dog is dismantling a throw pillow just off-screen. This one goes a full 360° around and 103° up and down, and the AI keeps the moving thing in frame while it does it.
A small white camera with a black lens.
Physical Privacy Mode
Flip it on in the Wyze app and the lens physically rotates to face the floor, then powers down. You don't have to trust a software toggle. You can look at it and know.
  • Wyze Indoor Cam Pan Shopify 23
    Know what matters.
    Smart Detections identify pets, people, packages, and vehicles so you get alerts that matter—not just “Motion Detected.” Add Cam Plus for cloud video recordings and smarter alerts.
  • A person is holding a Wyze indoor camera.
    24/7 local recording. Your own microSD card.
    Record 24/7 locally with a microSD card up to 512 GB (sold separately). Add AI alerts and cloud backup with Cam Plus.
  • A Wyze indoor camera is displayed in a store.
    Patrol your room with Pan Scan and custom waypoints.
    Set up to four waypoints in the app and let it walk its own beat in a loop. It's a night watchman that never asks for a break.
  • A garage with a car parked in it.
    Faster pairing. Reliable streaming.
    Wi-Fi 6 plus Bluetooth holds the connection on crowded networks and gets you set up without scanning a single QR code.
1 of 4
  • A person is plugging in a white device into a wall socket.
    Plug it in.
    Six feet of cable and a wall adapter, both in the box.
  • A person holding a smartphone with a Wyze Indoor Cam app open.
    Pair via Bluetooth.
    Open the app, tap the camera, skip the QR code entirely.
  • A person holding a smartphone with a picture of a living room on the screen.
    Place & watch.
    Set it on a shelf or mount it on the wall. You're live from anywhere.
1 of 3
A smartphone screen showing a list of rules for a smart home system.
A smartphone with a purple background and a 24 hour clock on the screen.
A smartphone screen with a CO alarm setting.
Wyze Indoor Cam Pan Shopify 26.
Even more features to love.
We made your favorite pan camera even better.
Set rules that actually make sense. Schedule your camera to turn on when you leave for the office, or automate it to flip on the living room smart lights the second it detects motion at night.
Look & listen for motion & sound. Wyze Indoor Cam Pan sends your phone an alert and begins recording when either is detected.
Receive an alert the moment Wyze Cam Pan v4 hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
Keep your phone in your pocket and use your voice to pull up a live feed on your smart display. It plays perfectly with Amazon Alexa and Google Assistant, because lifting a finger is a chore you didn't sign up for.
Compare Products
Compare Products
Lenses
Resolution
Field-of-View
Frame Rate
Night Vision
Spotlight
Sensor
IR Lights
Setup
Weather Resistance
Privacy Mode
Connectivity
Motion Warning
AI Motion Tracking
FREE shipping on orders $0+
