1 of 7
Wyze Window Cam Wedge Mount
Style
$22.99CAD
FREE shipping on orders $99+
    20° Camera Tilt Angle
  • A black background with a single white letter.
    Secure Adhesive Mounting
  • A black background with a single white dot in the center.
    Reduced Glare and Reflections
    Easily Mount Inside Window
  • Compatible Wyze Products: Wyze Window Cam
  • Dimensions: 6.37 x 3.99 x 0.92 in (162 x 101.5 x 23.5 mm)
  • Model: WYZEWCWM
  • Weight: 50g
  • Material: Plastic
  • Tilt Angle: 20°
  • Temperatures Operating Temperature: 32°F - 104°F (0°C - 40°C)
  • Storage Temperature: -4°F - 158°F (-20°C - 70°C)
Wyze Window Cam Wedge Mount Shopify 01 18006bcb 6969 4ac6 99b3 bfc10a498332.
20° View Angle Tilt
Place Wyze Window Cam in your second floor window without missing any events down on the ground.
  • A Wyze Window Cam is mounted on a wall.
    Tilted Down
    Need to mount it on the second floor? No problem. Angle it down to catch all the action down on the ground.
  • Wyze Window Cam Wedge Mount Shopify 10
    Tilted Up
    Place it in a basement window tilted up to catch everything happening outside and uphill.
  • A Wyze Window Cam Wedge Mount is shown, hanging on a glass door.
    Tilted Left/Right
    Monitor your front porch or look towards the side of you house with a tilted view either left or right.
A person holding a black camera with a green arrow pointing upwards.
Once you stick it, it stays stuck. Never worry about it falling off your window.
Wyze Window Cam Wedge Mount Shopify 03
Specialized Design to Reduce Glare
A specialized angled design removes reflections to give you the clearest footage possible through a window.
A Wyze Window Cam is mounted on a window sill.
Just peel, stick, and plug in the camera. We've included an extra-long 10 ft power cable with cable clips for tidy mounting.
Support Articles
To install Wyze Window Cam Wedge Mount:
  1. Go to your mounting location. Thoroughly clean and dry the inside of the window where you plan to mount your camera. Install on window glass only. Do not mount on a window behind a screen.
  2. Peel off the film from the wedge mount. Do not trim the mounting sticker.
  3. Affix the wedge mount onto the window. Stick the mounting sticker horizontally to minimize glare and for the best image quality.
  4. Remove the plastic from the camera lens, then press the camera onto the wedge mount.
  5. Route the camera’s power cable along the windowsill and/or wall with the included cable clips.
To minimize glare.
The larger sticker is designed to minimize glare caused by indoor lighting reflecting behind your Wyze Window Cam. So not trim the sticker.
For best results, always mount the sticker horizontally.
