1 of 5
Wyze Universal Camera Mount
A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling.
⚠️ Doesn't work with Wyze Cam OG/OG Telephoto.
$12.98 $14.99CAD
A durable camera mount with a longer neck. Designed to provide versatile mounting applications such as the ceiling or patio.
Made for Wyze Cameras that use a standard 1/4”-20 mount.
  • Made for Wyze Cams
    Compatible with Wyze Cams with 1/4"-20 mount
  • Heavy-Duty Metal Mount
  • Mount Anywhere
  • Easy Installation
Model Number
  • WYZEUMML
Color
  • White
Finish
  • Matte
Weight
  • 2 oz (57 g)
Dimensions
  • 2 in x 2 in x 3.8 in
Mount Load-bearing
  • 70 oz (2 kg)
Drywall anchors
  • 3x wall anchors (Length: 28.7 mm, Width: 5.5 mm, Drill bit size: 7/32)
Screw Assembly
  • 3x Philips screws (Length: 29.5 +- 1 mm, Width: 2.9 mm, Drill bit size: 3/64)
  • Wyze Universal Metal Mount x1
  • · Screw Assembly x1
The Universal Mount is compatible with all cameras that use a standard 1/4”-20 mount, including Wyze Cam v1/v2/v3, Wyze Cam v3 Pro, Wyze Cam Pan v1/v2/v3, Wyze Cam Outdoor v1/v2, and Wyze Battery Cam Pro.
*Please Note: that it is not compatible with Wyze Cam OG or OG Telephoto.
Yes, the Universal Mount is adjustable, allowing you to adjust the angle of the camera to your desired viewing position. Simply loosen the mount base, adjust the angle of the camera, and then tighten the base to secure the camera in place.
Yes, the Universal Mount is made of heavy-duty metal and is designed to withstand outdoor conditions. However, it is recommended to keep the camera and mount protected from direct exposure to rain, snow, and extreme weather conditions for long-term durability.
No, the Universal Mount is designed specifically for Wyze cameras that use a standard 1/4”-20 mount. It is not compatible with cameras that use a different mounting system.
A camera is mounted on the ceiling.
Built to last with adjustable and rugged metal construction, it can withstand the toughest weather conditions ⛈️ or ☀️
Boys playing in a pool with a Wyze battery cam pro.
Mount Anywhere
Adjustable and flexible to achieve the perfect angle and coverage for any space.
A white camera mounted on a ceiling.
Easy Installation
Hassle-free set up will your camera mounted in no time! Installs easily on fences, trees, siding, and more.
1 of 5
Check out cameras that work with this mount
  • Wyze Cam Pan v2
    Regular price $59.99 CAD
    Regular price CADDeal $59.99
    360° Pan/Tilt 1080p Camera Learn More
    Choose your option
Please note ⚠️: The universal mount will not work with Wyze Cam OG cameras
FREE shipping on orders $0+
$7.99
