1 of 4
Wyze Solar Panel
Wyze Solar Panel
12W Solar Charger for Outdoor Cams
Style
$7.99CAD
FREE shipping on orders $99+
Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life. Designed to be weather resistant and mountable anywhere.
Works with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
  • Weather-resistant page.
    IP65 Weather Resistant
  • A black background with a streamlined icon of a hammer and wench.
    Easy 360° Mount
  • WyzeCam Floodlight Icon 4
    Runs on Sun Power
  • WyzeCam Floodlight Icon 5
    13-foot Power Cable
Wyze Solar Panel Details
Color
  • White frame and mount
  • Black solar cells
Dimensions
  • 173 mm x 120 mm x 17 mm
Solar power rating
  • 2.5W, 5VDC
Micro USB cable length
  • 13 ft (4m)
Waterproof level
  • IP65
  • Wyze Cam Outdoor and Wyze Battery Pro recharge frequency vary based on device settings, motion notifications, and sun exposure in the area of placement.
  • For the most sunlight, position your Wyze Solar Panel so that it’s facing south and is tilted upward at a 30º angle.
  • Make sure it’s not in a shaded area and avoid placing it directly under a tree. Tree sap, falling leaves, and large shadows can greatly reduce the solar panel’s efficiency.
  • 1x Wyze Solar Panel
  • 1x Universal Head Locking Cover Assembly
  • 1x Connecting Rod
  • 1x Locking Screw Cap
  • 1x Base
  • 1x Adapter Cable
  • 1x Type-C Cable
  • 3x Screws
  • 3x Wall Anchors
  • 1x Quick Start Guide
The solar panel converts sunlight into electrical energy to charge Wyze Cam Outdoor or Wyze Battery Cam Pro.
The maximum power output is 2.5 watts.
Mount the solar panel where you get the most sunlight during the day. Make sure it’s not in a shaded area and avoid placing it directly under a tree. Tree sap, falling leaves, and large shadows can greatly reduce the solar panel’s efficiency.
No, we do not recommend using Wyze Solar Panel with other Wyze cameras. This is only compatible with Wyze Cam Outdoor and Wyze Battery Cam Pro.
Wyze Solar Panel is an accessory for Wyze Cam Outdoor and Wyze Battery Cam Pro to extend its battery life. We do not recommend using it to charge other devices.
Depending on the intensity of the sunlight, the solar panel is unlikely to perform well in cloudy or rainy weather.
Yes, Wyze Solar Panel is IP65 weather resistant and dustproof but is not waterproof.
No, Wyze Solar Panel is an accessory for Wyze Cam Outdoor and Wyze Battery Cam Pro to extend its battery life and is not related to the Base Station. Your Base Station needs a constant power source to keep your Wyze wireless cameras online.
A solar panel is attached to a white wall, with a camera and a battery.
Continuous Power
Extend the length of time you can keep your Wyze cam recording without having to bring it back inside to recharge.
A solar panel is attached to a house.
360° Freestyle Mount
Get the perfect angle to achieve maximum sun exposure IP65 Weather Resistance - Weatherproof and dustproof.
A person is holding a white device that is plugged into a wall outlet.
Long Range Power Cable
A 13-foot weatherproof power cable provides ultimate mounting flexibility.
1 of 4
Cameras that work with this solar panel
  • Wyze Cam Outdoor v1
    Regular price From $69.99 CAD
    Regular price CADDeal From $69.99
    Move it, mount it, record it - anywhere. Wireless. Learn More
    Choose your option
  • MicroSD Card
    Regular price From $25.99 CAD
    Regular price CADDeal From $25.99
    Choose your option
Support Articles
Download the Quick Start Guide for Wyze Solar Panel here.
Attached is the Quick Start Guide for Wyze Solar Panel, a short manual on how to get started.
This guide is a short user manual with the basics about Wyze Solar Panel, including:
  • What's in the box for Wyze Solar Panel.
  • A diagram of Wyze Solar Panel.
  • How to install Wyze Solar Panel.
  • How to position Wyze Solar Panel.
What’s in the box?
  • 1x Connecting Rod
  • 1x Base
  • 1x Adapter Cable
  • 1x Type-C Cable
  • 3x Screws
  • 3x Wall Anchors
To install your Wyze Solar Panel:
  1. Locate where you’d like to install your Wyze Solar Panel.
  2. Use the wall mount base and position the holes where you plan to mount the solar panel.
  3. Use a pencil to mark the holes.
  4. Align the pins on the connecting rod with the base and insert it, then tighten the locking screw cap under the base.
  5. Fix the base to your mounting location using the included screws. If the installation surface is soft or unstable, first use a Φ6.0 drill bit to drill a hole in the wall, then insert the anchor nail into the hole, and fix the base with screws.For harder surfaces like wood posts, trim, etc., skip to the next step.
  6. Screw the universal joint into the back of Wyze Solar Panel, then tighten it firmly with the attached nut.
  7. On the back of the solar panel, you’ll find a winding board for excess cable. Estimate how much cable you’ll need to attach the solar panel to your camera, and coil the rest behind the board.Connect the solar panel to the wall mount base by screwing the locking screw cap until it is secure.
  8. Securely insert the microUSB cable from the solar panel into the sleeve of the power adapter.For Wyze Cam Outdoor, use the standard adapter that is included with the solar panel.For Wyze Battery Cam Pro, you will need Wyze Solar Panel USB-C Adapter Cable (sold separately).Remove the silicone cover from the charging port on your camera and insert the power adapter until secure.
  9. Mount your Wyze Cam and you’re all set to harness the power of the sun!
  10. Need to adjust the angle of your solar panel? Simple! You can adjust your solar panel up to 90° at the elbow at any time or side to side by loosening the locking screw cap. Make sure the screws are securely tightened again after adjusting the solar panel.
Mounting Tips:
  • Find an area that gets the most direct sunlight throughout the day.
  • Angle the solar panel upward 30°.
  • Point it south if you’re in the northern hemisphere and north if you’re in the southern hemisphere.
