1 de 6
Prise extérieure Wyze
Weatherproof Smart Outlet with WiFi Controls
$24.99CAD
Stock faible : 67 restant
Garantie prolongée de 18 mois
Profitez pleinement de votre extérieur, par tous les temps, grâce à une prise connectée : même vos éclairages de jardin méritent une solution intelligente. Des décorations gonflables festives aux soirées entre amis, prenez le contrôle total grâce à une application. Suivez votre consommation, programmez des horaires et, en un clin d'œil, votre espace extérieur devient beaucoup plus facile à gérer, grâce à vous.
Voir les détails complets
Wyze Plug Outdoor Details
  • Color: Black
  • Weight: 7.2 Ounces
  • Dimensions (L x W x D): 4.0” x 2.8” x 1.4”
  • 1/2 HP Max Motor
  • Weather Rating: IP64
Additional Details
  • Operating Environment: Indoor and Outdoor
  • Operating Temperature: -4°F to 120°F
  • Input: 120V~, 60Hz
  • Output: 15A Max with Overload Protection
  • Compatibility: Android 5.0+ and iOS 9.0+
  • Certifications: FCC, IC, ETL
  • Warranty: 1 Year
  • Connectivity: 2.4GHz WiFi
  • Bluetooth V4.2 (for simple setup)
  • Wyze Plug Outdoor x 1
  • Quick Start Guide x 1
  • Mounting Accessories x 1
Wyze Plug Outdoor has long-range WiFi to ensure it can be used in many locations. It can reach up to 300 feet in an open environment but the exact distance will depend on the location (how many walls between the hardware, the building materials, etc.).
Wyze Plug Outdoor has a built-in photocell sensor that measures ambient light around the device. It is important to follow the in-app instructions and orient the device so it faces away from the wall so the sensor is exposed to the surrounding environment.
Yes, Wyze Plug Outdoor requires WiFi for setup and all features except the light sensor which (once configured using WiFi) can automatically turn Wyze Plug Outdoor on/off based on ambient light.
Yes, there are two on/off buttons on the hardware that let you control it directly from the plug.
Yes, Wyze Plug Outdoor should plug directly into an outlet and then hang down so that water does not run into the sockets. It should not be left flat or in standing or running water. If you would like to use the light sensor, it will need to face away from the wall so the sensor is exposed to the surrounding environment.
A smartphone displaying a screen with a Wyze outdoor plug in app.
Surveiller l'utilisation
Consommez moins d'énergie et plus de café froid
Suivi de la consommation d'énergie. Configurez des alertes de consommation et consultez l'historique de votre consommation dans l'application Wyze.
A large home with a circle overlaid on it.
Large couverture Wi-Fi
Le Wi-Fi longue portée vous permet de vous connecter presque partout.
Portée WiFi jusqu'à 90 m. Contrôlez en toute confiance les prises de votre maison grâce à la portée WiFi étendue de Wyze Plug Outdoor (90 m en espace ouvert).
Résistant aux intempéries IP64. Conçu pour une utilisation en extérieur.
Branchez-le en toute sécurité dans des zones exposées à la pluie, à la poussière, à la saleté et à la neige.
A black device with a blue cord plugged into a wall.
A close up of an outdoor plug with both outlets being used.
2 prises, 2 commandes séparées
Contrôle indépendant des deux points de vente à tout moment
Deux prises en une. Éteignez vos lumières extérieures, mais laissez votre bonhomme de neige gonflable bien en place.
A person holding a smartphone with the Wyze app open.
COMMANDES VOCALES AVEC ALEXA
Éteignez vos lumières sans mettre vos bottes.
Application et commande vocale. Illuminez votre quartier en quelques secondes en demandant à votre assistant vocal ou en ouvrant l'application Wyze sur votre téléphone.
  • Streamline icon Christmas lights 40x40 1.
    Éclairage extérieur
  • A black background with a white snowflake icon.
    Dégivrants de toiture
  • A black square with a faucet in the center.
    Pompe de bassin
1 de 3
Alimentez en toute sécurité les fondoirs et bien plus encore cet hiver
Prise de 15 A avec protection contre les surcharges. La prise Wyze Plug Outdoor offre l'une des puissances de sortie les plus élevées du marché pour une prise connectée, élargissant ainsi ses possibilités d'utilisation.
A black box with a blue plug hanging from a tree.
Support Articles
To set up your Wyze Plug Outdoor:
  3. Tap Power & Lighting > Wyze Plug Outdoor.
  4. Insert your plug into a power outlet.
  5. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
  6. On the next screen, you'll see your plug(s) connecting to the network.
  7. Once connected, name your plug's outlets. Tap on the first outlet's name, then type in the pop-up to edit. Tap on the second outlet's name, then type in the pop-up to edit. Tap Save.
  8. You’re all set. Enjoy your new Wyze device!
Important: Wyze Plug Outdoor should be plugged directly into your power outlet. We do not recommend connecting the outdoor plug to an extension cord as this could result in damage to your Wyze device and void your device's warranty.
Download the Quick Start Guide for Wyze Plug Outdoor in this article.
Attached is the Quick Start Guide for Wyze Plug Outdoor, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Plug Outdoor including:
  • What's in the box for Wyze Plug Outdoor.
  • How to set up your Wyze Plug Outdoor.
  • How to read the status lights for Wyze Plug Outdoor.
  • How to use Wyze Plug Outdoor.
Wyze Plug Outdoor is waterproof, but there are a few steps you can take to make the most of it.
To optimize the outdoor plug's waterproofing:
  1. Plug the Wyze Plug Outdoor into an outlet with the sockets pointing downwards to the ground. This keeps water from running directly into the sockets.
  2. Make sure the sockets are at least 6 inches above the ground. This protects the plug from being submerged by heavy rain.
  3. Cover the socket(s) with the waterproof covers when not in use.
