1 of 18
Wyze Bulb Cam Pan Color
“Excellent camera at a good price”Paul L.
4,000+ original Bulb Cam reviews4.2out of 5stars
Quantity
13M+ Households Trust
$149.98CAD
Mood lighting meets peace of mind. Wyze Bulb Cam Pan Color combines colorful lighting with a pan-and-tilt security camera in one clever bulb. Set the vibe and keep an eye on things. Now that’s a bright idea.
Please measure your sconce before ordering. Click to learn more.
  • A Light Bulb +
    Security Camera
  • 360º pan x 180º tilt
  • 2.5K QHD Color Night Vision
  • 16 Million Colors &
    Tunable White
  • AI-Powered
    Motion Tracking
  • Privacy Mode
  • Extends up to 4.2 in
  • 2 Way Audio
  • Siren
  • Local Recording to MicroSD Card
  • Warranty
Materials & Colors
  • Color: White
  • Finish: Matte
  • Camera Dimensions: 70 mm (H) 70 mm (W) x 250 mm (D) collapsed
  • Camera Weight: 565 g (1.25 lbs)
  • Telescopic Rod Length: 3 cm
Display
  • Resolution: 2.5K QHD(2560 x 1440p)
  • Frame Rate: Daytime 20 FPS, Night 15 FPS
  • Field of View: 115.8º D, 98.5ºH, 53.1ºV
  • Pan Tilt Range: 360º pan x 180º tilt
  • Digital Zoom: 8x
Night Vision
  • Color Night Vision
  • IR Lights: 4 * 850nm
Audio
  • Simultaneous 2-way Talk: Yes
  • Siren: 100 db @ 10cm
Power
  • Power Input: 120V AC E26 Socket
Sensor & Lens
  • 1/3"
  • Aperture: F 1.6
LED Indicator
  • Red & Blue led Indicator
Bulb Light
  • 1800K - 6500K Adjustable + 16M RGB Colors
Connectivity
  • Wi-Fi 6 Dual-Band (2.4GHz + 5GHz)
Storage
  • Supports up to 512 GB local storage (microSD card required)
  • Cloud storage (Subscription required)
Temperature
  • Storage Temperature: -4°F-122°F (-40°C-80°C)
  • Operating Temperature: -40°F-158°F(-40°C-70°C)
Weather Resistance
  • IP65 Weather Resistant (camera part)
  • Indoor/Outdoor
Phone Compatibility
  • Android 10.0+
  • iOS 16.0+
Certifications
  • FCC, IC, UL, IP65 (Camera part)
Languages
  • English
Warranty
  • 1-Year
Packaging
  • Dimensions 90*90*390 (mm)
  • Weight 0.8kg
  • Wyze Bulb Cam Pan Color x 1
  • Switch Cover x 1
  • Socket Adapter x 1
  • Quick Start Guide x 1
Wyze Bulb Cam Pan will turn heads with an electrified pan-and-tilt camera and a bright, tunable full-color bulb in one clever device. Capture sharper details with 2.5K resolution, stay connected via dual-band Wi-Fi (2.4 GHz and 5 GHz) with Wi-Fi 6 support, and gain peace of mind with Privacy Mode. It’s a smarter, brighter way to light your space and monitor what matters.
Yes, Wyze Bulb Cam Pan is IP65 weatherproof and can be installed in outdoor sconces. However, most socket adapters are not waterproof. Please ensure the socket does not come in direct contact with water unless using a waterproof socket adapter.
Yes, a brand new feature for Wyze Bulb Cam Pan is the ability to pan-and-tilt the camera using the Wyze app, just like your other Wyze Cam Pan devices. Wyze Bulb Cam Pan can pan up to 360º horizontally and tilt up to 180º vertically.
Yes, the bulb in Wyze Bulb Cam Pan is dimmable and can be set up to 1100 lumens in the Wyze app. It also has Ambient Light Mode, which sets the bulb to low for general exterior lighting.
Yes, you can adjust the color temperature on Wyze Bulb Cam Pan between 1800K (warm white) to 6500K (daylight white).
Yes, with Wyze Bulb Cam Pan you have precise color control in the Wyze app - up to 16 million colors to set the vibe.
Yes, Wyze Bulb Cam Pan supports both 2.4 GHz and 5 GHz networks, and both Wi-Fi 4 and Wi-Fi 6 routers.
Yes! Once you set up your Wyze Bulb Cam Pan, you can add a Wyze Bulb Color to it in your Device Settings. You can also enable Sync Mode to control both the camera’s bulb and the color bulb together.
Wyze Bulb Cam Pan fits standard E26 sockets and requires continuous 120V AC 60Hz power, like your existing standard bulb socket.
Yes, Wyze Bulb Cam Pan includes a microSD card slot for local storage, allowing continuous recording. It supports microSD cards up to 512GB in exFAT format.
Yes, you can set this camera to Privacy Mode, which points the camera lens away and turns off the audio for privacy.
Yes, the camera lens will return its previous position.
Wyze Bulb Cam Pan only links with Wyze Bulb Color, and does not work with Wyze Accessory Bulbs.
Wyze Bulb Cam Pan measures about 70 mm x 70 mm x 280 mm when fully extended. Your sconce must have an internal diameter of at least 75 mm and an internal depth under 250 mm to install this device.
For larger sconces, use Wyze Lamp Socket with Wyze Cam Pan v4.
Day: 20 FPS ; Night: 15 FPS.
2.5K HD (2560 *1440P).
Yes. The Wyze Bulb Cam Pan Color has two modes, Ambient Light and Motion Light, each with its own schedule, color, and brightness settings. You can keep a warm, soft light on all night and have it brighten when a person or vehicle is detected.
No. The Wyze Bulb Cam Pan Color is compatible with Wyze Color Bulbs. You can sync any Wyze Color Bulbs on your account with it, and link or unlink them at any time.
Use the Wyze app to turn the light on or off and to change its color and brightness. You can also use Alexa to turn it on or off.
Note: Do not use a dimmer switch to adjust brightness. It will cause the light to flicker.
Not your Grandma's porch light
it feels so good to
Never Wonder.
Don't take our word for it
13,000,000+
Households trust
Reviews from original Wyze Bulb Cam customers
Original Bulb Cam
    Easy install
    Twist. Pair. Done.
    Outdoor security for people that hate wires. And tools.
    Install guide
    Pair it in the Wyze app first. Check the view and Wi-Fi connection before mounting, then position the detachable panel toward direct sunlight.
    What you need
        Do you have a wrist? Great! You’re qualified to set this up.
        Follows the motion, smoothly.
        AI motion tracking follows people and pets with buttery smooth panning, and we mean BUTTERY smooth panning. You can also auto-scan between custom way points.
        Every white.
        Every color.
        Every mood.
        1100 lumens and 16M colors to match the mood, the season, the sports team, or that beige the HOA made you paint your fence.
        Bright.
        Or just right.
        Turn it up to light the whole entry, or dim it down for a softer glow.
        2.5K resolution +
        Color Night Vision
        Crispy 2.5K picture gets all the details, all the time. Day, night, 3:00 AM when you swear you heard something. Especially that one.
        Rolling storage
        on a microSD card
        168 hours of video a week. Nothing uploads to the cloud, but rumor is St. Peter screens every second in your life recap vid. So in a way it does.
        Card sold separately. Cloud storage options + AI features are available with a paid plan.
        Privacy mode.
        One tap to make it spin around and stare at its own butt when you don’t want it to see yours. The mic shuts off too.
        Extends up to 4.2 in.
        to satisfy deeper sconces
        The rod extends 1.2 inches. The included socket adapter adds another 3 inches and lets you adjust the camera orientation. The confidence boost is immeasurable, but your sconce is measurable, so still measure before you order. Please.
        For real, please measure before ordering
        We're still gonna accept your return, but we'll both know it was preventable.
        Placeholder image 1Placeholder image 2
        • 2.76 × 2.76 × 9.8 inches collapsed, about 11 inches fully extended
          (70 × 70 × 250-280 mm)
          Measured from the base of your socket.
        • The extender adds 2 inches and we recommend leaving an inch or so for the camera to poke out below your sconce.
        • Fits open-ended sconces with a standard E26 socket and at least 3 inches (75 mm) of internal diameter
        Syncs with
        Wyze Bulb Color
        Link unlimited Wyze Bulb Color bulbs to match color, brightness, and schedule. Great for fixtures with multiple sockets, one camera bulb to rule them all.
        View Bulb Color
        Two-way audio
        and siren
        Talk to your kids, your mailman, or talk some sense into those night prowlers. If that doesn’t work, hit them with the siren.
        Bop-It
        Mode.
        You can twist It. You can pull It. You could theoretically bop-it. If the power goes out and you’re bored you can take it down and play bop-it with your friends. Nobody has ever actually used it for this, but you could be the first.
        First ten people that leave a 5 star review on wyze.com that talks about Bop-It Mode get a special prize. You deserve it anyway for reading this far down the page.
        The best of the rest.
        • Timelapse mode
        • Alexa and Google integrations
        • Device sharing
        • Detection zones
        • Honestly so much more, just buy it we are exhausted from writing about all of these features there are too many.
        Good questions
        Asked and answered
        FREE shipping on orders $0+
