1 of 7
Wyze Handheld Vacuum
The perfect spot cleaning companion from car to home.
A powerful and compact cordless vacuum with a full accessory kit for spot cleaning anywhere from your car to your home. Whether it’s spills, pet hair, or just dust bunnies - there’s an attachment for that.
Wyze Handheld Vacuum Device Details
Color
  • Black
Weight
  • 19.8 oz
Battery and Charging
  • Charging Method: Type-C power cable
  • Charging input: 5V-2A
  • Charging time: About 3 hours to 100%
  • Battery capacity: 6,000 mAh
  • Rated voltage: 10.8 V
  • Rated power output: 120 W
Vacuum Operation
Dust cup volume
  • 0.2 L
Noise level
  • 73.8 dB(A)
Running time
  • 30 mins in default mode
  • 10 mins in max power mode
Suction power
  • 9,000 PA in default mode
  • 16,800 PA in max power mode
Additional Details
Operating
  • -4°F - 140°F (-20°C - 60°C)
Charging
  • 32°F - 113°F (0°C - 45°C)
Storage:
  • -4°F - 104°F (-20°C - 40°C)
Weather Resistance
  • None. Do not use outdoors.
  • Wyze Handheld Vacuum x1
  • USB Cable x1
  • Charger x1
  • Storage Bag x1
  • Extension Hose x1
  • Crevice Tool x1
  • Flat Nozzle x1
  • Attachment Adapter x1
  • Brush Tool x1
  • Quick Start Guide x1
  1. Remove the vacuum from the packaging.
  2. Fully charge the vacuum using the included Type-C power cable and charger. The status light will flash quickly when charged. Unplug the vacuum from power.
  3. To turn on the vacuum and operate in default mode, long press the Power button for 2 seconds. For stronger suction, short press the Power button once.
  4. To turn off the vacuum, long press the Power button again for 2 seconds.
Wyze Handheld Vacuum can be used on all dry surfaces to clean dry debris from dust mites to big crumbs. Ideal environments: home, car, office, etc.
No, only use Wyze Handheld Vacuum on dry surfaces to clean dry debris.
Yes, all Wyze Handheld Vacuum orders come with 1 flat suction nozzle. But preorders come with 1 flat suction nozzle plus 1 brush tool, 1 crevice tool, and 1 extension hose.
No, Wyze Handheld Vacuum does not connect to WiFi. It is not an IoT device.
  1. Rotate and remove the dust cup
  2. Then rotate and remove the prefilter gauze.
  3. Pull the HEPA filter out of the prefilter gauze and rinse it with tap water.
  4. Once dry, reassemble the handheld vacuum.
Attach the included Type-C power cable to the vacuum and then attach the other end into an adapter compatible with 5V-2A. Then plug it the power adapter into a power outlet.
About 3 hours from 0 to 100% battery.
When fully charged, the handheld vacuum will work for up to 30 minutes of persistent use.
Engineered for extreme portability.
Wyze Handheld Vacuum was designed to be luxuriously convenient to use for any task. At just 1.23lbs and under 3" thick, it's 50% lighter and 65% more compact than leading handheld vacuums.
A vacuum cleaner in a car.
A vacuum cleaner picking up dog food.
Double the suction of other handheld vacs.
Most handheld vacuums (8kPa) can handle dust and small debris. Wyze Handheld Vacuum (16.8kPa) takes portable cleaning to a new level by pulling up even the deepest dirt, crumbs, and pet hair.
A vacuum cleaner with a USB-C port for charging.
USB-C charging.
Charge your vacuum where you charge all your devices with the integrated USB-C port. View your battery life in bright LEDs with up to 30 minutes of run-time.
A person is opening a container of coffee grounds into a trash can.
True HEPA allergen filtration.
To empty, just press a single button located near the nossle. Inside are the dustbin, stainless steel filter, and true HEPA filter which traps 95% of allergens. Each part is easily removable and washable.
A black car seat with a button to turn on eco mode.
Turbo / Eco Mode
Whether you're spot cleaning or rage cleaning, Wyze Handheld Vacuum has a mode for that. Even at its loudest setting, it's still 20% quieter than most handheld vacuums.
Support Articles
Wyze Handheld Vacuum is not a smart device, but it's extremely powerful for a handheld vacuum.
To use Wyze Handheld Vacuum:
  2. Fully charge the vacuum using the included Type-C power cable. The status light will flash quickly when charged. Unplug the vacuum from power.
Connect the charging cable, then plug into an outlet.
There's no extra charging dock or station needed for Wyze Handheld Vacuum. Simply attach the included USB Type-C power cable to the vacuum, and attach the other end into an adapter compatible with 5V-2A. Then plug it into a power outlet.
Note: Wyze Handheld Vacuum will not charge with a C2C cable. You must use the included A2C cable.
Cleaning the handheld vacuum involves emptying the dust cup, and rinsing the filters with water.
To clean Wyze Handheld Vacuum:
  1. Empty the dust cup. Point the handheld vacuum at a trash can and single press the quick release button. Shake out the debris into the trash.
  2. Clean the HEPA filter and pre-filter. Rotate and remove the dust cup, then rotate and remove the prefilter gauze.Pull the HEPA filter out of the prefilter gauze and rinse both with tap water. Let dry.
  3. Once dry, reassemble the vacuum.
  4. Close the top of the vacuum with your hand.
FREE shipping on orders $99+
