1 of 20
Wyze Battery Cam Pro
2.5K Outdoor Cam with Spotlight
No power outlet or electrician needed. Turn this wireless cam into a solar security cam by adding a Wyze Solar Panel.
Color
Pack
Accessory
$159.98 $173.98CAD
NEW Bird Detection
Great news for Wyze Battery Cam Pro owners. Bird Detection is now available with Wyze Security Plans. Test it with a Cam Plus trial.
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
  • 2.5K HDR Video Resolution
  • Wire-Free, No Hub required
  • Integrated Spotlight & Siren
  • Radar + PIR Motion Detection
  • Removable, Rechargeable Battery Packs
  • IP65 Weatherproof
  • 2.4 & 5Ghz WiFi Support
  • A black background with a white logo for a wireless device.
    Outdoor/Indoor. Wire-Free. No Hub.
    Place it anywhere with hassle free setup.
  • A colorful logo of a person holding a shield.
    2K HDR Video with Color Night Vision
    Capture more details with enhanced video.
    Double the sensors for more accurate detections.
  • Battery
    Removable Battery Packs
    Swap and recharge to eliminate security downtime.
Color & Materials
  • Color: White
  • Finish: Matte finish
  • Mechanical Structure: PC plastics
  • Camera Lens: Optical glass
  • Camera Weight (lbs): 0.94
  • Dimensions (Inches): 2.5 x 1.8 x 3.5
Additional Details
  • CPU Speed: 500 MHz
  • Memory: 128 MB RAM
  • Mounting Methods: 1/4” - 20 standard
  • Wall mount: Included (short mount)
  • Wall Mount Dimensions: 2 in x 2 in x 2.2 in
    Wall Mount Weight: 1.5 oz (44 g)
Certifications: FCC, IC
Drywall anchors
  • Wall anchors
  • Length: 28.7 mm
  • Width: 5.5 mm
  • Drill bit size: 7/32
Screw Assembly
Philips screws
  • Length: 29.5 +- 1 mm
  • Width: 2.9 mm
  • Drill bit size: 3/64
Power
  • Power Cable Length
  • USB-A to USB-C Cable, 0.5m
  • Power Adapter: 5V, 2A (NOT INCLUDED)
Battery Pack
  • Capacity: 6200mAh
  • Charging Time: Approximately 9 hours
  • Battery Life: Up to 6 Months
  • Technology: Li-Ion
  • Connector: USB-C
  • Image Sensor: CMOS-Starlight Sensor (2560 x 1440)
  • Lens: F1.6
  • Digital Zoom: 8x
  • Field-of-View: 134°(DFOV), 108°(HFOV), 56°(VFOV)
  • Night Vision: 2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)
Video
  • Daytime: 15 FPS
  • Nighttime: 15 FPS
  • Video Resolution: 2560 x 1440 (2.5K)
  • Video Encoding: H.264
Connectivity & Compatibility
  • Bluetooth: BLE 5.1
  • Wi-Fi: 2.4 GHz and 5 GHz, 802.11a/n/g/b
Audio
  • Microphone: MEMS Digital Mic
  • Two-way Audio
  • Built-in speaker and microphone
  • Noise and echo cancellation
  • 2-way Simultaneous
    Siren, 100 dB SPL @ 0.1m
Weather & Temperature
  • Weather Resistance: Indoor and Outdoor (IP65)
  • Operating Temp: -20°C to +50°C (-4°F to +122°F), Humidity < 90%
  • Storage Temp: -40°C to +50°C (-40°F to +122°F), Humidity < 90%
Storage
  • Local Storage: Supports up to 256 GB microSD cards
  • Cloud Storage: Record to the cloud with Cam Plus
  • x1 - Wyze Battery Cam Pro
  • x1 - Wall Mount
  • x1 - USB-C Cable
  • x1 - Battery Pack
  • x3 - Screw Assembly
  • x1 - Quick Start Guide
Note: Power Adapter is not included
No, you can set up your camera directly on your 2.4 Ghz or 5 GHz home Wi-Fi network and start using your camera in minutes.
No, it’s not compatible with Wyze Base Station.
With normal use, a battery pack should last up to 6 months before recharging. Alternatively, you can purchase additional battery packs to swap as needed.
You can use the included standard 1/4" - 20 metal wall mount or purchase our Wyze Universal Metal Mount accessory for ceiling mounting. It's not compatible with the magnetic base mount on Wyze Cam Outdoor.
Yes! Continuous or motion-only local recording is available. Keep in mind that these features may greatly shorten battery life.
Learn more on how to use a MicroSD card with your Battery Cam Pro.
The fusion of radar and PIR eliminates false alarms caused by extreme weather conditions like heavy rain, snow, or intense heat. The radar sensor detects the distance of objects in front of the camera, providing precise information about detected motion to reduce unwanted alerts.
It takes approximately 9 hours to fully charge the battery.
Yes, you can use the camera normally while it's charging.
Yes, you can purchase the Wyze Solar Panel with an included USB-C adapter cable. Alternatively, you can purchase a USB-C cable if you bought the original solar panel on or before May 2023.
Yes it is.
Yes it is the same battery pack with 6200 mAh capacity.
Feature Highlight: Local recording (with a MicroSD card) is available for Battery Cam Pro
Weatherproof wire-freedom for all.
No wires. No hubs. It's the ultimate battery operated go-anywhere, see-everything home security camera. Get pro-grade protection precisely where you need it most.
1 of 5
Shop Wyze Battery Cam Pro Accessories
  • Wyze Removable Battery Pack
    Regular price $33.99 CAD
    Regular price $33.99 CADDeal $33.99
    Works with Wyze Battery Cam Pro, Wyze Duo Cam Doorbell and Wyze Palm Lock. Learn More
  • Wyze Battery Charging Dock
    Regular price $26.99 CAD
    Regular price CADDeal $26.99
    Charge up to two batteries at once. Learn More
  • Wyze Solar Panel
    Regular price From $7.99 CAD
    Regular price CADDeal From $7.99
    12W Solar Charger for Outdoor Cams Learn More
    Choose your option
    View Options
  • MicroSD Card
    Regular price From $25.99 CAD
    Regular price CADDeal From $25.99
    Choose your option
  • Wyze Universal Camera Mount
    Regular price $12.98 CAD
    Regular price $14.99 CADDeal $12.98
    A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling. Learn More
Capture more details with 2K HDR & Color Night Vision.
Day or night, every detail matters. Wyze Battery Cam Pro utilizes high dynamic range for balanced images with richer colors.
Integrated light. Intruder flight.
Light up potential intruders with 150 lumens of LED, motion-activated light. You can also manually control the spotlight in the Wyze app for extra security while you’re walking the dog at night.
Radar + PIR = A motion detection superstar.
Double the motion sensors means double the "Gotcha!" Radar and PIR combine for earlier and more precise detections. Set custom detection zones in the Wyze app for location specific notifications.
Get even smarter detections with Cam Plus.
The power to protect.
Wyze Battery Cam Pro has flexible power & mounting options.
A white toothbrush with a red button on the side.
Removable battery packs.
Taking down your camera to charge it is as tedious and wearisome as cleaning an airport urinal. Easily hot-swap battery packs and eliminate security downtime.
Add to Cart
A person is pressing a button on a black box.
Ready power with Wyze Battery Charging Dock.
Charge up to two battery packs at once with Wyze Battery Charging Dock. Sold separately.
Add to Cart
A solar panel is attached to a house.
Turn your cam into a Solar Powered Security Camera in seconds.
Nothing says, "I'd like to keep living on planet Earth" like a solar panel. Convert sun rays into power so you can leave your camera up longer with less frequent charging.
Add to Cart
A white camera with a black background.
Ceiling setup with Wyze Universal Mount.
Need to keep an eye high in the sky? Wyze Universal Mount has a longer stem for a flexible ceiling mount option. Required when mounting Wyze Battery Cam Pro to a ceiling or under an eave.
Add to Cart
Battery Cam Pro can locally record to a microSD card.
Keep motion events stored locally on a microSD card (sold separately). Add AI alerts and cloud backup with Cam Plus. Local recording impacts battery life.
A white camera with a blue light on it.
A white and blue box with a 5GHz label on it.
Connecting device
A smartphone screen with a search bar for a device.
No running by the pool!
More Pro features you'll love.
Drip. Splash. Plop. No matter the weather, this camera cannot be stopped.
No more QR code scanning. Setup is quick and easy with BluetoothⓇ.
Talk (or yell) to anyone easily with a built-in microphone and speaker.
Up and monitoring in minutes. Watch how 👇
Support Articles
Before you begin setup:
  2. Connect your smartphone or tablet to a 2.4 GHz or 5 GHz Wi-Fi network.
  3. Unpack your Wyze Battery Cam Pro, removing all plastic and packing materials.Be sure to remove the plastic film from the lens.
  4. Charge the battery pack using the included charging cable.It takes 9 hours to fully charge the battery from 0 to 100%.If the battery pack is charging, there should be one green status light.If the battery pack is fully charged, both status lights should be solid green.
To set up your Wyze Battery Cam Pro:
  3. Tap Cameras > Battery Camera > Wyze Battery Cam Pro.
  4. Insert the battery pack into the camera.Open the battery compartment on the bottom of the camera, locate the arrow on the battery pack and point it down into the compartment, then push the battery in until it clicks.The camera’s status light will turn solid yellow when powered. When flashing blue and yellow, it’s ready for setup.
  5. Tap Begin Setup.
  6. Under the battery door, press and hold the SETUP button. It will say “ready to connect”. The camera may say “ready to connect” without pressing the SETUP button. If so, continue.
  7. In the app, check the box next to It said, “Ready to connect”. Then tap Next.
  8. If BluetoothⓇ hasn’t already been enabled, you’ll be prompted to allow BluetoothⓇ access. Tap Okay.If BluetoothⓇ has already been enabled, it will skip to the next step.
  9. The Wyze app will begin searching and pairing to your camera.
  10. Select your 2.4 GHz or 5 GHz Wi-Fi network and enter your network password. Tap Next.
    Tap the icon in the password field to display the password to ensure it was entered correctly.
  11. After the camera is set up and connected, it will say "setup completed".
  12. Success! Your camera is set up and ready to go. Tap Mounting Tips for placement recommendations. Or check out our Wyze Battery Cam Pro Mounting Guide. Or tap Skip if you already have your camera mounted.
  13. Tap Next. You’re set up! It’s time to name your device.
  14. Name your Wyze Battery Cam Pro using the text field, or by choosing a suggestion.
  15. Tap Finish when done.
  16. Choose between the Basic plan (no subscription) or Cam Plus. Tap Continue.
  17. Set up some automations on the Things to Try* page, or tap Skip.
  18. You’re all set. Enjoy your new Wyze device!
Mount your Wyze Battery Cam Pro anywhere using the included wall mount or Wyze Universal Metal Mount.
Depending on the location of where you plan to mount your camera, a ladder may be required.
What’s in the box?
  • 1x Wyze Battery Cam Pro
  • 1x Wall Mount
  • 1x USB-A to USB-C Cable
  • 1x Battery Pack
  • 3x Screws (29.5 mm x 2.9 mm)Note: Use a 3/64 drill bit
  • 3x Drywall Anchors (28.7 mm x 5.5 mm)Note: Use a 7/32 drill bit
  • 1x Quick Start Guide
To mount your Wyze Battery Cam Pro from the wall:
  1. Remove the wall mount base from the camera mount by rotating the base counterclockwise.
  2. Use the base and position the holes where you plan to mount the camera.
  3. Use a pencil to mark the holes.
  4. For drywall or a surface too soft for screws, drill pilot holes then insert the drywall anchors into the holes.For harder surfaces like wood posts, trim, etc., skip to the next step.
  5. Screw the wall mount base into the wall using the provided screws.
  6. Screw (twist) the wall mount onto the back of your Wyze Battery Cam Pro and tighten the disk.Be sure not to over-screw or screw it too tightly.
  7. Connect the entire assembly to the wall mount base by rotating the wall mount clockwise until snug.
  8. Need to adjust the camera angle? Simply loosen the mount by rotating it counterclockwise and adjust the post angle to the desired position then tighten the mount.
To mount your Wyze Battery Cam Pro from a ceiling, simply follow the above steps, but with Wyze Universal Metal Mount.
Tips:
  • Mount your camera 7 feet above the ground, titled 20° downwards for the best detection distance.
  • You can customize the detection distance up to 30ft in the camera’s Detection Settings.
  • Mount your camera away from direct sunlight to avoid glare, overheating, and poor battery life.
  • Point your camera away from areas with a lot of movement, like busy roads or blowing trees, which can trigger false Event notifications.
  • Avoid placing your camera behind glass, looking out of a window, or installed in a third-party case. Wyze Battery Cam Pro uses a mixture of PIR (temperature changes) and radar (movement) to detect motion. Motion detection will not trigger if the camera is behind glass, looking out of a window, or inside a third-party case.
Your Wyze Battery Cam Pro is compatible with a microSD card, which gives you the ability to record motion events or continuous footage directly to your local microSD card.
Important: Continuous recording will drastically drain the battery.
To use a microSD card with Wyze Battery Cam Pro:
  1. Get a microSD card. * We have tested with cards up to 256 GB when formatted as exFAT. Even larger cards may work, but this has not been tested on our end.
  2. Format the microSD cardIf the microSD card has been used before, we recommend formatting the card when you install it in your Wyze Cam.To do this, tap into your camera’s live stream from the Home tab and tap Settings > Advanced Settings > Manage MicroSD Card > Format. ⚡️Heads up! Formatting the card will erase all of the existing content, so be sure to back up your files if there are any you want to save.
  3. Record to the microSD card
  4. View local recordings from the Live stream:In the Wyze app, tap into your camera's Live stream.Tap the SD Card button next to Take Photo.Tap and drag the timeline to view the recorded video for a specific point in time.Available footage will be highlighted in the timeline.Pinch and zoom on the timeline to select a specific point in time.
  5. View local recordings on your computer:In the Wyze app, tap into your camera's Live stream.Tap Settings > Advanced Settings > Manage MicroSD Card > Eject MicroSD Card.Remove the microSD card from your Wyze Cam.Insert it into a computer with a microSD card slot to view the raw video files (mp4 format).
More about Continuous and Events Only Recording
Recording Resolution
The recording resolution of Cam Plus cloud events and local recordings is controlled by the Recording Resolution setting in Advanced Settings.
  1. In the Wyze app, tap into your camera's Live stream.
  2. Tap Settings > Advanced Settings.
  3. Tap Recording Resolution.
  4. Choose 2K or HD.
Continuous Recording
  1. The camera will stop entering Sleep/Power Saving Mode when set to continuous local recording.
  2. We strongly recommend connecting Wyze Battery Cam Pro to a 5V 2A AC power source for continuous recording. We do not recommend to use it with battery only or battery + solar panel power options because it will drain the battery quickly.
  3. A fully charged battery can last for up to 10 hours of continuous recording. Your camera will continuously record video to the microSD card, giving you the option to have your recording available for playback later - no subscription required.If you have a microSD card inserted and Local recording to microSD card turned on in your settings, the camera will continuously record to that microSD card, even if offline.The cam can still create alert videos that are captured and stored on the cloud based on the camera’s other recording settings.The video length depends on the size of your microSD card and your recording settings. When the microSD card is full, it will overwrite the oldest footage and roll forward.
To view your recorded footage, you can either bring your Wyze Cam back to an area that is covered by the Wi-Fi network it was set up in and use the SD Card Playback feature in the Wyze app, OR remove the microSD card from your Wyze Cam to view the raw video files (mp4 format) on a computer.
When you return the microSD card to your Wyze Battery Cam Pro, it will resume continuous recording. The camera supports up to a 256 GB microSD card, which holds roughly 2-3 days of playback recording.
💡Tip: Only recording Events is an excellent way to preserve battery life and space on your microSD card.
  • Your camera will only record video if motion is detected.
  • This feature backs up Cam Plus event videos to local microSD card with customized Recording Cooldown and Max Video Length settings in Event Recording settings. With a Cam Plus license, you can set the camera to record motion events with no cooldown period and up to 5 mins video length. For cameras without a Cam Plus license, the length of the local video will be around 12 seconds with the same recording cooldown period.
Additional Note:
  • Time lapse videos are not supported on Wyze Battery Cam Pro.
FREE shipping on orders $0+
$279.98 $249.98
