1 of 9
Lock + Gateway + Keypad
$124.98 $183.98CAD
Low stock: 69 left
FREE shipping on orders $99+
Keep your door's dead bolt. Just add the brains.
A woman holding a green bag and a child holding a banana while opening a door.
Unlocks as you approach. Locks when you leave.
Hands full? Wyze Lock knows when you arrive home and automatically unlocks as you approach. When it senses the door is closed, it automatically locks behind you.
Wyze Lock Details
  • Color: Silver
  • Dimensions: 4.9" Length x 2.5" Width x 1.3" Depth (2" including knob)
  • Weight: 0.67 lb
  • Power Source: 4x AA Batteries (included)
  • Battery Life: 5-6 months (depending on usage)
  • Communication Method: Bluetooth, Zigbee
  • Range: To Keypad: 9', To Gateway: 50', BLE to phone: 16'
  • Compatibility: Android 5.0+, iOS 9.0+
  • Weather Resistance: Indoor use only
  • Operating Temperature: 14°F - 131°F / -10°C - 55°C
  • Storage Temperature: -22°F - 158°F / -30°C - 70°C
Keypad (sold separately)
  • Color: Silver
  • Dimensions: 3.7" Length x 1.3" Width x 1.0" Depth
  • Weight: 0.1 lb
  • Power Source: 2x AA Batteries (included)
  • Battery Life: 4-6 months (depending on temperature)
  • Range: To Lock: 9'
  • Weather Resistance: IPX5
  • Operating Temperature: -4°F - 140°F / -20°C - 60°C
Gateway
  • Color: White
  • Dimensions: 2.1" Length x 2.1" Width x 1.2" Depth (1.9" including pins)
  • Weight: 0.12 lb
  • Power Source: 110-240V, ~60Hz
  • Battery Life: NA
  • Communication Method: Bluetooth, Zigbee, Wifi
  • Range: To Lock: 50', To Router: 50
Same key. Same deadbolt. Infinitely smarter.
Wyze Lock uses your door's existing hardware so you can keep your key, but still get all the benefits of a smart lock.
Keep your key graphic.
A wooden door with a lock on it.
A person holding a smartphone with the Wyze app open, showing the status of their backyard door being locked.
Remote access and history viewing.
Unlock the door for friends and family, even if you're away from home with a tap in the Wyze app. See who accessed your home from anywhere and get notified whenever the door is left unlocked.
A smart lock that works with Alexa and Google.
Control with Alexa, Google, and Wyze Switch.
Wyze Lock works with Alexa and Google Assistant so you can lock your door by just saying, "Hey Alexa, lock the front door."
You have been given access to the front door.
Send virtual keys to family and friends.
Wyze Lock makes sharing access to your home simple and puts you in complete control. Easily grant or revoke access to your home through the Wyze app. Only you can see the history of how each key is used.
Compatible with most single cylinder deadbolts.
We made Wyze Lock to work with most single cylinder deadbolts—deadbolts with a keyhole on only one side. Find out if your deadbolt works with Wyze Lock here.
A cell phone with a picture of a doorbell on it.
Unlock with your Wyze Video Doorbell.
You can control your Wyze Lock right from the Wyze Video Doorbell (or Video Doorbell Pro) viewer, so you don't have to switch between apps just to open the door.
Shop Wyze Video Doorbell
Installs in under 15 minutes.
Wyze Lock only replaces the interior side of your existing deadbolt, so it's much quicker (and easier) to install than a complete deadbolt replacement.
  • A black lock with a keypad and a button.
    Wyze Lock Bolt
    Built for Convenience: Quickly unlock the door with your fingerprint
    • Fingerprint unlock
    • Local app access only
    • No Wyze automations or Alexa/Google support
    • Replaces existing deadbolt
    • Basic Auto-Lock
    • No Auto-Unlock
    • Keypad built-in
    Shop Wyze Lock Bolt
  • A white button with a lock on it.
    Wyze Lock
    Built for Smart Homes: Monitor and access your door from anywhere
    • No fingerprint unlock
    • Access the app from anywhere
    • Wyze automations & Alexa/Google support
    • Attaches to existing deadbolt
    • Advanced door position Auto-Lock
    • Auto-Unlock
    • Optional keypad sold separately
Support Articles
Installing your new Wyze Lock is meant to be as straightforward as possible. If you do run into any trouble with the process outlined on this page though, check out our Troubleshooting section for tips on getting things installed properly.
If you're unsure of whether Wyze Lock will work with your current deadbolt, we've got you covered with our Wyze Lock Compatibility Guide.
What’s in the box?
  • 1x Wyze Lock
  • 1x Mounting Plate
  • 4x Lock Adapters
  • 4x AA Batteries
  • 1x Adhesive Strip
Required Tools
  • 1x Philips Screwdriver
To install your Wyze Lock:
  1. Use the supplied adhesive strip to hold the outside of the lock in place
  2. Unlock your installed deadbolt
  3. Use your screwdriver to remove the screws from your existing deadbolt’s thumb-latch
  4. Insert the screws from Step 3 into the Wyze Lock Mounting Plate
  5. Attach the Wyze Lock Mounting Plate in place of the old thumb-latch. Making sure the plate is level, tighten the screws until snug
  6. Find and install the included adapter which fits the tailpiece of your lock. Reference the chart in the Wyze app to determine which works with your deadbolt
  7. Remove the front plate by pulling from the notch on the bottom of the Lock
  8. Place the Wyze Lock on the Mounting Plate, adjusting the knob as necessary to get it to align with the adapter
  9. Check to make sure that the lock is flush with the door, and can be both locked and unlocked with the thumb-latch If the lock can't be turned at this point, remove it and rotate the thumb 90-degrees and try again
  10. Once you’re confident that everything is aligned, tighten the 2 pre-installed screws inside the battery compartment until snug, taking care not to over-tighten them
  11. Install the included 4x AA batteries taking note of orientation, then fold the battery latches down
Once your lock is successfully installed, the next step is to move on to setting it up. Check out our Wyze Lock Setup Guide here.
Download the Quick Start Guide for Wyze Lock in this article.
Below is the Quick Start Guide for Wyze Lock, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Lock including:
  • What's in the box for Wyze Lock.
  • The components of Wyze Lock and Wyze Lock Gateway
  • How to set up your Wyze Lock.
  • Troubleshooting your Wyze Lock.
  • How to read the status lights for Wyze Lock.
If you haven't already, please check out our Wyze Lock Keypad Installation Guide to get it mounted.
An alternative to start the setup process is to continue in the Wyze app immediately after setting up your Wyze Lock.
To set up your Wyze Lock Keypad:
  1. In the Wyze app, tap the Wyze Lock you're setting up a Keypad for.
  2. Go to Settings by tapping the gear icon in the top right.
  3. Tap Wyze Lock Keypad Settings > Add Keypad.
  4. Press and hold the Lock button on the keypad until the status light is flashing green.
  5. Tap Next in the Wyze app.
  6. The keypad will automatically proceed through setup until it connection is complete.
  7. Once the keypad is connected, enter a 4-8 digit code in the Wyze app.*
You're all set! Be sure to choose a code that you'll remember, or record it somewhere safe so you don't forget it.
