1 of 7
Wyze Cam Floodlight Plug-In Mount (Color)
Wyze Cam Floodlight v2 (Color)
$132.98 $158.96CAD
FREE shipping on orders $99+
    2.5K QHD Resolution & Color Night Vision
    Capture more details day and night with 160° Wide Field of View.
  • A black screen with a 20ft icon.
    Plug-in mount with 20ft Power Cord
    Reach a outdoor-rated outlet with ease. Velcro cable strap included.
  • Install icon on a black screen.
    Easy to Install
    It's fast and easy. Just plug it in, and mount your floodlight.
    No Junction Box Required
    Skip the electrician and the construction. Plug-n-play in minutes.
Wyze Cam Floodlight Plug-in Mount
  • Colors: White and Black
  • Outdoor safe: Yes
  • Operating Temperature: -22°F to 122°F
  • Input: 110 - 120V AC
  • Power Cord Rating: SJTW (Hard service, thermoplastic cable, S: service, J: junior, T: thermoplastic, W: weather-approved)
  • Cable Wire: 18 AWG
  • Power Cord Length: 20 feet (6m)
  • Package Dimension: 153mm x 155mm x 79mm
  • Package Weight: 1.39 lbs
  • Color: White or Black
  • Finish: Matte
  • Mount: Wall/Ceiling
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • 2 dimmable LED light panels
  • 2800 total lumens of brightness
  • 5000K color temperature
  • Dimmable: Yes
  • 2K (2304 x 1296)
  • Night Vision
  • Color Night Vision
  • Hardwired 110 - 120V AC
  • -4°F - 140°F (-20°C - 60°C)
  • IP65 Water Resistance
  • Safe for outdoor use
Learn more
Connectivity & Compatibility
  • IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
Warranty
  • Warranty: 1 Year
  • 1x Wyze Cam Floodlight Plug-in Mount
  • 1x Floodlight Pro mounting kit (silicone ring, long screw)
  • 1x Mounting screw kit
  • 1x Foam tape
  • 1x Quick Start Guide
  • 1x Wyze Cam Floodlight v2
  • 1x Mounting Accessory Kit
  • 2x Bracket Screws (#6, #8, and #10)
  • 1x Ground Screw
  • 1x Floodlight Screw
  • 1x Rubber Stopper
  • 1x Mounting Bracket
  • 2x Wire Nuts
  • 1x Hook
A black security camera with two floodlights attached, mounted to a wall.
Bundle includes Wyze Cam Floodlight v2
The dark doesn't stand a chance.
Delivering 2K HD video and vibrant color night vision, this outdoor security camera ensures your home always under watch.
The expansive 160° wide-angle view and advanced motion detection eliminates blind spots.
Enjoy a well-lit exterior with powerful 2800-Lumen LEDs, and let the 105dB siren add an extra layer of security.
A person holding a white light fixture with a camera on it.
Bundle also includes Plug-in Mount
Easy to install. No junction box needed.
Say goodbye to the complexity and cost of a junction box. No need to hire electricians and handy people, or cut giant holes into the exterior of your home.
*Product featured in picture is Wyze Floodlight Pro
A flexible power solution for all Wyze Cam Floodlights.
Ditch the shock and zap (unless you're into that sort of thing). If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight. No more scary junction boxes and expensive electricians.
A white chair with a plant in a pot on the table.
Two lights attached to a wall.
Put it right where you need it.
Free thyself from the shackles of non-ideally-located junction boxes! The durable 20ft. cable reaches outdoor-rated outlets with ease. A velcro strap is included for clean cable management.
Seriously, watch how easy it is to install.
