Passer au contenu
Sonnette vidéo à piles + carillon Wi-Fi
Head to Toe View
Six Month Battery Life
Easy Install
Place it anywhere
1536x1536 HD+
Video Resolution
SALE
$79.98 $85.96SAVE 7%
En rupture de stock
En rupture de stock
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Voir les détails complets
A battery-powered doorbell built to see the full picture.
Experience effortless front porch protection, no matter where you live. Easily install it wired or wire-free and view it all from anywhere in crystal-clear HD+ resolution.
Battery Video Doorbell + Palm Lock  - Wyze Labs, Inc.
Wide head-to-toe view angle.
See more of what matters. With a 150° horizontal and 150° vertical field of view, Wyze Doorbell captures everything from a visitor’s smile to a package tucked against your door.
Keep an eye on kids coming home from school, delivery drop-offs, or unexpected guests, all without blind spots. Even if someone stands close to the camera, you’ll still see the full picture — from head to toe, porch to street.
Wire-free or wired.
Go up to 6 months on a single charge, or hook it up to your existing doorbell wiring for nonstop power. Recharging is easy, just plug into the USB-C port on the back.
Flexible chime options.
Never miss a ring. Connect to your home’s existing chime, or pair with a Wyze Universal Wi-Fi Chime (sold separately) to hear alerts anywhere in your home, even through your Wyze Cams.
Pick from 20 chime sounds and 8 volume levels to match your style (or have a little fun and set it to a dog bark to surprise uninvited guests).
Easy to install for homes and apartments.
Mount anywhere with the included hardware and corner plate for the perfect view. Ideal for renters or homeowners who want simple, secure installation without hassle.
When motion is detected, Wyze Battery Video Doorbell can automatically play a “You are currently being recorded” message, letting visitors know they’re on camera.
That simple phrase can make a big difference. Studies have shown that visible or audible signs of surveillance reduce break-ins by up to 60%, and most burglars admit they’ll avoid homes with cameras or alarms altogether.
With two-way audio, you can greet guests, give delivery instructions, or let friends know you’ll be right there, all through the Wyze app.
In a rush? Use Quick Responses to instantly play preset messages like “Please leave the package at the door” or “Be there shortly.” Perfect for when your hands are full, your baby’s napping, or you just don’t feel like yelling through the door.
IP65 weather resistance.
No need to worry about water damage, foggy lenses, or failed recordings of those cheaper doorbells. Get reliable protection and peace of mind, no matter what the forecast says.
Unlock from anywhere.
À associer avec Wyze Lock et Wyze Palm Lock.
Voyez qui est à votre porte et ouvrez-lui, le tout depuis le même écran. Associé à la serrure connectée Wyze Palm Lock , vous pouvez déverrouiller votre porte à distance directement depuis l'application Wyze ou la vue en direct de votre sonnette.
*Non compatible avec le verrou Wyze Lock Bolt.
Shop now
More to love
Ne manquez rien grâce à l'enregistrement local (alimentation filaire continue requise) avec une carte microSD jusqu'à 256 Go (vendue séparément).
Regardez et apprenez. Personnalisez votre sonnette.
Découvrez notre vidéo de déballage ci-dessous. Apprenez à appairer votre sonnette, à personnaliser les notifications, à ajouter un carillon et bien plus encore.
Compare Doorbells
Sonnette vidéo Wyze Pro
from $99.98 $173.98
Resolution
1563 x 1563 (HD+)
Front: 2048 x 1536 (2K) / Bottom: 1920 x 1080
1440 x 1440
2048 x 1536 (2K)
Field-of-View
H: 150°, V: 150°
Front H: 132°, V: 100° / Bottom H: 121°, V: 60°
H: 150°, V: 150°
H: 135°, V: 103°
Chime
Existing + Auxiliary
Existing
Auxiliary
Existing
Power Option
Battery + Wired
Battery + Wired
Battery + Wired
Wired Only
3P Integration
Amazon Alexa, Google Home
Storage
Local & Cloud
Local & Cloud
Cloud Only
Local & Cloud
View
View
View
View
