1 of 8
Wyze Light Strip Pro
Customize your vibe with multi-color segment control.
Size
$28.99 $47.99CAD
Low stock: 83 left
    Multi-color
    16 customizable segments
  • Icon palette.
    16 Million Colors
    RGB and tunable white
  • A black background with a white icon of a light bulb.
    Music Mode
    Sync lights to the beat of the music
  • A black image of a bed.
    Trimmable Design
    Cut to fit any space
Weight
  • 10.8 oz, 1.01 lbs
Length
  • 16.4 ft, 32.8 ft
Power
  • Power Source: Corded Electric
  • Power Adapter Output: 12 Volts
  • Power Adapter Input: 100-240V, 50/60 Hz
  • Wattage: 16.4 ft 24 watts, 32.8 ft 48 watts
Additional Details
Colors
  • 16 million
Single or Multicolor
  • Multicolor
Customizable Zones
  • 16
Lumens Per Meter
  • Blue(0.8lm/LED at 20mA) *30pcs/meter
  • Red(1.0lm/LED at 20mA) *30pcs/meter
  • Green(2.5lm/LED at 20mA) *30pcs/meter
Usage
  • Indoor Use Only
Communication Mode
  • 802.11 b/g/n, 2.4 GHz, Bluetooth
Operating Temperature
  • -4°F - 122°F (-20°C - 50°C)
Storage Temperature
  • -40°F - 158°F (-40°C - 70°C)
Life Expectancy
  • 25,000 Hours
16.4ft Light Strip
  • Wyze Light Strip Pro x 1
  • Adhesive Clips x 10
  • Controller x 1
  • Power Adapter x 1
  • Quick Start Guide x 1
  • Alcohol Wipe x 2
32.8ft Light Strip
  • Wyze Light Strip Pro x 2
  • Adhesive Clips x 20
  • Controller x 1
  • Power Adapter x 1
  • Alcohol Wipe x 4
No, Wyze Light Strips are sold in two lengths, 16.4 feet and 32.8 feet, and are not built to be connected end-to-end. The 32.8” version is actually two 16.4” strips that have the controller in the middle.
No, you cannot connect different models together physically, but they can be grouped together in the Wyze app.
No, both Wyze Light Strip and Wyze Light Strip Pro are meant for indoor-use only.
Yes! You can create a device group and control them together.
With the adhesive backing. Wyze Light Strip has an adhesive back and additional clips that can be used to attach the strip to a variety of surfaces. Make sure to clean the mounting area before installation to ensure the best hold.
Yes, you can cut both Wyze Light Strip and Wyze Light Strip Pro at designated cutting marks on the strip to fit your desired location.
Using the built-in microphone. The controller for Wyze Light Strip and Wyze Light Strip Pro has a built-in microphone used to match the lights to the beat of the music.
Wyze Light Strip Pro can have multiple colors on the same strip while Wyze Light Strip can only have one color at a time. This means Wyze Light Strip Pro can have different colors across the strip and has more advanced lighting effects. Both versions have a microphone and can be grouped together.
Multi-color segment control
Multiplayer, meet multi-color. Normal LED light strips can only show one color at a time. Ours displays up to 16 RGB colors at once and does advanced lighting effects so you can stack victory royales in the perfect ambiance.
A computer desk with a keyboard and monitor.
A white light strip with a button on the side.
Segment Control
Wyze Strips Pro has a chip between every 3 LED lights which allows for multiple colors to display at the same time and advanced lighting effects.
A white light strip with a label that says "WyzeLightStripPro" and a button that says "GND".
Protective Coating
A clear epoxy coating protects the advanced components and provides a refined, flexible appearance.
A pair of scissors cutting a white cord.
Trimmable Design
Designated cut areas allow precise customization to fit your space.
A smartphone app with a screen that shows the settings for the light strip.
Music Mode makes a rave in every room
Sync your lights to the beat of your favorite tracks with Music Mode using Wyze Light Strips’s built-in microphone. Your dance videos (and dance parties) just got a serious glow-up.
Sun Match
Automatically sync the color temperature of your LED light strips to the natural light-cycle of the day, so you can wake, work, or wind down the way nature intended.
A white Amazon Echo sitting on a table.
A view of a house with different colored lights in each room.
Wyze Light Strip Pro is a smart lighting solution that can be controlled through a smartphone app.
A bed with a light strip pro behind it.
Wyze Light Strip Pro timer settings.
More bright ideas
Make it look like someone's home whenever you are away. Just enable "Vacation Mode" in the Wyze app and our light strip does the rest.
Start a timer to have your strip turn on or off or create powerful automations in the Wyze app.
  • A rainbow colored light strip with green, yellow, and purple lights.
    Wyze Light Strip Pro (Current Page)
    - Up to 16 colors per strip
    - Advanced lighting effects
    - Protective epoxy coating
    - Plus all great features of Wyze Light Strip!
  • A purple light strip with a single light on it.
    Wyze Light Strip
    - One color per strip
    - Basic lighting effects
    - No epoxy coating
    More Info
1 of 2
Support Articles
To set up your Wyze Light Strip:
  3. Tap Power & Lighting > Wyze Light Strip or Wyze Light Strip Pro. Pro Tip: You can set up both versions from the same option. It doesn’t matter which you select.
  4. Follow the in-app instructions to install your light strip and controller in your desired location.
  5. Plug the power adapter into a nearby outlet and see the light strip begin to pulse, showing it’s in pairing mode. Want to set up several light strips at once? Install, and power them on now. You can set up a lot of strips at once. We've tested over 30! The light strip(s) will automatically begin to pulse.Not pulsing? Press and hold the side button on the controller for 7 seconds to put it into pairing mode.
  6. If prompted by the Wyze app, allow access to your location and BluetoothⓇ. Tap OK.
  7. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
  8. On the next screen, you'll see your light strips(s) connecting to the network.
  9. Once connected, name your light(s) and edit the icon(s). Tap on the light strip name, then type in the pop-up to edit. Tap Next. If you're setting up multiple light strips, they will each glow a specific color during setup. Name each one accordingly.
  10. You’re all set. Enjoy your new Wyze device!
Download the Quick Start Guide for Wyze Light Strip Pro in this article.
Below is the Quick Start Guide for Wyze Light Strip Pro, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Light Strip Pro including:
  • What's in the box for Wyze Light Strip Pro.
  • The components of a Wyze Light Strip Pro.
  • How to install your Wyze Light Strip Pro.
  • How to use the controller on your Wyze Light Strip Pro.
  • How to read the status lights on your light strip controller.
FREE shipping on orders $0+
