1 of 10
Wyze Cam v4
Wyze Cam v4
2.5K Camera with Night Vision & Spotlight
Color
Pack
SALE
$49.99 $78.92CADSAVE 37%
Get unmatched security with Wyze Cam v4. Crystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, and motion-activated spotlight keep your home safe day or night. Plus, 24/7 local recording, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant for ultimate convenience.
2.5K HD Video
Color Night Vision
2 Way Audio
Free Returns
    2.5K QHD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • A black and white image of a weather icon.
    Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
    Motion-Activated Spotlight
    Automatically trigger the LED light and voice prompt for extra security.
  • A purple and white shield with a white background.
    Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v4 Specs
Colors & Materials
  • Colors: White and Grey
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue.
Dimensions & Weight
  • 2in x 2in x 2 3/8in
  • 0.49 lb (222 g)
Mounting
  • Stand, wall mount, ceiling mount,
    or magnetic wall mount (adhesive)
Power
  • Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
  • Outdoor Power Adapter (sold separately)
  • Cable: 6-Foot Flat micro USB to USB-A
Video
  • Resolution: 2.5K QHD (2560x1440)
  • Digital Zoom: 8x
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Color Night Vision: Yes
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Audio
  • Speaker: 99dB, waterproof
  • Simultaneous 2-way Talk: Yes
  • Built-in Siren: Yes
  • Noise & Echo Cancellation: Yes
Connectivity & Compatibility
  • Bluetooth® 5.2
  • Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
Storage
  • Local (microSD card required)
  • MicroSD card up to 512 GB
  • Cloud (with subscription plan)
Weather & Temperature
  • IP65 weather resistant
  • Operating temp: -4ºF - 122ºF (-20ºC - 50ºC)
  • Storage temp: -40°F - 158°F (-40°C - 70°C)
Warranty
  • 1-Year
A box with a camera and a guide.
Included in a 1 pack:
  • Wyze Cam v4 x1
  • Quick Start Guide x1
  • Wall Mount Plate x1
  • Wall Mount Plate Tape x1
  • Screw Kit x1
  • Indoor USB Power Adapter x1
  • 6-Foot Flat micro USB to USB-A cable x1
Note: The camera and USB cable will be either white or grey, depending on the colorway chosen.
Wyze Cam v4 is our best camera yet, with super-clear, 2.5K QHD resolution and enhanced Color Night Vision. Our new audio technology now removes harsh and static sounds better than ever before. You can use Wyze Cam v4 indoors and outdoors, and use its built-in spotlight and Motion Warning feature to deter intruders. With Wi-Fi 6 capabilities, you can get better connectivity, and with Smart Focus on the Live stream, you can catch important details in motion while still viewing the bigger picture.
Wyze Cam v4 is a wired camera. It is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Yes, Wyze Cam v4 is IP65-rated and can be used both indoors and outdoors.
2.5K QHD (2560x1440).
No, Wyze Cam v4 only supports 2.4 GHz networks.
Wyze Cam v4 is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Yes, Wyze Cam v4 is compatible with Wyze Web View.
Wi-Fi 6 offers better range, handling of congestion, and higher connection speed. For example, the max capacity of Wi-Fi 5 is ~80 feet vs WiFi 6 at ~150 ft, and the number of streams for Wi-Fi 5 is 8 streams vs Wi-Fi 6 at 12 streams. If you are interested in a Wi-Fi 6 router, check out our Wyze Mesh Router and Wyze Mesh Router Pro.
Yes, Wi-Fi 6 is backwards compatible.
No, Wyze Cam v4 is powered via a USB cable.
Day: 20 frames per second (fps)
Night: 15 fps
Yes. While it's not waterproof, it is weather resistant and safe to use outside. Indoor and Outdoor IP65 rated.
Wyze Cam v4 works with the following accessories: Wyze Lamp Socket, Wyze Cam Window Mount, Wyze Cam Outdoor Adapter v1 and v2, and microSD cards up to 512 GB.
Smart Focus is a new feature that adds a smaller view of the Live stream, while the camera focuses on what matters - motion. When motion is detected, you will have two views of the Live stream at the same time.
No. Wyze Cam v4 is not compatible with our home monitoring service, but it's on the wish list!
A young boy is flexing his arm in front of a map of the world.
Wyze Cam v4 with WDR
No WDR
ip65 weather resistance
Place it anywhere.
Enhanced two-way talk
Clearer conversation.
Integrated Spotlight + Siren
More safety at night.
A Wyze Cam v4 microSD card.
Record every second
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
1 of 4
A woman holding a cell phone with a Wyze Cam v4 on a table.
Connect with bluetooth®
Easy to set up.
Screw-free magnetic mount
Easy to mount.
A Wyze Cam v4 is displayed on a wooden table.
Works with smart assistants
AUTO-ZOOM WITH AI
Track with Smart Focus.
A green circle with a Wyze Cam v4 inside.
Even more features to love.
  • A small camera with a blue light on it.
    Wyze Cam v4 NEW
    Colors: White or Grey
    Finish: Textured Matte
    Resolution: 2.5K QHD w/ our best color range (WDR)
    Field of view: 115.9° (D) x 98.5° (H) x 53.1°(V)
    Night vision: B&W + Enhanced Color Night Vision
    Sound: Enhanced Two-Way Talk
    Siren: 99 dB
    Spotlight:
    Notification speed: Advanced
    MicroSD card support: Up to 256GB
    Released: 2024
    Ready to buy?
  • A small camera with a white base.
    Wyze Cam v3 Pro
    Colors: White
    Finish: Matte
    Resolution: 2.5K
    Night vision: B&W + Color Night Vision
    Sound: Two-Way Talk
    Siren: 89 dB
    Spotlight:
    Released: 2022
    Learn more
    Wyze Cam v3
    Colors: White, Black, or Limited Edition Blue
    Finish: Matte
    Resolution: 1080p
    Field of view: 121° (D) x 102° (H) x 54°(V)
    Sound: Two-Way Talk
    Siren: 80 dB
    Spotlight: No (spotlight kit sold separately)
    Notification speed: Standard
    Released: 2020
    Learn more
1 of 3
