1 of 8
Wyze Light Strip
Wyze Light Strip
Color your world with brilliant LED accent lighting.
Size
$32.99 $54.99CAD
  • Icon palette.
    16 Million Colors
    RGB and tunable white
  • A black background with a white icon of a light bulb.
    Music Mode
    Sync lights to the beat of the music
  • A black screen with a white icon of a sunrise.
    Sun Match
    Automatically adjust color to match the time of day
  • A black image of a bed.
    Trimmable Design
    Cut to fit any space
Wyze Light Strip Details
Weight
  • 10.8 oz, 1.01 lbs
Length
  • 16.4 ft, 32.8 ft
Power
  • Power Source: Corded Electric
  • Power Adapter Output: 12 Volts
  • Power Adapter Input: 100-240V, 50/60 Hz
  • Wattage: 16.4 ft 18 watts / 32.8 ft 36 watts
Additional Details
Colors
  • 16 million
Single or Multicolor
  • Single
Customizable Zones
  • 1
Lumens Per Meter
  • Blue(0.8lm/LED at 20mA) *30pcs/meter
  • Red(1.0lm/LED at 20mA) *30pcs/meter
  • Green(2.5lm/LED at 20mA) *30pcs/meter
Usage
  • Indoor Use Only
Communication Mode
  • 802.11 b/g/n, 2.4 GHz, Bluetooth
Operating Temperature
  • -4°F - 122°F (-20°C - 50°C)
Storage Temperature
  • -40°F - 158°F (-40°C - 70°C)
Life Expectancy
  • 25,000 Hours
An image of a camera lens with the text "Coming Soon".
16.4ft Light Strip
  • Wyze Light Strip x1
  • Controller x 1
  • Adhesive Clips x10
  • Power Adapter x 1
  • Quick Start Guide x 1
  • Alcohol Wipe x 2
32.8ft Light Strip
  • Wyze Light Strip x2
  • Controller x 1
  • Adhesive Clips x20
  • Power Adapter x 1
  • Alcohol Wipe x 4
No, Wyze Light Strips are sold in two lengths, 16.4 feet and 32.8 feet, and are not built to be connected end-to-end. The 32.8” version is actually two 16.4” strips that have the controller in the middle.
No, you cannot connect different models together physically, but they can be grouped together in the Wyze app.
No, both Wyze Light Strip and Wyze Light Strip Pro are meant for indoor-use only.
Not yet, but we’re working on that for the near future.
With the adhesive backing. Wyze Light Strip has an adhesive back and additional clips that can be used to attach the strip to a variety of surfaces. Make sure to clean the mounting area before installation to ensure the best hold.
Yes, you can cut both Wyze Light Strip and Wyze Light Strip Pro at designated cutting marks on the strip to fit your desired location.
Using the built-in microphone. The controller for Wyze Light Strip and Wyze Light Strip Pro has a built-in microphone used to match the lights to the beat of the music.
Wyze Light Strip Pro can have multiple colors on the same strip while Wyze Light Strip can only have one color at a time. This means Wyze Light Strip Pro can have different colors across the strip and has more advanced lighting effects. Both versions have a microphone and can be grouped together.
A smartphone app with a screen that shows the settings for the light strip.
Music Mode makes a rave in every room
Sync your lights to the beat of your favorite tracks with Music Mode using Wyze Light Strips’s built-in microphone. Your dance videos (and dance parties) just got a serious glow-up.
Sun Match
Automatically sync the color temperature of your LED light strips to the natural light-cycle of the day, so you can wake, work, or wind down the way nature intended.
A white Amazon Echo sitting on a table.
A view of a house with different colored lights in each room.
Wyze Light Strip Pro is a smart lighting solution that can be controlled through a smartphone app.
A bed with a light strip pro behind it.
Wyze Light Strip Pro timer settings.
More bright ideas
Make it look like someone's home whenever you are away. Just enable "Vacation Mode" in the Wyze app and our light strip does the rest.
Start a timer to have your strip turn on or off or create powerful automations in the Wyze app.
  • A purple light strip with a single light on it.
    Wyze Light Strip (Current Page)
    - One color per strip
    - Basic lighting effects
    - No epoxy coating
  • A rainbow colored light strip with green, yellow, and purple lights.
    - Up to 16 colors per strip
    - Advanced lighting effects
    - Protective epoxy coating
    - Plus all great features of Wyze Light Strip!
    More Info
FREE shipping on orders $0+
