1 of 6
Wyze Plug Outdoor
Wyze Plug Outdoor
Weatherproof Smart Outlet with WiFi Controls
$24.99CAD
FREE shipping on orders $99+
Power up the outdoors, rain or shine, with an outdoor smart plug – because even your garden lights deserve a tech-savvy friend. From festive holiday inflatables to backyard soirées, take full control with the ease of an app. Monitor usage, set schedules – and just like that, your outdoor space just got a whole lot easier to manage, all thanks to you.
Wyze Plug Outdoor Details
  • Color: Black
  • Weight: 7.2 Ounces
  • Dimensions (L x W x D): 4.0” x 2.8” x 1.4”
  • 1/2 HP Max Motor
  • Weather Rating: IP64
Additional Details
  • Operating Environment: Indoor and Outdoor
  • Operating Temperature: -4°F to 120°F
  • Input: 120V~, 60Hz
  • Output: 15A Max with Overload Protection
  • Compatibility: Android 5.0+ and iOS 9.0+
  • Certifications: FCC, IC, ETL
  • Warranty: 1 Year
  • Connectivity: 2.4GHz WiFi
  • Bluetooth V4.2 (for simple setup)
  • Wyze Plug Outdoor x 1
  • Quick Start Guide x 1
  • Mounting Accessories x 1
Wyze Plug Outdoor has long-range WiFi to ensure it can be used in many locations. It can reach up to 300 feet in an open environment but the exact distance will depend on the location (how many walls between the hardware, the building materials, etc.).
Wyze Plug Outdoor has a built-in photocell sensor that measures ambient light around the device. It is important to follow the in-app instructions and orient the device so it faces away from the wall so the sensor is exposed to the surrounding environment.
Yes, Wyze Plug Outdoor requires WiFi for setup and all features except the light sensor which (once configured using WiFi) can automatically turn Wyze Plug Outdoor on/off based on ambient light.
Yes, there are two on/off buttons on the hardware that let you control it directly from the plug.
Yes, Wyze Plug Outdoor should plug directly into an outlet and then hang down so that water does not run into the sockets. It should not be left flat or in standing or running water. If you would like to use the light sensor, it will need to face away from the wall so the sensor is exposed to the surrounding environment.
A smartphone displaying a screen with a Wyze outdoor plug in app.
Monitor USAGE
Consume less energy and more cold brew
Energy Monitoring. Set energy consumption alerts and see historical energy usage in the Wyze app.
A large home with a circle overlaid on it.
Large WiFI Range
Long-range WiFi lets you plug in nearly anywhere
Up to 300’ WiFi Range. Confidently control outlets around your home with Wyze Plug Outdoor’s extended WiFi range (300 ft. in open space).
IP64 Weather Resistant. Made for the outdoors.
Safely plug into areas that are exposed to rain, dust, dirt, and snow.
A black device with a blue cord plugged into a wall.
A close up of an outdoor plug with both outlets being used.
2 Outlets, 2 Separate Controls
Independent control of both outlets at any given time
Two Outlets in One. Turn off your outdoor lights but leave your inflatable snowman standing strong.
A person holding a smartphone with the Wyze app open.
VOICE COMMANDS WITH ALEXA
Turn your lights off without putting your boots on.
App & Voice Control. Light up your block in seconds by asking your voice assistant or pulling up the Wyze app on your phone.
  • Streamline icon Christmas lights 40x40 1.
    Outdoor Lighting
  • A black background with a white snowflake icon.
    Roof De-icers
  • A black square with a faucet in the center.
    Pond Pump
1 of 3
Safely power melters, and more this winter
15 AMP Output with Overload Protection. Wyze Plug Outdoor offers one of the highest output ratings available for a smart plug, allowing for more ways to use it.
A black box with a blue plug hanging from a tree.
Support Articles
To set up your Wyze Plug Outdoor:
  3. Tap Power & Lighting > Wyze Plug Outdoor.
  4. Insert your plug into a power outlet.
  5. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
  6. On the next screen, you'll see your plug(s) connecting to the network.
  7. Once connected, name your plug's outlets. Tap on the first outlet's name, then type in the pop-up to edit. Tap on the second outlet's name, then type in the pop-up to edit. Tap Save.
  8. You’re all set. Enjoy your new Wyze device!
Important: Wyze Plug Outdoor should be plugged directly into your power outlet. We do not recommend connecting the outdoor plug to an extension cord as this could result in damage to your Wyze device and void your device's warranty.
Download the Quick Start Guide for Wyze Plug Outdoor in this article.
Attached is the Quick Start Guide for Wyze Plug Outdoor, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Plug Outdoor including:
  • What's in the box for Wyze Plug Outdoor.
  • How to set up your Wyze Plug Outdoor.
  • How to read the status lights for Wyze Plug Outdoor.
  • How to use Wyze Plug Outdoor.
Wyze Plug Outdoor is waterproof, but there are a few steps you can take to make the most of it.
To optimize the outdoor plug's waterproofing:
  1. Plug the Wyze Plug Outdoor into an outlet with the sockets pointing downwards to the ground. This keeps water from running directly into the sockets.
  2. Make sure the sockets are at least 6 inches above the ground. This protects the plug from being submerged by heavy rain.
  3. Cover the socket(s) with the waterproof covers when not in use.
