1 of 9
Wyze Cam Outdoor v1
Wyze Cam Outdoor v1
Move it, mount it, record it - anywhere. Wireless.
Check out the newer model:
  • 2.5K HD w/Color Night Vision.
  • Built-in microSD slot & spotlight.
  • Removable battery.
  • Doesn't need a base station to work.
  • Indoor/Outdoor friendly.
  • More processing power. It's faster!
  • Works with Wyze Solar Panel.
  • You'll also continue to get the amazing features of Wyze Cam Outdoor: 2-way audio and traditional night vision.
Get Battery Cam Pro
Style
Item is no longer available.
  • Weather resistant icon.
    IP65
    Rain or shine. Weather resistant.
  • Charging battery full.
    2 x 2500 mAh
    Wire-free. 100% battery-powered.
  • Camera icon.
    1080P
    Livestream & recording. Cloud recordings with Cam Plus plan.
  • A black background with a white PIR motion icon.
    PIR Sensor
    Built-in motion detection technology.
Camera
Mounting method
  • Camera mounts to base via magnets. Base mounts to walls or ceilings w/ screws.
  • Camera is compatible with 3rd party 1⁄4” — 20 mount
Item dimension
  • 2.3 inch x 2.3 inch x 2.8 inch
Item weight
  • 9.8 ounces
CPU
  • 900MHz
Sensor
  • 1/2.7’
Power method
  • Battery powered
SD
  • Supports up to 256GB
Battery
Battery spec
  • 2x 2,600 mAh/7.4V rechargeable batteries
Battery life
  • 3-6 months of battery life with normal use
Operating temperature
  • Operating: -4ºF to 120ºF (-20ºC to 49ºC)
  • While charging: 32ºF to 122ºF (0ºC to 50ºC)
IP Rating
  • IP65
  • Resolution: 1920x1080 (1080p)
  • Night vision LEDs
  • 8*850nm LEDs
  • Night vision distance: Up to 25 feet
  • Camera lens aperture: F2.5
  • Camera focal length: 3.3mm
Frames per second
  • Day time video 20 FPS
  • Night-time video 10 FPS
Zoom
  • 8x digital
Video streaming
  • One base station supports up to 4 cameras
Local storage
  • MicroSD card slot on camera and base station
Base station
  • Interface port: Fast ethernet (10/100)
  • Wireless protocol: 802.11 b/g/n
  • Memory: 128M
  • Wireless security protocol: WPA/WPA2
  • SD card slot: Up to 32GB
Wyze Cam Outdoor Starter Bundle
  • Wyze Cam Outdoor x1
  • Base Station x1
  • Base Station Power Adapter x1
  • Base Station Ethernet Cable x1
  • Camera Charging USB Cable x1
  • Quick Start Guide x1
  • Screw Assembly x1
Starter Bundle + Forest Camo Skin by dbrand
  • Base Station x1
  • Screw Assembly x1
  • + dbrand Forest Camo Decal x1
Wyze Cam Outdoor Add-On Camera
  • Screw Assembly x1
We want to ensure that we offer the best possible experience at launch. We will need more time to thoroughly test support beyond 4 cameras and decide if we can allow more cameras per base station in the future. For now, if you need more than 4 cameras, you can buy another starter bundle to get an extra base station.
Yes, Wyze Cam Outdoor is compatible with Cam Plus. Use Cam Plus to remove the cooldown period, record longer Event Videos, and have more smart detection features.
Wyze Cam Outdoor is built for maximum flexibility so that you can truly put it anywhere you want even if that is outside or where there is no power outlet. Continuously recording to a micro SD card like Wyze Cam v2 will make the battery life extremely short. Because of this, we did not build this feature and Wyze Cam v2 is still the best option for this use case. However, we did build a "Scheduled Recording" feature where you can schedule specific times for the camera to continuously record to its local micro SD card or record when PIR is triggered though this will reduce battery life. This feature combined with Travel Mode will allow you to take the camera anywhere to record anything you want even if there is no WiFi available.
The cooldown period is adjustable between 1 minute, 3 minutes, and 5 minutes. The Event Video length is 12 seconds. Add Cam Plus to remove the cooldown period and record full-length Event Videos.
The battery can last up to 3 to 6 months with normal usage (about 10-20 Event alerts per day). Battery life varies based on settings, usage, and environment temperature.
With the included mounting base, you can mount the camera in either a wall-mount or ceiling-mount position. The camera and the mounting base are connected using magnets. Alternatively, the camera also has a standard 1/4-20 screw hole at the bottom and you can use any compatible 3rd-party mounting kit.
Wyze Base Station can be used wired with an ethernet cable or wirelessly with WiFi. The base station requires an ethernet connection to the router during setup. Once setup is complete, you can either keep the wired connection, or switch to a WiFi connection in the Wyze app.
The camera will function while charging. However, this is not recommended as the camera is built with the intention of running primarily off of its battery power.
The micro SD card slot on the camera is meant for the time lapse and scheduled recording features. This is meant to save videos that you intend to shoot with the camera such as a specific task continuously recorded over a couple of hours or monitoring a remote area without WiFi. This is not meant for constant continuous recording like with Wyze Cam v2.
The micro SD card slot on the base station is meant for a backup of the 12-second Event Videos. This is a good feature to use if you are concerned about the camera becoming lost, stolen, or damaged where it is mounted.
The base station is primarily used to improve the battery life by keeping the camera power consumption low. It also provides a reliable internet connection via an ethernet cable and removes compatibility issues with different router brands.
We have added a new feature for Wyze Cam Outdoor because we understand that the risk of theft is higher with products that are mounted outdoors. We built a mechanism that prevents a new account from setting up the camera if it is already paired with a Wyze account unless the original account releases it. In short, if someone steals the camera, the camera will not be able to be used again unless the owner removes the camera from their account.
Yes, the Wyze Cam Outdoor would need to stay paired with your account to prevent another person from using it. We are looking into ways to improve this experience after launch.
Originally, we looked into solving our battery problems with kyber crystals. But, due to limited supply and rebel subterfuge, we were forced to go with lithium ion batteries instead. We kept the original design after realizing that it helps improve the accuracy and function of the Wyze Cam Outdoor’s passive infrared motion detection.
The biggest differences for Wyze Cam Outdoor compared to Wyze Cam v2 is the IP65-rated weatherproofing and the built-in battery allowing it to be truly wire-free. Wyze Cam Outdoor also features a PIR (passive infrared) sensor to detect motion while Wyze Cam v2 uses a pixel comparison algorithm. We also developed a travel mode for times where there may not be WiFi available when you are using this camera. Wyze Cam Outdoor was designed to excel in a harsh environment without readily available power sources.
Yes, this camera can be used indoors. Although it is possible that a Wyze Cam v2 would be better equipped for your use case if there is a power outlet available.
Stand up to any weather.
Stand up to any weather. IP65 weather-resistant. Bring on the downpours, blizzards, and heatwaves- Wyze Cam Outdoor is built from the ground up to be a workhorse in even the harshest conditions.
A small black camera with a white frame.
Wireless. Go where wire’s can’t.
Wire-free & battery powered. Mount to the outside of your home or in your trees without running wire or searching for outlets. 2x 2,600 mAh integrated rechargeable batteries last from 3-6 months based on normal usage.*
*Normal usage is 10-20 event videos per day. Battery life varies based on settings, temperature, and usage.
Seize the day. Illuminate the night.
1080p Full HD with nightvision. Crisp video recording and live streaming with 25 ft, yard-illuminating night vision lets you see every detail on a face or whisker on a snout.
See who’s coming and going.
Wyze Cam Outdoor uses passive infrared sensors (PIR) to sense body heat signatures which reduces false alerts from things like waving branches and falling leaves. When motion is detected, you’ll get an alert from the Wyze app so you never miss a thing.
A man is standing in front of a house, looking at his phone.
Cover every corner of your home.
Low profile base station. Connect up to 4 cameras to a single bay station and view all video streams in the Wyze app. The starter bundle includes one Base Station. (Additional cameras sold separately and available at general launch.)
A white camera with a black lens.
A white room with a flat screen TV on the wall.
Man holding a box with a camera on it.
Respond in real time.
Two way audio. Ask the delivery person to hide a package behind the bushes, or scare off unwanted guests in your yard using Wyze Cam Outdoor’s built-in speaker and microphone.
A white camera on a rock.
Capture the world
Offline video recording. Staying at a hotel or backpacking in the Rockies? Travel Mode records motion & time-lapse videos locally to a MicroSD card for when you’re without an internet connection or base station.
Timelapse
Pikes Place 2019
Experiences
Mountain Rainier 2019
Behind the scenes
Set up and installation made easy.
FREE shipping on orders $0+
