Setting up a smart home often feels like trying to assemble furniture in the dark. It doesn’t have to be that way. If you want the short answer to which Wyze camera is best for your specific need, here it is: the Wyze Cam v4 is the best for indoors, the Solar Cam Pan is best for outdoors, the Cam Pan v3 is ideal for pets, the Duo Cam Battery Doorbell is perfect for packages, the Floodlight Cam v2 handles driveways, the Window Cam is the safest bet for renters, and the Duo Cam Pan is the top choice for small businesses.
At Wyze, we believe in premium features without the premium price. Finding the right camera is simply a matter of knowing what you want to look at and what you need covered. Let us walk through the best Wyze cameras for every specific situation so you can stop guessing and start seeing.
Quick Reference Guide
Your Need |
The Top Pick |
Why It Works |
Indoors |
Clear resolution and color night vision for everyday monitoring. |
Outdoors |
Runs on solar power and spins to see the entire yard. |
Pets |
Physically tracks moving animals across the room. |
Packages |
Features two cameras to see the visitor and the package on the floor. |
Driveways |
Bright motion-triggered LEDs paired with clear video. |
Renters |
Mounts inside looking out, requiring no drilling or permanent changes. |
Small Businesses |
Dual lenses to monitor the register and the stockroom simultaneously. |
The Best Wyze Camera for Indoors
Top Pick: Wyze Cam v4
When you just need a reliable eye on the living room or hallway, Wyze Cam v4 is the clear winner. It offers upgraded resolution and incredible color night vision. Think of it as a highly observant roommate who never eats your leftovers. It is simple to plug in, easy to view from your phone, and blends right into your decor.
The Best Wyze Camera for Outdoors
Top Pick: Wyze Solar Cam Pan
The great outdoors requires a camera that can handle the elements without forcing you to climb a ladder every few months to swap batteries. The Wyze Solar Cam Pan uses an integrated solar panel to keep itself charged with just a little sunlight. Better yet, it features full pan-and-tilt capabilities, meaning you can spin the camera around from your phone or set it to auto-track to see every corner of your yard.
The Best Wyze Camera for Pets
Top Pick: Wyze Cam Pan v3
Pets refuse to stay in one place, which means a stationary camera often ends up staring at an empty dog bed. Wyze Cam Pan v3 solves this by spinning a full 360 degrees and tilting 180 degrees. You can physically track your cat from the app as it contemplates pushing your favorite coffee mug off the kitchen counter. It also features two-way audio, so you can kindly tell your dog to get off the sofa from anywhere in the world.
The Best Wyze Camera for Packages
Top Pick: Wyze Duo Cam Battery Doorbell
A standard doorbell camera is great for seeing faces, but it isn’t ideal for seeing the ground. The Wyze Duo Cam Battery Doorbell fixes this blind spot by giving you two distinct cameras. One camera looks forward to capture the person, while a second camera looks straight down at your porch. You will know the exact moment your delivery driver drops off your box, and you can keep an eye on it until you get home.
The Best Wyze Camera for Driveways
Top Pick: Wyze Floodlight Cam v2
Driveways need illumination just as much as they need observation. Wyze Floodlight v2 turns night into day with intensely bright LEDs that trigger on motion. It is highly effective for lighting your path when you pull in late after work, while also recording clear video of anyone approaching your vehicles.
The Best Wyze Camera for Renters
Top Pick: Wyze Window Cam
Renters need flexibility. You want a smart home, but you also want your security deposit back. The Wyze Window Cam attaches directly to the inside of your glass, pointing outside without any of the annoying glare that usually ruins window-facing video. It gives you outdoor security without requiring you to drill a single hole in the exterior or interior of your landlord's building.
The Best Wyze Camera for Small Businesses
Top Pick: Wyze Duo Cam Pan
Running a small business involves enough overhead without spending your monthly budget on a complex video setup. The Wyze Duo Cam Pan gives you two distinct perspectives in a single device. With dual lenses, you can keep a stationary eye on the cash register while the other lens pans to monitor the entire stockroom or sales floor. It is a highly practical way to watch multiple angles of your shop when you cannot be there in person.
The Right Camera for the Right Spot
You do not need an advanced degree in electronics to build a smart space. By choosing cameras tailored to your specific needs, you can easily set up a customized system that works for your home or business.
Frequently Asked Questions
Do I need a subscription to use Wyze cameras? You do not need a subscription to get started. Wyze cameras are functional right out of the box with local storage using a microSD card. We offer Cam Plus, Cam Unlimited, and Cam Unlimited Pro for cloud video recording and smart AI alerts, but it is an optional upgrade.
Are Wyze cameras hard to install? Most of our indoor cameras just plug into a standard wall outlet. Our outdoor cameras offer battery and solar power options, meaning you never have to wire anything or hire a professional. Setup usually takes just a few minutes through the Wyze app.
Do Wyze cameras need a separate smart hub? No. Wyze cameras connect directly to your home Wi-Fi network. You do not need to buy an extra base station or bridge to get your cameras online.
