Skip to content
Front Porch Security Bundle
Capture all of the action happening in your yard.
Wyze Cam OG (Color)
$99.98CAD
Keep an eye on who's coming and going without breaking the bank. Get the new Wyze Video Doorbell v2 and a Wyze Cam OG to see everything on your front porch.
  • Owl in front of color wheel icon
    1080p HD Color Night Vision
  • Rain cloud with the sun behind it
    IP65 Indoor/Outdoor Security
  • Bright spotlight
    Built-In Spotlight with Integrated Siren
  • MicroSD card with arrows that represent continuous recording
    24/7 Recording to Wyze microSD Card
    No subscription required.
Video Resolution: 2K (2048 x 1536)
Video Format: H.264
Sensor Size: 1/2.8"
Aperture: F2.0
Focal Length: 2.1mm
Frame Rate: Day: 20FPS, Night: 15FPS
Field-of-View: Horizontal: 135°, Vertical: 103°,Diagonal: 166.8°
Power: 16V-24V AC,≥10VA
Microphone: ECM (Electric Condenser)
Zoom: Digital Zoom
MicroSD card: Up to 256G in FAT32 format
Cloud: When paired with a Wyze Security Plan
IP65 weather resistant
Operating temp: -4°F - 122°F (-20°C - 50°C)
Storage temp: -40°F - 176°F (-40°C - 80°C)
Wyze Cam OG
Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
Video FPS: Daytime - 20 FPS Nighttime - 15 FPS
Video Encoding: H.264
Video Resolution: 1920 x 1080 (1080p)
2 spotlight (5000K, 40 lumens)
Weather Resistance: Indoor and Outdoor (IP65)
Operating: -4°F - 131°F (-20°C - 55°C)
Storage: -40°F - 158°F (-40°C - 70°C)
Power Cable Length: 6 ft (1.8 m)
Ports: 1 micro USB
Night Vision: 4 IR LEDs (850nm)
Digital Zoom: 8x
Field-of-View-OG: 121.4°(DFOV), 102.3°(HFOV), 54.1°(VFOV)
Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
Local Storage: Supports up to 256 GB microSD in exFAT format
Connectivity & Compatibility
IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
Phone Compatibility: Android 9.0+, iOS 15.0+Integrations: Alexa, Google Assistant, IFTTT
Warranty
1 Year
Note: There may be slight differences in appearance depending on which camera model you receive. The product functionality is identical.
The latest 2025 model number is WYZECGSD on the box. The previous model number is WYZECGS.
Wyze Video Doorbell v2:
1x Video Doorbell Camera
1x Wyze Doorbell Chime Controller
1x Wall Plate1x Wedge (30°)
1x Installation Kit3x Wire Caps
2x Extension Wires1x Screw Kit
2x Long Screws
2x Short Screws
2x Wall Anchors
1x Quick Start Guide
Wyze Cam OG:
1x Plug-in Camera
1x Indoor Power Adapter
1x USB Cable
1x Wall Anchors
1x Wall Plate
1x Mounting Screw Kit (M4)
Two white cameras on a table.
Independently amazing.
Upside down or right side up each camera operates on its own to cover every angle of any space.
Smartphone camera with Wyze app notification on it.
3x faster motion notifications.
A speaker with a microphone on a wall.
Upgraded two-way audio.
Person holding a smartphone with a live video stream of their dog.
  • Smartphone with livestream video open on the screen. White text overlay of local microSD card storage features: timeline, calendar view, continuous recording, and timelapse..
    Supports all Wyze microSD cards, up to and including 256GB.
  • Smartphone with detected events on the screen. White text overlay of Cam Plus features: Unlimited cloud storage, smarter notifications, and advanced detection of people, packages, vehicles, and pets.
Cam OG's live view inside the Wyze app.
A smartphone displaying a live view of a home.
Cam OG's playback timeline with labelled events inside the Wyze app.
Cam OG's detection zone settings inside the Wyze app.
Cam OG's smoke and carbon alarm settings inside the Wyze app.
A smartphone screen with a setting for alarm sounds.
A brand new app experience.
Unlike a stray Lego brick at 1 am, we've put all the handy tools exactly where you'd want them–from spotlight and siren controls to the new simplified event review.
Enjoy a new, easy-to-scan Recent Events section to quickly navigate footage.
Tell Wyze Cam OG exactly where you want it to watch. Get notifications only for detections within your customized zone.
  • 3D render of Wyze Cam OG security camera against a white background.
    Wyze Cam OG
    • 120° Field of View
    • Built-In Spotlight with Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    • Works with Wyze Cam OG Stack Kit
  • 3D render of Wyze Cam OG Telephoto security camera against a white background.
    • 3x Telephoto Camera (27° Field of View)
    • Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    Learn More
