1 de 3
Capteur d'entrée Wyze Sense
Détecte l'ouverture/la fermeture des objets.
Taille
Extensions
$48.99CAD
En stock
Recevez-le dès
Utilisez un code postal de 6 caractères, par exemple L6Y 0P5.
Garantie prolongée de 18 mois
Détecte l'ouverture et la fermeture des objets. À utiliser avec Wyze Sense v2 ou Wyze Home Monitoring.
Voir les détails complets
No, this functionality is not available at this time. To use Wyze Sense v2 accessories, please purchase and connect them to a Wyze Sense Hub via the Wyze Home Monitoring Core Starter Kit.
Up to 100 sensors & keypads.
No. Wyze Sense Entry and Motion Sensors and Keypads are for indoor use only.
Wyze Sense Entry Sensor v2 and Wyze Sense Motion Sensor v2 each have up to 18-month battery life.
No, the adhesive is designed to be permanent.
No, all sensors and keypad will require a central device to pair with.
The Wyze Sense Hub can connect to sensors up to 500 feet away in an unobstructed room. Please note that walls and interference in your home may cause the range to vary.
Wyze Sense Motion Sensor v2 can detect movement within a 120 degree field of vision within 25 feet.
