1 de 18
Caméra Wyze Pan Couleur
Plus de 4 000 avis originaux sur la Bulb Cam4.2sur 5étoiles
Quantité
Plus de 13 millions de foyers nous font confiance
$149.98CAD
En stock
Recevez-le dès
Utilisez un code postal de 6 caractères, par exemple L6Y 0P5.
Retours sans tracas pendant 30 jours.
Garantie prolongée de 18 mois
Mood lighting meets peace of mind. Wyze Bulb Cam Pan Color combines colorful lighting with a pan-and-tilt security camera in one clever bulb. Set the vibe and keep an eye on things. Now that’s a bright idea.
Please measure your sconce before ordering. Click to learn more.
Voir les détails complets
  • A Light Bulb +
    Security Camera
  • 360º pan x 180º tilt
  • 2.5K QHD Color Night Vision
  • 16 Million Colors &
    Tunable White
  • AI-Powered
    Motion Tracking
  • Privacy Mode
  • Extends up to 4.2 in
  • 2 Way Audio
  • Siren
  • Local Recording to MicroSD Card
  • Warranty
Materials & Colors
  • Color: White
  • Finish: Matte
  • Camera Dimensions: 70 mm (H) 70 mm (W) x 250 mm (D) collapsed
  • Camera Weight: 565 g (1.25 lbs)
  • Telescopic Rod Length: 3 cm
Display
  • Resolution: 2.5K QHD(2560 x 1440p)
  • Frame Rate: Daytime 20 FPS, Night 15 FPS
  • Field of View: 115.8º D, 98.5ºH, 53.1ºV
  • Pan Tilt Range: 360º pan x 180º tilt
  • Digital Zoom: 8x
Night Vision
  • Color Night Vision
  • IR Lights: 4 * 850nm
Audio
  • Simultaneous 2-way Talk: Yes
  • Siren: 100 db @ 10cm
Power
  • Power Input: 120V AC E26 Socket
Sensor & Lens
  • 1/3"
  • Aperture: F 1.6
LED Indicator
  • Red & Blue led Indicator
Bulb Light
  • 1800K - 6500K Adjustable + 16M RGB Colors
Connectivity
  • Wi-Fi 6 Dual-Band (2.4GHz + 5GHz)
Storage
  • Supports up to 512 GB local storage (microSD card required)
  • Cloud storage (Subscription required)
Temperature
  • Storage Temperature: -4°F-122°F (-40°C-80°C)
  • Operating Temperature: -40°F-158°F(-40°C-70°C)
Weather Resistance
  • IP65 Weather Resistant (camera part)
  • Indoor/Outdoor
Phone Compatibility
  • Android 10.0+
  • iOS 16.0+
Certifications
  • FCC, IC, UL, IP65 (Camera part)
Languages
  • English
Warranty
  • 1-Year
Packaging
  • Dimensions 90*90*390 (mm)
  • Weight 0.8kg
  • Wyze Bulb Cam Pan Color x 1
  • Switch Cover x 1
  • Socket Adapter x 1
  • Quick Start Guide x 1
Wyze Bulb Cam Pan will turn heads with an electrified pan-and-tilt camera and a bright, tunable full-color bulb in one clever device. Capture sharper details with 2.5K resolution, stay connected via dual-band Wi-Fi (2.4 GHz and 5 GHz) with Wi-Fi 6 support, and gain peace of mind with Privacy Mode. It’s a smarter, brighter way to light your space and monitor what matters.
Yes, Wyze Bulb Cam Pan is IP65 weatherproof and can be installed in outdoor sconces. However, most socket adapters are not waterproof. Please ensure the socket does not come in direct contact with water unless using a waterproof socket adapter.
Yes, a brand new feature for Wyze Bulb Cam Pan is the ability to pan-and-tilt the camera using the Wyze app, just like your other Wyze Cam Pan devices. Wyze Bulb Cam Pan can pan up to 360º horizontally and tilt up to 180º vertically.
Yes, the bulb in Wyze Bulb Cam Pan is dimmable and can be set up to 1100 lumens in the Wyze app. It also has Ambient Light Mode, which sets the bulb to low for general exterior lighting.
Yes, you can adjust the color temperature on Wyze Bulb Cam Pan between 1800K (warm white) to 6500K (daylight white).
Yes, with Wyze Bulb Cam Pan you have precise color control in the Wyze app - up to 16 million colors to set the vibe.
Yes, Wyze Bulb Cam Pan supports both 2.4 GHz and 5 GHz networks, and both Wi-Fi 4 and Wi-Fi 6 routers.
Yes! Once you set up your Wyze Bulb Cam Pan, you can add a Wyze Bulb Color to it in your Device Settings. You can also enable Sync Mode to control both the camera’s bulb and the color bulb together.
Wyze Bulb Cam Pan fits standard E26 sockets and requires continuous 120V AC 60Hz power, like your existing standard bulb socket.
Yes, Wyze Bulb Cam Pan includes a microSD card slot for local storage, allowing continuous recording. It supports microSD cards up to 512GB in exFAT format.
Yes, you can set this camera to Privacy Mode, which points the camera lens away and turns off the audio for privacy.
Yes, the camera lens will return its previous position.
Wyze Bulb Cam Pan only links with Wyze Bulb Color, and does not work with Wyze Accessory Bulbs.
Wyze Bulb Cam Pan measures about 70 mm x 70 mm x 280 mm when fully extended. Your sconce must have an internal diameter of at least 75 mm and an internal depth under 250 mm to install this device.
For larger sconces, use Wyze Lamp Socket with Wyze Cam Pan v4.
Day: 20 FPS ; Night: 15 FPS.
2.5K HD (2560 *1440P).
Yes. The Wyze Bulb Cam Pan Color has two modes, Ambient Light and Motion Light, each with its own schedule, color, and brightness settings. You can keep a warm, soft light on all night and have it brighten when a person or vehicle is detected.
No. The Wyze Bulb Cam Pan Color is compatible with Wyze Color Bulbs. You can sync any Wyze Color Bulbs on your account with it, and link or unlink them at any time.
Use the Wyze app to turn the light on or off and to change its color and brightness. You can also use Alexa to turn it on or off.
Note: Do not use a dimmer switch to adjust brightness. It will cause the light to flicker.
Not your Grandma's porch light
ça fait tellement de bien de
Ne vous posez plus de questions.
Ne nous croyez pas sur parole
13 000 000+
Confiance des ménages
Avis des premiers clients de la Wyze Bulb Cam
Caméra Ampoule Originale
    Installation facile
    Tournez. Assemblez. C'est prêt.
    Sécurité extérieure pour ceux qui détestent les fils. Et les outils. Vous avez un poignet ? Parfait ! Vous êtes qualifié pour l'installer.
    Guide d'installation
    Associez-le d'abord dans l'application Wyze. Vérifiez la vue et la connexion Wi-Fi avant de le fixer, puis orientez le panneau amovible vers la lumière directe du soleil.
    Ce dont vous avez besoin
        Do you have a wrist? Great! You’re qualified to set this up.
        Suit le mouvement, avec fluidité.
        Le suivi de mouvement par IA suit les personnes et les animaux de compagnie avec un panoramique d'une fluidité exemplaire, et nous insistons vraiment sur le terme EXEMPLAIRE. Vous pouvez également effectuer un balayage automatique entre des points de passage personnalisés.
        Chaque blanc.
        Chaque couleur.
        Chaque humeur.
        1100 lumens et 16 millions de couleurs pour correspondre à votre humeur, à la saison, à votre équipe sportive ou à ce beige que le syndicat de copropriété vous a obligé à utiliser pour peindre votre clôture.
        Lumineux.
        Ou juste parfait.
        Augmentez l'intensité pour éclairer toute l'entrée, ou baissez-la pour une lueur plus douce.
        Résolution 2.5K +
        Vision nocturne couleur
        Une image 2,5K ultra-nette capture tous les détails, en permanence. De jour, de nuit, à 3h du matin quand vous jurez avoir entendu quelque chose. Surtout à ce moment-là.
        Stockage mobile
        sur une carte microSD
        168 heures de vidéo par semaine. Rien n'est envoyé sur le cloud, mais la rumeur dit que Saint-Pierre visionne chaque seconde de votre vidéo récapitulative. Donc, d'une certaine manière, si.
        Carte vendue séparément. Des options de stockage cloud et des fonctionnalités IA sont disponibles avec un abonnement payant.
        Mode privé.
        Un seul appui pour le faire pivoter et lui faire regarder ses propres fesses quand vous ne voulez pas qu'il voie les vôtres. Le micro se coupe également.
        S'étend jusqu'à 10,7 cm
        pour s'adapter aux appliques plus profondes
        La tige s'étend de 1,2 pouce. L'adaptateur de douille inclus ajoute 3 pouces supplémentaires et vous permet d'ajuster l'orientation de la caméra. Le regain de confiance est incommensurable, mais votre applique est mesurable, alors mesurez quand même avant de commander. S'il vous plaît.
        For real, please measure before ordering
        We're still gonna accept your return, but we'll both know it was preventable.
        Placeholder image 1Placeholder image 2
        • 2.76 × 2.76 × 9.8 inches collapsed, about 11 inches fully extended
          (70 × 70 × 250-280 mm)
          Measured from the base of your socket.
        • The extender adds 2 inches and we recommend leaving an inch or so for the camera to poke out below your sconce.
        • Fits open-ended sconces with a standard E26 socket and at least 3 inches (75 mm) of internal diameter
        Se synchronise avec
        Wyze Bulb Color v2
        Associez vos ampoules Wyze Bulb Color v2 pour synchroniser leur couleur, leur luminosité et leur programmation. Idéal pour les luminaires à douilles multiples : une seule ampoule pour les gouverner toutes.
        View Bulb Color
        Audio bidirectionnel
        et sirène
        Parlez à vos enfants, à votre facteur, ou essayez de ramener à la raison ces rôdeurs nocturnes. Si cela ne suffit pas, utilisez la sirène.
        Bop-It
        Mode.
        Vous pouvez le tourner. Vous pouvez tirer dessus. Vous pourriez théoriquement jouer au Bop-It avec. Si le courant est coupé et que vous vous ennuyez, vous pouvez le décrocher et jouer au Bop-It avec vos amis. Personne ne l'a jamais vraiment fait, mais vous pourriez être le premier.
        Les dix premières personnes qui laisseront un avis 5 étoiles mentionnant le mode Bop-It recevront un prix spécial. Vous le méritez bien pour avoir lu jusqu'ici.
        Le meilleur du reste.
        • Mode accéléré
        • Intégrations Alexa et Google
        • Partage d'appareil
        • Zones de détection
        • Honnêtement, il y en a tellement plus, achetez-le simplement, nous sommes épuisés d'écrire sur toutes ces fonctionnalités, il y en a trop.
        Bonnes questions
        Question posée et répondue
