1 of 7
Wyze Video Doorbell (Wired)
Check out the newer model:
  • 2K QHD w/Color Night Vision.
  • Built-in microSD storage.
  • Works with Existing Doorbell Chime.
  • Enables 3-6 seconds of pre-roll recording for motion events.
  • You'll also continue to get the amazing features of Doorbell v1 (wired): 2-way audio and traditional night vision.
Get Doorbell v2
Style
$79.99CAD
Low stock: 1 left
FREE shipping on orders $99+
Item is no longer available.
Small has never been mightier. Head-to-toe, 1080p, full HD viewing on this wired doorbell camera.
    1080p full HD
    Live stream & recording.
  • A black and white image of a phone being held.
    4:3 Aspect Ratio
    Get the full picture. See people head to toe.
  • Wyze switchicon.
    Two-way Audio
    When someone approaches your door, just open the app to begin talking.
  • A blue and purple circle with a white cross in the middle.
    See more with Cam Plus
    Cloud video storage and advanced AI detections (with subscription).
Wyze Video Doorbell Specs
Color & Materials
  • White
  • Plastic
Dimensions
  • 1.5'' x 3.25'' x 0.625''
Video & Image
  • Image Sensor: 2K (2048 x 1536)
  • Camera: F2.0 aperture, 2.7mm focal length, 1/2.8" CMOS
  • Image Quality: 1080p and 480p w/ 8x Digital Zoom
  • Frames per Second: 20 Daytime, 15 Nighttime
Audio
  • Audio: Built in Speaker & Microphone (with 2-way Audio & Noise/Echo Cancellation)
Additional Details
  • White LED (Fill Light): 6 x 5000K (daylight color temperature)
  • IR Night Light: 4 x 940nm Infrared LED
  • Connectivity: Direct to WiFi 802.11 b/g/n, 2.4GHz (5GHz WiFi not supported)
  • Sub1G: 906.8MHz, used for local connection between doorbell and chime.
  • IP65 Weather-resistant
  • Storage Temperature: -40 to 176°F (-40 to 80°C)
  • Operating Temperature: -4 to 122°F (-20 to 50°C)
  • Field of View: 120° Vertical x 88° Horizontal
Connectivity & Compatibility
  • 2.4 GHz WiFi
Data Security
  • End-to-end encryption, HTTPS secure transfer protocol, AES 128-bit encryption
Wyze Chime
  • Chime Power: Standard US Power Outlet: 100V-240V, 0.1A, 50/60Hz
  • Weight: 2.0 oz / 56g
  • Size: 2'' x 2'' x 1.4''
  • Chimes: 5 modern, 4 classic doorbell, 3 animal sounds, 6 automation sounds, 1 intruder alarm
Wyze Video Doorbell
  • Wyze Video Doorbell x1
  • Wall Plate x1
  • Wedge (Horizontal, 30°) x1
  • Wire Caps x4
  • Bracket Screws x2
  • Screws & Expansion Tubes x2
  • Extension Wires x2
  • Jump Wire x1
  • Quick Start Guide x1
Wyze Video Doorbell + Chime
Everything listed under Wyze Video Doorbell, plus:
No, it is a hardwired doorbell.
Wyze Video Doorbell does not use batteries. It is hardwired, connecting directly with your existing mechanical chime power source.
No, your existing chime won't work.
The existing chime will be bypassed so that the power can be used for your Wyze Video Doorbell.
No, it only detects motion.
Your Wyze Video Doorbell can detect motion and people and has been optimized with a white LED light to ensure you see a clear face in the live stream. It does not detect sound.
Yes, in your doorbell settings.
To change your Wyze Chime volume:
  1. In the Wyze app, tap on your Wyze Video Doorbell.
  2. Tap on the Settings icon on the top right.
  3. Tap Extended Devices > Chime > Tunes.
Yes, Wyze Video Doorbell is IP65 rated as weather-resistant. This means that it is "dust-tight" and protected against water sprays from any angle.
No. Wyze Video Doorbell connects directly to WiFi. It does not connect to the Bridge or the Wyze Base Station.
Yes, absolutely.
Yes! We've integrated with the most popular smart home systems. Use your Amazon Echo smart speakers as doorbell chimes hear the bell ring from anywhere in your house. With Wyze Video Doorbell, you can also view live video feeds of people at the door from your Echo Show and Google Home devices.
Cam Plus allows you to see a live feed of anyone at the door, whether they're knocking or just standing around outside. This makes it easy for you to track who's coming and going without ever having to leave your comfort zone or worry while being away from home.
Yes, but not all functions will work.
Once your Wyze Video Doorbell is paired with Wyze Chime, it will chime when the doorbell is pressed, even if the doorbell is not connected to WiFi.
However, the doorbell will not record event videos to the cloud or send push notifications to your phone if it is offline.
No. Wyze Video Doorbell does not support a microSD card. All recorded events will be stored in the cloud.
Wyze 4.3.3.
People are taller than they are wide. So is our live stream.
Wyze Video Doorbell records and live streams video in 1080p Full HD with a 4:3 aspect ratio so you can see every visitor from head to toe. You’ll also be able to see packages left on the ground beneath your doorbell.
See it in action
We built a device that allows you to be at your front door no matter where you are. See how Wyze users are using theirs to capture everything from important deliveries to epic snowfalls.
doorbell image size illustration
Size matters. And we’re as small as it gets.
Slim Profile
Keep your curb appeal and let your door stay the center of attention with our slick, compact design.
A dog looking through a window.
Don't worry about visitors missing it.
A motion-activated LED will grab their attention as soon as they approach.
* Photo from a Wyze user
A person holding a cell phone with a picture of a man wearing a yellow hat.
Never miss another visitor. Unless you want to.
Instant Notifications
Receive instant push notifications when Wyze Video Doorbell is pressed so you know the moment someone’s at your door.
Pull up a live stream of your visitor before responding to decide whether you’d like to ignore a solicitor or answer the delivery driver.
Hello, Bonjour, or Hola. Wherever you are, answer your door from miles away.
Two-way audio. Never feel away from home again with two-way audio. When someone approaches your door, just open the app to begin talking.
A man is holding a box with a smile on his face.
Google works with Alexa to provide a seamless experience.
Integrated with Alexa and Google.
Use your Amazon Echo smart speakers as extra doorbell chimes throughout your home. Command live video feeds to appear on your Echo Show and Google Home devices, even get an alert from Alexa if a person is detected at your door, with Cam Plus.
A white speaker with a green top.
Hear your doorbell ring, chirp, or bark from any room.
Pair any number of wireless Wyze Chimes with your doorbell so every room in your house is ready to alert you when someone’s at the door.
Chime sold separately.
Choose from 19 different chime sounds including traditional bells to birds chirping.
A man wearing a hoodie is holding a box with a doorbell in it.
Beware of Doorbell
Smart Alerts & Video Recording
Wyze Video Doorbell lights up brightly when motion is detected nearby, alerting visitors and would-be porch pirates of your video doorbell.
Plus, you can turn on push notifications to get a phone alert whenever anyone or anything approaches your door, even if they don't ring the doorbell.
Camplus logo with a purple background.
And we created ways for making your cam even smarter
Plan Sold Separately
  • Person Detection
  • Full-length motion recording
  • Vehicle, pet, and package detection
  • See everything that happens at your doorstep
A white doorbell with a blue button on it.
Built to endure the elements.
IP65 weather resistant
Install Wyze Video Doorbell on your door without worrying about interference from the elements. IP65 weather resistance protects this doorbell from rain, snow, and sun.
A blue cell phone with a picture of a porch on it.
Let guests in remotely with Wyze Lock.
Better with Wyze Lock. Don’t worry if the dinner party shows up before you. Let your friends inside when you’re stuck in traffic by remotely unlocking your door with Wyze Lock. Requires: Wyze Lock
Learn More
Surprisingly super simple self-installation. Seriously.
Easy installation. Replace your existing hardwired doorbell in under 20 minutes with our easy DIY installation guide. Check out the video below to see for yourself.
Support Articles
This article details how to set up your Wyze Battery Video Doorbell. Let's get started!
To set up your Wyze Battery Video Doorbell:
  3. Tap Cameras > Video Doorbells > Wyze Battery Video Doorbell.
  4. Press and hold the SETUP button on the back of the doorbell for 5 seconds until the status light flashes red and it says "ready to connect."
  5. In the app, tap "I heard “Ready to connect," then Begin Setup.
  6. If you haven’t already enabled Bluetooth® and location access for the Wyze app, there will be a screen prompting you to do so. Once enabled, tap Next.If Bluetooth® and location access have already been enabled, it will skip to the next step.
  7. The app will automatically begin searching for and pairing with your Wyze Battery Video Doorbell.If you have multiple Wyze Battery Video Doorbells, select the correct camera by tapping the MAC address that matches the address on the back of the doorbell.
  8. Select your 2.4 GHz network and enter your network password. Tap Connect.Tap the icon in the password field to display the password to ensure it was entered correctly.
  9. Your device will continue pairing. Once paired, tap Next.
  10. Follow the in-app instructions to mount Wyze Battery Video Doorbell.Also handy: Wyze Battery Video Doorbell Installation Guide.
  11. Choose your chime option, then tap Next. By Itself. The doorbell will ring when it's pressed. With an existing house chime. Your doorbell will ring on your house chime, using Wyze Chime Controller (sold separately) when pressed. You'll be prompted to set up Wyze Chime Controller after doorbell setup is complete. With a Wyze Wi-Fi Chime. Your doorbell will ring on a Wyze Wi-Fi Chime (sold separately) when it is pressed. You'll be prompted to set up Wyze Wi-Fi Chime after doorbell setup is complete.
  12. You've successfully set up your Wyze Battery Video Doorbell. Now it's time to customize it. Tap Next.
  13. Name your Wyze Battery Video Doorbell using the text field, or by choosing a suggestion. Tap Finish when done.
  14. You may have a prompt to enable Cam Plus. Tap Continue.
  15. Set up some automations on the Things to Try* page, or tap Skip.
  16. You’re all set! Your doorbell is set up and ready to go.
Now that your Wyze Video Doorbell is all set up, it's time to add a Wyze Chime. Your chime will sound whenever someone rings the doorbell.
To set up your Wyze Chime:
Immediately after setting up your Wyze Video Doorbell, you'll be prompted to mount it, then continue to set up your Wyze Chime.
  1. Tap Add a Wyze Chime, then tap Next to continue.
    Don't want / need to add a Wyze Chime right now? Tap Not Now.
  2. Plug your chime into a standard power outlet close to the doorbell.
  3. Press and hold the reset button on the bottom of the Wyze Chime until the blue light flashes quickly three times. Set up should complete automatically.
  4. Tap Finish. You're all set!
Follow the steps in the Wyze Battery Video Doorbell Setup Guide to get your doorbell ready for installation.
What's in the Box:
To install your Wyze Battery Video Doorbell (Battery):
After initial setup in the Wyze app, you can choose how you will mount your Wyze Battery Video Doorbell.
  • ⭐️ Battery Mode: For more flexibility when installing.
  • Wired Installation: To replace your existing AC-wired doorbell. Requires a Wyze Chime Controller (sold separately).
  1. To install your doorbell without wiring, tap Battery Mode then Next.
  2. Make sure you have the required tools for mounting. Tap Next.You will need a Phillips screwdriver
  3. Select where your doorbell will be mounted, relative to the door. Tap Next.
    PerpendicularParallel.
  4. Select how you want to position or angle your doorbell. Tap Next.Straight aheadFollow the steps to mount the Back Plate.
    At an angleFollow the steps to mount the Corner Kit, then Back Plate.
  5. Attach your doorbell to the Back Plate starting from the bottom, as shown in the app. Tap Next.
  6. Choose how you want your doorbell to ring. Tap Next. By itself. Only the doorbell will ring when it's pressed. With a Wyze Wi-Fi Chime. Your doorbell will ring with a Wyze Wi-Fi Chime (sold separately) when it is pressed.
  7. Installation complete! Continue along in the app to complete setup.
To install your Wyze Battery Video Doorbell (Wired):
After initial setup in the Wyze app, you can choose how you will mount your Wyze Battery Video Doorbell. For wired installation, you must have a Wyze Chime Controller (sold separately) and follow the instructions to install it: Wyze Doorbell Chime Controller Installation Guide
  • Battery Mode: For more flexibility when installing.
  • ⭐️ Wired Installation: To replace your existing AC-wired doorbell.Requires a Wyze Chime Controller (sold separately).
  1. To install your doorbell using AC wiring, tap Wired Installation then Next.
  2. Make sure you have the required tools for mounting. Tap Next.You will need a Phillips screwdriver.
  3. Turn off power to your current mechanical doorbell at your electrical panel. Tap Next.Related article: Which switch in the electrical panel controls my doorbell? Press your doorbell button to confirm the power is shut off.
  4. Gently remove your existing doorbell and disconnect the wires. Tap Next.
  5. Select where your doorbell will be mounted, relative to the door. Tap Next.PerpendicularParallel.
  6. Select how you want to position or angle your doorbell. Tap Next.Straight aheadFollow the steps to mount the Back Plate.
  7. Attach the extension wires to your new doorbell, following along in the app. Tap Next.
  8. Pair and cap the loose extension wire ends with the wires from the wall. Tap Next.
  9. Attach your doorbell to the backplate starting from the bottom, as shown in the app. Tap Next.
  10. Installation complete! Continue along in the app to complete setup.
