1 of 10
Cam v4 + 32GB microSD card
The clearest Wyze Cam ever made.
Wyze Cam v4 (Color)
$59.98 $64.98CAD
FREE shipping on orders $99+
Bundle Includes
Bundle Includes
Get unmatched security with Wyze Cam v4. Crystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, and motion-activated spotlight keep your home safe day or night. Plus, 24/7 local recording, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant for ultimate convenience. Plus, unlock continuous recording and time lapses for your Wyze Cams with the included 32GB MicroSD card — never miss a moment, whether it’s big or small!
    2.5K QHD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • A black and white image of a weather icon.
    Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
    Motion-Activated Spotlight
    Automatically trigger the LED light and voice prompt for extra security.
  • A purple circle with a white cross in it.
    Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v4 Specs
Colors & Materials
  • Colors: White and Grey
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue.
Dimensions & Weight
  • 2in x 2in x 2 3/8in
  • 0.49 lb (222 g)
Mounting
  • Stand, wall mount, ceiling mount,
    or magnetic wall mount (adhesive)
Power
  • Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
  • Outdoor Power Adapter (sold separately)
  • Cable: 6-Foot Flat micro USB to USB-A
Video
  • Resolution: 2.5K QHD (2560x1440)
  • Digital Zoom: 8x
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Color Night Vision: Yes
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Audio
  • Speaker: 99dB, waterproof
  • Simultaneous 2-way Talk: Yes
  • Built-in Siren: Yes
  • Noise & Echo Cancellation: Yes
Connectivity & Compatibility
  • Bluetooth® 5.2
  • Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
Storage
  • Local (microSD card required)
  • MicroSD card up to 512 GB
  • Cloud (with subscription plan)
Weather & Temperature
  • IP65 weather resistant
  • Operating temp: -4ºF - 122ºF (-20ºC - 50ºC)
  • Storage temp: -40°F - 158°F (-40°C - 70°C)
Warranty
  • 1-Year
Cam v4 - 1 pack:
  • Wyze Cam v4 x1
  • Quick Start Guide x1
  • Wall Mount Plate x1
  • Wall Mount Plate Tape x1
  • Screw Kit x1
  • Indoor USB Power Adapter x1
  • 6-Foot Flat micro USB to USB-A cable x1
+32GB MicroSD Card
A young boy flexing his arm in front of a map of the world.
Wyze Cam v4 with WDR
No WDR
A green circle with a Wyze Cam v4 inside.
Even more features to love.
Unlock amazing camera features
Record continuously with the included 32 GB microSD card. Add AI alerts and cloud backup with Cam Plus.
A person is inserting an SD card into a device.
Local Recording
Record around the clock locally with the included 32 GB microSD card.* Set it up in the Wyze app, then review playback in the app or directly from the card. Add AI alerts and cloud backup with Cam Plus.
*The majority of Wyze Cams have a built-in microSD card slot; please check technical specs for compatibility and supported card size.
A smartphone app displaying a baby in a crib.
A house with a deck at night.
A house with a white porch and a black car parked in front of it.
A view of a house with different colored lights in each room.
A living room with a couch, a chair, and a television.
A sunset on a beach.
Available footage will be highlighted in the timeline. Pinch and zoom on the timeline to select a specific point in time. It's that easy.
Quickly find events in a few convenient taps.
Capture every moment effortlessly! Your camera will keep rolling, recording footage directly to the included 32 GB microSD card. Revisit and relive your favorite moments at your convenience. Add AI alerts and cloud backup with Cam Plus.
Capture the world in motion and watch as time unfolds before your eyes. From stunning sunsets to bustling cityscapes, create mesmerizing timelapse videos.
Saving videos to your Wyze Cam is as easy as 1-2-3.
To learn more, click the button below.
* Requires Wyze Outdoor Power Adapter for outdoor use.
* Requires microSD card for local recording.
